Question about Sony Ericsson Z550i Cellular Phone
Sony eriscsson z550i BLUE TOOTH not working
Hi, i m using z550i since last 1 1/2 years , blue tooth is not working since last one month, what is the solution
  • djura_91 Jun 13, 2008
    bluetooth on my se z550i doesn't work last few months. I don't know what's the reason but it always says "Bluetooth turned on", and there is no any sign of bluetooth.
Hiiii i am Amay last 2 month my Bluetooth not work what is the solution
Posted on Jul 28, 2008
Code for sony dr-bt100cx bluetooth
Hi, when you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
When pairing both device, you will ask for pairing code, You four digit numbers(default code(0000). and pair.
After pairing both device, you detected paired, you can now use the blue tooth device with your phone.
there are no special code for pairing Blue tooth device.
Normal codes used are any four digit, four numbers you want to use.(0000, 1234).
Hope that helps...
Thanks for using fixya.
Nov 25, 2010 | Sony DRBT100CX Bluetooth Headset
Tip
Passcodes for most blue tooth devices
Most blue tooth manufactures use a factory 4 digit pin pairing code,motorola uses 0000,and 1234,even though they are the most common of the codes used to pair a blue tooth device there are two others that i know of,and they are 1111, or 9999,now in the 10 years that i've dealt with blue tooth technology i have yet to come across a blue tooth device that has not used one of these 4 codes,so try these first from the most common ones first,then if it is nessasary to try other ones try the last two,but 90 percent of blue tooth manufactures use the same technology witch in this case would be the same codes..i hope this helps..thank you
on Feb 26, 2011 | Cell Phones
I go to the bluetooth menu and turn it on. it says "Bluetooth turned on" But the icon fails to appear and file transfer fails.
HOW TOCONNECT BLUETOOTH
It all depends. When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
Take care.
Aug 16, 2010 | Sony Ericsson K550i Cellular Phone
How to put a hbh705 into pairing mode
Take care.
Aug 06, 2010 | Sony Bluetooth Headst HBH705 Sandcolor...
How to connect sony ericsion w395 via blue tooth
Take care.
Jul 07, 2010 | Sony Ericsson W395i GSM Quadband Phone ...
Bluetooth not working in sony W580i phone
After attempting on this process, if doesn't work,that means thee blue tooth is corrupted and to restore bluetooth, you will to flash the phone. Flashing the phone will restore back blue tooth.
You can use this links to see how to flash your phone.
hubpages.com/hub/How-to-Flash-your-cell-phone
and
unlocktotalk.com/UnlockCodeInstructions.htm.
Take care.
Take care.
Jul 03, 2010 | Sony Ericsson w580i Cellular Phone
Can i install blue tooth Sony ercisson w200i
Sorry we can not install the blue tooth on w200i phone, Blue tooth is a hardware device... Sorry
Hope this has helped you.. Thanks
Jun 26, 2010 | Sony Ericsson W200i Cellular Phone
Problem in transfering file via bluetooth
Take care.
Jun 17, 2010 | Sony Ericsson K750
Motorola Razr 2 V8 blue tooth will not power on
my motrola v8 b tooth can b powered on , and it can recieve data but i cannt send data to any blooth tooth device , the send botton in the last not working, cn u tell me why.....
Oct 18, 2008 | Cell Phones
Sony Ericsson Z550i Cellular Phone Logo
163 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Sandeep Shenoy
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
