Question about Lands Phones
Panasonic TG8222E Please can you tell me how to pair my Panasonic TG8222E to the planatronics C 65 headset. I also can not find my remote access code for the remote answer machine. Many Thanks Sally
The Panasonic TG8222E is not a bluetooth capable device therefore it won't work with your Plantronics headset.
Have you checked underneath the base station for your remote access code?
Posted on Jul 13, 2008
I have no codes in my manual which came with my Jabra Style. Have even downloaded the pdf manual, still no codes. Can you tell me how I can use this app please?
Usually the Jabra headset connects via blue tooth. You pair it with a smart phone once. No codes other than the pairing number you see on the phone when starting the pairing process.
Feb 03, 2016 | Jabra Radio Communications
How do I geat the pass key for my device
You see, pairing codes for bluetooth headsets are hardcoded by their manufacturers. Please, take a look at these generic tips I posted a long time ago. Hope they might suit your needs, somehow.
Anyway, please, let me know if you need further informations. In this case, please, tell me both your headset and phone (or the other device you are trying to pair your headset with) models and makers.
Regards,
Carlos
Sep 11, 2012 | Jabra BT4051 Bluetooth Headset
What's the access code to activate bluetooth on laptop hp6530b?
If it asks for a code for the bluetooth it is the device pairing code, so if its a phone or something similar you enter the code on it and then on the PC.If its a headset or similar, the manual will tell you the pairing code for the item.
May 17, 2011 | Computers & Internet
I need the pass code ,I lost my info and I trying to put it on my new phone thanks.
Universally the default pairing code for headsets is 4 zeros(0000). It is this way because you usually need physical access to the headset in order to pair it with a phone(holding down the button or buttons to make it pair), and once someone else has your headset all bets are off anyway.
Try 0000.
I have also read that some plantonics setups do not always require a pin code.
Good Luck!
Mar 03, 2011 | Plantronics Explorer 220 Bluetooth Headset...
My problem is do not show music player & video player & don't work bluetooth headset
Hello there,
How are you accessing the Music Player? Can you tell me how? Please try to re-pair your headset as well.
Please also tell me if there are errors you are getting.
Nov 24, 2010 | Nokia 7610 Supernova Cell Phone
Unable to pair LG GM200 bluetooth 2.0 A2DP with Plantronics Pulsar 260. Error: "Request Failed" Please help in connecting this two devices
Each pair of BT enabled phone and headset is a particular world. I don't have the Plantronics, but my LG phone pairs fine with my Lubix stereo headsets. I'll tell you how I managed to pair them: I put my headsets in pairing mode. Then, on my phone, I go to 'Connectivity > Bluetooth > Device list > Options > New'. If my bluetooth stack is off I'm prompted to turn it on. It starts to search for devices, and comes up with my BT headsets' name, I press 'Pair', it prompts me for the pairing code. I enter '0000' (the same code for your Plantronics' headsets, by the way) and Ok. Then, back to the Device list, I select the BT headsets and go to 'Options > Connect'. I'm good to go. After listening to music, I use to go again to 'Connectivity > Bluetooth > Device list', select the headsets and press 'Options > Disconnect'.
Hope it works for you.
Cheers! Carlos
Apr 18, 2010 | LG GM200 Cell Phone
When getting paired tells me code is wrong...help
Correct. The pairing code is 0000. If you need instructions on how to pair, please let me know and i will be glad to assist you.
Mar 25, 2010 | Motorola Mobility H500 Wireless Headset
Cannot get my planatronic headset to work Plugged
Thank you for gettingf back to me, but after spending all day checking wires and plugs I went away annoyed, a friend came I told them the problem and they just got hold of the head set plugged it in and it worked, don't ask me why.
Feb 01, 2010 | Audio Players & Recorders
Pairing Sky+ Remote with Panasonic Viera remote
1. Press tv on your Sky remote control.
2. Press and hold down select and the red button together until the red light at the top of your Sky remote control flashes twice.
3. Press tv again
Then enter the remote control code using the number keypad. The red light will flash twice if a valid code has been entered.
Panasonic Code: 0051
4. Point your Sky remote control at your TV and press the Power button. If this turns the off as you'd expect, then the tv should be set, press Select and the remote should work
5. If the TV does not turn off press tv, then press the Power button again, repeat this process until the TV turns off, when the TV turns off press Select.
Dec 29, 2008 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Lands Phones Logo
239 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
