Back to:
Tags:
2008 Toyota 4Runner
Battery light on the dashboard cannot go off
posted by ayew on May 22, 2008
battery light on the dashboard cannot go off
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on May 23, 2008
Not Rated (0)
cmrvi1
Rank:Guru Guru
Rating: 87%, 83 votes
Check the voltage at the battery with the engine off. Then check the voltage with the engine running. It should be at least 1 volt higher than with engine off. If both voltages are the same, then the alterator is bad,
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on battery light on the dashboard cannot go off:
I don't want to Accept this solution
Can you Help with these Cars problems?
Land Rover Discovery
Hi, i have a manual Landrover Discovery 300Tdi, 1995 M...
Hyundai Elantra
i,ve got a problem starting my 97 hyundai lantra 5dr...
Isuzu Rodeo
the transer case has a leak in it and we have put luquid...
2008 Toyota 4Runner
i need to remove the factory installed radio/gps. i have a...
2008 Toyota 4Runner
Hello, I have 1998 Toyota 4Runner in very good condition I...
Loading problems.
Repair Service
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
