Question about Garden
Repair of pull start to garden blower - Garden
    Scholar:
  • 71 Answers
To replace the pull cord line:
If your pull cord is still attached to the grab handle, it's likely your spring is still wound. Follow this if this is the case, purchase rope of the correct length (or cut) and the correct diameter at your local lawn/garden store, then:
1. Disconnect the long drive shaft by removing the small set screw and the clamp - pull the shaft out of the engine body.
2. Remove the recoil assembly (About 5-5 torx bolts). You may need to disconnect a wire to the kill-switch at this time.
3. Pull the cord until it stops and use a small piece of wood acting as a wedge to jam between the recoil and the housing.
4. Cut the line and pull the knotted terminating end from the hosing.
5. Keep the wedge tight so it does not spin back. If this happens, you will simply need to rewind the spring back (about five turns) and re-wedge it.
6. Feed line through the recoil housing and into the recoil. Pass line through the hole in the recoil and knot the end. Trip to about .25 inch tail. Pull the rope through the grab handle and single or double knot this.
7. Remove the wedge and allow the spring to pull the rope back into the recoil.
8. If it does not completely recoil, either your rope is too long or you will need to add a "wind" to your spring buy removing the line and wind back 1 more turn. Retry.
Posted on Sep 25, 2010
SOURCE:
How to start my "Toro Power Clear 621e snowblower"
Usually full chock, pull a few times,if it doesn't start go to half chock. Out should give full chock.
Jan 05, 2018 | Garden
Snow blower will not start
sheer pin on flywheel sheered off pull flywheel and replace sheer key
Feb 23, 2014 | Troy Garden
MTD Snow Blower will NOT start up!
fuel float stuck --- need carburator repair -- to check it has spark then pull spark plug --- if wet blow off spark plug and check spark on plug then squirt a small fuel out of oil can into plug hole and put plug back in -- if engine fires on first pull carburator needs fixing -- check by squirting fuel in carburator with oil can and see if you can keep it running
Feb 23, 2014 | Garden
Went to start bp251 blower after sitting in shed for a week, pull string was very hard to pull. took off plug a lot of fuel came out of plug hole . also checked muffler screen,was clean. there was quite a...
Take plug out turn blower to where plug hole is down pull starter cord many times until all fuel is out. Clean plug, install, try starting without priming or choking. If no start try priming just until you get fuel to engine. Try starting again. If this works when storing blower leave fuel cap slightly loose in very hot weather until you want to start.
Aug 09, 2017 | ECHO, Inc. PB-251C Handheld Blower
Starter pull cord broke off
You can buy a new pull cord or start a any lawn an garden shop
Nov 09, 2009 | Craftsman 4 Cycle Blower/Vac
I can't get it started. It was my Uncle's who
Tips for starting gas powered garden tools.
1.) Drain old gas and replace with new gas.
2.) Make sure oil/gas mix ratio is correct 50 parts gas 1 part oil.
3.) Pull spark plug and replace with a new one or clean the old one.
4.) Pull start with full choke until engine turns over. Then take choke off.
5.) Pull to start.
It should be that easy. If it doesnt start your problems may require a repair shop.
Aug 27, 2009 | Echo Garden
Troy Built Snow blower won't start.
Cleaned out caruretor and blew out presumed dirt via compressed air. Thanks for your support.
Jun 20, 2009 | Agri-Fab Agri - Fab Snow Blower - 42"
Garden Logo
310 people viewed this question
Top Garden Experts
roeb
john h
Marvin
Marvin
