Question about HP LaserJet 4 plus Printer
Hp Laserjet printer
When i print i get a band of shading down the left hand side of the page.
I have changed the cartridge but has made no difference. If anything is is worse now because it has gone from thin stipes to a wide band covering almost 1/3 of the page width.
Any suggestions please?
  • soucek Oct 08, 2008
    The stripe down the left side has grown to about 3" wide, started about 1/2" wide. I think it may be from preprinted return addresses on envelopes. I was printing abotu 250 and noticed it at about 100. I have tried theHP Clean utility, wiped down the roller under the toner, and the problem comes back in about two more envelopes. Any ideas how to fix/avoid this problems?
    Problem Solver:
  • 7 Answers
A vertical stripe that is consistent top to bottom could be a laser issue, it has prisms and lenses that could be dirty or even a bit of paper stuck covering the laser light window. Dig into it and look for any debris and clean the lenses.
Hogdoctor
Posted on Jun 02, 2008
When printing a page. I get a large shaded area
umm
you may know that this model of printers is very old
i think your cartridge is expiered try to change the cartridge if by the old one just to test....
if the new cartridge is the reason then you have to replace it
Feb 19, 2010 | HP LaserJet 4p Printer
New toner prints very light. No setting changes on printer.
I had a similar problem, it turned out to be a cheap toner cartridge. Replaced it with an HP cartridge and have had any problem since.
Mar 23, 2009 | HP LaserJet 4p Printer
Color LaserJet Printer Problem
Have you tried changing the magenta and black toner cartriages?
Jan 26, 2009 | HP Color LaserJet 3500 Printer
HP Laserjet 1100, band of unprinted area after new toner install
Hi Friend,
You have mentioned this is a 2nd hand printer,
you have to service the printer,(fuser unit)
if the problem exists after fuser service check Laser Scanner also,
Thanks
Lux5
Nov 28, 2008 | HP LaserJet 1100 Printer
Grey band on left side of printed page.
replace toner drum or replace cartridge
Mar 19, 2008 | HP LaserJet 4 plus Printer
LJ 2430 Printing Blank Pages
HI there have you tried the toner cartridge as this could also cause this problem? Also change the transfer roller and are the bands going from left to right or from up to down. If the bands are left to right change both if up to down more likely to be the toner cartridge.
Hope this helps you
Thanks J
Jan 11, 2008 | HP LaserJet 2420 Printer
Hp 2420 printing light on left side of page
take out cartridge and look at roller on bottom of printer, clean with clean cloth and try, also there is a slit ( or hole on the inside ( put your hand inside and try to touch the top of printer there is a hole there where the images go to the laser clean with clean lint free cloth.
Nov 01, 2007 | HP LaserJet 2420 Printer
Black edge
With other laser printer that problem would be attributed to the drum being faulty. Your model of printer has the toner and drum built into one unit - the "cartridge". You can try a different cartridge and see if that changes your printing results. Another reason, which is less likely, but still possible it that your fuser film sleeve need to be changed. The fuser film is located deep within your printer and requires a technician to replace it. Regards, Babb
Apr 23, 2007 | HP LaserJet 1018 Printer
HP LaserJet 4 plus Printer Logo
174 people viewed this question
Seeker5211
Seeker5211
