Question about Casio EXILIM ZOOM EX-Z70 Digital Camera
9 volt battery trick
Can you explain the logistics of this '9V battery trick'
how do i actually do it?
If you don’t find a solution you may want to try fixityourself123@gmail.com. He was able to give me some great advice and he has used parts in good condition and at a good price. It worked for me.
Posted on Sep 13, 2008
Audio problems. The rear speakers sometimes work, sometimes don't and the driver side door never works. I don't know if it is the wiring or speakers.
A good way to test speakers / wiring is to use a 9v battery. Unplug leads from the deck and jumper the 9v + and - to the speaker wires and see/ listen for the speaker cone to move. With this simple trick you can trace problems pretty quickly
Aug 14, 2016 | Cars & Trucks
Replace alternator
It should not be too difficult to unbolt the alternator. Basically remove the drive belt, disconnect the battery. (it would save you some grief if you take a 9V battery and connect it to the battery terminals. This will be enough voltage to keep the computer memory and radio programming when you disconnect the car battery.) The 9V battery is a trick I use all the time.
Apr 06, 2014 | Kia Sportage Cars & Trucks
Physical size of the Actron CP7672 Digital Multitester,
The meter measures in size aproximatelly 2 1/2" X 5" X 3/4" deep, and takes a standard 9 Volt battury, unscrew the two phillip screws on the back, and gently pull off the back cover, and you will see the battury at the bottom of the meter, unclip it from the battury clip, and replace with a similar type of 9 Volt battury, and reassemble.
Feb 12, 2012 | Actron CP7672 Digital Multitester
Batteries
I think you will find that one 9 volt battery would not last any time at all. the 6 AAs have a big capacity and that's why they use them, a little 9v battery is intended for low power equipment.
I see it is supplied with a 12v AC adaptor, if you connect a 12V battery via the adaptor socket you may get a longer run time if its a rechargable battery even better.
Jan 22, 2010 | Meade NIghtView NIght Vision Monocular
Batterys dont keep there charge i think the batterys need to be replaced
before you dump those batteries, check the charger. If the battery when charged runs the tool but dies out quickly then you are probably right. If the battery never seems to be charged at all, then it may be the charger.
Dec 10, 2009 | Hitachi DS14DVF3 14.4 Volt Ni Cad 3/8 Inch...
Power pack creates 'hummmm' in wireless headphones.
I don't think the 12V power pack is the problem. Generally there would be a regulator on the plug pack input to the transmitter (as power packs are notoriously bad at voltage regulation).
My guess is it an 'earth leak' between the TV and the transmitter via the audio lead. Does the powerpack have a earth pin. If so, are you able to plug it into an non-earthed power outlet.
If this isn't possible try removing the ground connection from the audio lead.
It could also be a bad audio lead.
Is the TV mono and the transmitter stereo or visa versa? You may need a mono to stereo lead.
Hopefully something in here will help.
Mar 17, 2009 | Electronics - Others
Power pack creates 'hummmm' in headphones.
GKLHKJHKLHKLHKLHKLHKJLHKL
please rate this solution?? hahaha lol here you go
Mar 17, 2009 | 1996 kawasaki ZZR 1100
Lithium ion battery won't charge
known issue, battery needs to be 'shocked" back to life. Here's the fix:
"Hi,I just found a soultion on another website and it appears to have worked for me.Apparently the battery loses it memory when fully discharged,to fix this take a 9v battery and place the terminals + to + and - to - with the camera battery for 30 seconds or so then put the battery back in the camera and charge as normal.I just did this and it seems to be charging and the red light is solid.hope this helps."
Nov 04, 2007 | Casio Exilim Zoom EX-Z700 Digital Camera
New Camera Does Not Charge
A red flashing light does NOT mean it charging. THat means you have a defective battery. Call tech support and tell them that you have a defective battery and they may be able to get a replacement for you.
Jun 08, 2007 | Casio Exilim EX-S600 Digital Camera
Open Questions:
See all Casio EXILIM ZOOM EX-Z70 Digital Camera Questions
Casio EXILIM ZOOM EX-Z70 Digital Camera Logo
175 people viewed this question
Top Casio Cameras Experts
mohamed salim shaikh
pontelemon
pontelemon
Are you a Casio Camera Expert? Answer questions, earn points and help others
