Question about Tag Heuer Formula 1 CAC1111.BA0850 Wrist Watch
Watch crown I have a vintage Louis watch , the crown has fallen off and lost. How do I replace it myself ? I see the stem with threads but , are there certain sizes and if found do I just screw it on?
Dongguan Perfect Watch Parts Co. , Ltd. has been manufacturing and selling the watch parts-crown for nearly 5 years since 2002. And we have many different materials crown & pusher for our customers. Such as, stainless steel, copper and alloy. BTW, In order to suit our customers' requirements concerning the environment protective, We also provide our customers crown&pusher which meets RoHS compliance .
Tel:86-0769-21295490
Email:Cruiseju@gmail.com
Posted on Oct 14, 2008
  • 111 Answers
Nice noon ! can you replace the crown but need of exact size of crown that the tread are same of old crown! thank you ! god bless !...
Posted on Sep 02, 2008
The crown unscrews and comes of is this normal Is there a spring inside?.
The crown is attached to the "stem" by screwing them together. The procedure, and this is not a good do it yourself project in most cases, is to remove the crown and the stem. Hold the stem in a "pin vise" and apply a threadlock to the threads and attach the crown. Install the crown and stem in the watch and check to see if everything still works(setting, time adjustment, etc.) Might pay to have a watchmaker do this, this is more technical than it seems.
May 24, 2011 | Watches
The stem and crown fell out of my fossil watch, i would like to obtain replacements and install them myself.
mcdevito75 here, You may not be able to fix your fossil watch, it"sa quartz and once the crown and stem came out, the mechanism that holds it in plce may be broke.
Jun 14, 2010 | Watches
Screw down crown wont lock
There are only two things that can cause screw down crown to malfunction. First is dirt and second is weakened/damaged thread. In first case you need to use ultrasonic cleaner by immersing the crown AND case to get rid of any dirt and grime sticking on both threads. If the matter is weakened/damaged thread - you will have to fit new crown and (possibly) new case tube on which crown is screwed onto. This can be done by decent watchmaker only.
Rate me, plz.
Jan 06, 2010 | Watches
Winder is lost
You need a replacement stem and crown. I would replace the stem just to be sure you arent putting a new crown on a damaged stem.
Sakgen is very good about repairing their watches. Unfortunately this doesnt fall under their warranty but the repair directly through them is an average price for this part.
Generic after market crowns are also available at local watch repair shops. Make sure that if you go this route that you select a shop that can reseal the watch to is water resistance rating so you do not void your lifetime limited warranty on the movement. This mean they must have a pressure testing chamber and be able to supply printed proof of resealing.
Sep 23, 2009 | Skagen 355LGSC Wrist Watch
Stem of watch won't return to its original position
The winding crown is loose on the stem. Get the stem completely out of watch and while holding in vice or pair of pliers screw the crown back on tight. Do not overscrew it, as the stem may brake. Even better would be to unscrew the crown first, dip the threaded stem end in to the Superglue and then screw the crown back. It will prevent from the same problem in future.
Rate, please.
Jul 29, 2009 | Watches
I cant pull out the date/time pin on my luminox 3204. any suggestions?
On some watches - scuba usually - the crown has a rubber seal and that seal is engaged when the crown is screwed to the case. If your watch is like this, you need to unscrew the crown before you can pull out the stem. Twist the crown in a counterclockwise direction several turns. You will be able to tell when it is completely unscrewed because youwill feel spring tension. Pull out the stem to set the watch. When you finish, push the stem back in. Push against the spring tension and carefully thread the crown back onto the case. That should do it.
Jun 12, 2009 | Luminox Navy Seal Dive 3204 Wrist Watch
Broken stem (or came off)
You could send it to Timex yourself and they might fix it for free if it looks like it just unscrewed.
Jun 10, 2009 | Timex Sports Ironman Triathlon 50-Lap...
I pulled on the crown and it came off the stem
Do not open the watch yet, as you do not know how to get the stem out.
Take an eyeglass and examine the crown. You will find the small hub in the centre of the crown. If the centre of this hub is hollow and you can see the thread in it- you will be able to screw it back on stem (all watch crowns are screwed on to stems, never pressed).
If the centre of that hub looks filled with metal, then the stem end is broke and you will need replace stem AND crown (the metal filling the hub is the broken end of stem).
In case if the crown still in tact, let me know by asking questions and I'll guide you through all the process HOW TO.
Rate me, please.
Mar 24, 2009 | Watches
Invicta Lupah crown replacement?
If there is no problem with the stem then you can just screw it on. I suggest using a thread lock to insure a good fit. Start by taking the back off and hold the stem in place with a pair of needle nose pliers. Be sure to start by turning the crown in the reverse direction so you dont cross thread. Once you feel it hit the beginning of the thread you can turn in the on direction.
I always recommend having this sort of service done by a watch maker/technician who can reseal the watch and pressure test it to be sure it is still water resistant.
Aug 30, 2008 | Invicta Dragon Lupah 2093 Wrist Watch
Broken stem off aromen gobletover 50yrs old maker bleirristall made in bavaria.germany 24% clear stem any chance of repair have broken pieces was my Mothers passed away meens the world to me please help...
Is the stem broken near the crown? Or do you think there is enough stem to take out of crown? If not you probibly will have to go to a watchmake (NOT a watch repairman) to make you the stem. If there is enough metal to take stem out of the crown you may be able to get someone to solder the stem back together. I do that reguarly with stems that are vintage, and I don't want have the time to remake the whole stem. Let me know. Good Luck!!!!
Jul 09, 2008 | Watches
Tag Heuer Formula 1 CAC1111.BA0850 Wrist Watch Logo
339 people viewed this question
Top Tag Heuer Watches Experts
Jimmy Accardi
Are you a Tag Heuer Watch Expert? Answer questions, earn points and help others
