Question about ASUS WL-500W Router (WL500W)
3 problems writting on hd, drop connection n download master
1. i hav serious connection problem to the internet when i bootup my com each time which i hav to reboot my router again to get connected quite often same as wireless as well it juz drop connection.
2. Most of all I could share my powered ext hd which allow me n others to view but can't copy/del files to the hd folder. access denied which i hav give all right to readn write.
3. And i cant download files to my ext hd using download master keep giving me an network error. device not ready. router firmware v2
  • Alexza Jun 09, 2008
    My Download Master dose not download anyfile, even online appear on screen. It's just appear "Queued" but I can download the same file with
    Utorrent completely smooth. I don't know how I have to set up more ? Now I think Why I bought this Asus ? I bought this because I love to download. Feeling so bad that can't download.
  • Anonymous Oct 30, 2008
    I canĀ“t create folders on my ext HD, bur I given IT full read/wright access
Use a FAT32 Formatted partition (32GB) on your external USB Harddrive as the main Master Download Area. To do this, connect the drive to the PC by USB and re-partition the drive in sections with the disk manager. 32GB for the FAT32 and the rest in NTFS. Re-connect the drive to the WL500W USB and the FAT32 partition will be recognised automatically by the Router. Linux users can use the full HD drive if they format the drive in Ext2/Ext3. Correctly formatted USB memory sticks with a capacity of 32GB are better suited for this un-attended (low power) dowloading. You can use a (FAT32) 8 Gbyte stick also !
Warning !
Using only NTFS partitions will make the drive read-only and useless for un-attended downloads by the WL500W. Unfortunatly this is the case with 100% of all new availbale drives (>500GB) - So RE-PARTITION it wisely !!!
What about Queing (Waiting) ?
It waits for the connection and if bandwidth is available it starts the download. If files are missing on a server or the address is invalid an error is risen and the link is aborted or deleted. Many BitTorrent files are invalid or have nobody seeding. Waiting is therefore the best option.
Posted on Jul 08, 2008
Connection drop out (Time out) ?
Maybe your graphics card is small or another problem, more information please
Apr 06, 2014 | Internet Avg AVG Security V8.0 WIN - 2...
The channel master locked up so I unplugged it. Now, when I plug it back in it just sits and says loading Chanel master tv but does not load. What should I do?
I have 3 of these 7000pals and 2 have done a similar thing, one of them did it twice. After the loading channel Master screen hangs for a time, they would restart. Then the same cycle would keep repeating. It seems like after years of adding and deleting timers, the DVR's software gets "confused". I've noticed twice it happened on the hour just as a program timer started while I was watching a program through the DVR. ZAP...Locked up! The power button would not even work to turn it off.
The steps below fixed all three instances of this failure.
To unlock the Channel Master CM7000PAL DVR:
1. Unplug the recorder from the wall outlet and DISCONNECT THE ANTENNA. Now plug it back into the wall power outlet.(This will keep the recorder from freezing and rebooting)
2. let it go thru it's normal bootup, tv guide search, etc.
3. When you are able to, hit MENU and then go up to TIMERS. Delete all of the record timers. Unplug it, reconnect the antenna, and plug it back in.
4. After a now a proper bootup, re-program you timers and you will be good to go.
5. And the best thing is, all of your pre-recorded shows will still be there on the hard drive.
I would suggest that you do a yearly "TIMER CLEAN" to avoid this trouble in the future.
Sep 22, 2013 | Channel Master CM7000PAL HD DVR
My CM7000PAL unit only displays "Channel Master CM-7000PAL..... Loading. Please wait..." then turns off and then repeats the same message. I don't know how to fix this issue. Has anyone found a solution?
3. When you are able to, hit MENU and then go up to TIMERS. Delete all of the record timers. Unplug it, re-connect the antenna, and plug it back in.
I have 3 of these 7000pals and 2 have done this same thing, one of them did it twice. I would suggest that you do a yearly "TIMER CLEAN" to avoid this trouble in the future.
Aug 06, 2013 | Channel Master CM7000PAL HD DVR
Channel master cm7000pal
Jun 29, 2012 | Channel Master CM7000PAL HD DVR
Whenever i connect to the internet...i can't seem to be on the homepage of microsoft.com...more serious problem is that whenever i download a file that came from something like microsoft.com blah....it...
you seem to have a problem with your data connection. if you don't mind my asking. what internet provider are you using in? if you are using a router modem try to power off the router modem for about 15 minutes then turn it on again. and connect back to internet.
Jul 11, 2011 | Computers & Internet
Bought fable2, knothole island DLC and my save wont load.
Was this purchased while connect to your friends connection? if so then the problems is that it was purchased with his connection and not your own
Oct 01, 2009 | Microsoft Fable 2 for Xbox 360
Game installing problems.
do u hav internet? do u hav directx?
Aug 05, 2009 | Video Game Consoles & Games
My nokia 3230 mobile always hang i have a serious problem on that mobile so please give me some solution to solve it.............................................................
pls Hard Reset ur device like this
Master reset
1) *#7370#, then enter 12345 (This is the default security code unless the user has changed it) and then Yes. The phone then wipes all apps and phonebook contacts on the internal memory.
if doesnt help then pls update ur Phone ROM on this link it will be ok it is a pure software fault see link for the update download the update application and driver for ur phone and then connect wire provided and thru internet the application will update ur phone
http://europe.nokia.com/A4144321
Pls rate me WELL !
May 06, 2009 | Nokia 3230
Hard drive 20.4 gb
1st of all, check your PC is it has 2 HD or not, if there are 2 HD then make sure 1 is set to Master and another 1 is Slave or Cable Select. If there is only 1 HD, then have to set it to Master.
After this, enter the BIOS to see whether the PC can locate the installed HD or not.
If it is not, then make sure the HD is connected single with IDE cable (do not share with CD-ROM or the other HD, if it is share the unplug the other 1).
If the problem still then may be u can check the HD either is still functional, find a IDE to USB converter in computer shop and connect your HD to your PC and see either the HD can be detected or not as an external HD. If no, then the worst case show your HD is spoil already.
YBC (/\)
Oct 19, 2008 | Quantum Fireball Lct20 (QML20000LD-A) 20...
Phone not connecting to pc
I hav the same phone....
Here's the solution
Just download and install the following drivers:--
1. Motorola_EU_Driver_Installation_v2.6.2 (look up in google)
2. Mobile Master 7 (can be found on filecyb.com)
After installing connect Motorola L6i via any data cable.Sure to detect by xp or vista
Good Luck.
Sep 27, 2008 | Motorola Mobility L6I Cellular Phone
Open Questions:
ASUS WL-500W Router (WL500W) Logo
536 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
