Question about Dishwashers
Indesit IDE 1005 error code
I have an indesit dishwasher which is showing error code A10. what do I need to do to fix it? will i need to get any replacement parts, if so which ones?
Many thanks
Gary
  • mamachrissy9 Nov 27, 2008
    My dishwasher also showing A10 could I buy and replace part myself?
  • 868 Answers
Replace the control board
Posted on May 22, 2008
A10 code Indesit Dishwasher DSG573
A10 is a heater fault check heater or look for poor connection on module normally the pink or blue wire
Jan 24, 2014 | Hotpoint 24 in. FDW60 Free-standing...
Indesit dish washer is showing error code A08 why
from what i can find out, it means (auxillary wash pump triac cloesd/open circuit)
Sep 25, 2011 | Indesit 24 in. DE73 Evolution...
Fdd914 dishwasher error code A10 appears and its not in the booklet
Hi, the interpretation for error code A10 is: A10 = fill solenoid valve triac closed/open circuit - check valve/ operation - machine drains until level switch resets + 30"
Now, to try and solve the problem yourself: Turn off the water supply to the dishwasher & remove the hose, Run the machine for several minutes in a normal position. Turn the machine off, reconnect the fill hose, turn the water back on then turn the machine back on.
If this doesn't solve the problem, then you'll need to call a service person.
Jun 12, 2011 | Hotpoint-Ariston FDD914 24 in. Built-in...
My dishwasher is showing error code a10 model ide 1005
Jun 12, 2011 | Dishwashers
Fault code A10 on indesit dishwasher, how do I fix it?
A10 fault indicates heater open circuit fault. Problem either heating element, or control board. Test element for correct continuity and resistence, if OK, replace controller
Aug 07, 2009 | Indesit Dishwashers
A05 code
Indesit Error Messages and Error Codes Indesit Dishwashers
  • F10 - Fill or empty time out. Check that the hoses are not kinked, that the taps are on or whether the drain pump or hose is blocked.
  • F11 - Heater timed out. The heater has not reached the required level. Book a service engineer.
  • F20 - Temperature under range. Book a service engineer. .
  • F21 - Temperature over range. Book a service engineer.
Fault codes for Indesit LCD Dishwasher Models
  • A01 - Float switch operated - Book a service engineer.
  • A02 - Open/Short circuit heater relay - Book a service engineer.
  • A03 - Short circuit on thermistor - Book a service engineer.
  • A04 - Unable to reach or sense temperature within 70 minutes - Book service engineer.
  • A05 - Pressure switch has not been reset - Book a service engineer.
  • A07 - Open/Short circuit wash motor triac - Book a service engineer.
  • A08 - Open/Short circuit auxiliary wash motor triac - Book a service engineer.
  • A09 - Open/Short circuit with main wash traic - Book a service engineer.
  • A10 - Open/Short circuit fill valve traic - Book a service engineer.
  • A11 - Half load valve traic or alternating motor action - Book a service engineer.
  • A12 - Open circuit heater rely - Book a service engineer.
  • A13 - Open/Short circuit dispenser traic - Book a service engineer.
  • A14 - Drain hose too low causing syphoning. Check drain hose and re-adjust.
  • H20 - Check tap and pressure of incoming water.
_uacct = "UA-1207243-4";urchinTracker();
Sep 14, 2008 | Indesit 24 in. DE73 Evolution...
Hotpoint Aquarius+ FDW70 Error Codes
i have the same on my dishwasher and have just been looking on the net. Found out that the error code A10 means open/short circuit fill value traic. Whatever that means!!! and to book a service engineer. Hope that helps
May 04, 2007 | Hotpoint 24 in. FDW60 Free-standing...
Indesit evolution de 73 dishwasher with an AO5 error code
a05 is pressure switch not reset. check for blockages in the drain pump, filters and sump
May 06, 2007 | Indesit 24 in. DE73 Evolution...
Dishwashers Logo
610 people viewed this question
Top Dishwashers Experts
Owen Barnes
