Samsung 45bn hi..got a problem with the samtron 45bn monitor. Initially, the screen turned yellow, then afterwards the screen went blank ie. black altogether... the monitor switches on alongwith the PC but remains blank..guess its a cable problem..plz help.. u replied that it is a cable problem... thanks for the reply..checked the cable and found it to be alright..guess the internal circuitry has locked or something as the light in the front panel is always on..how do i go about repairing now..
Hi... there's a resolution problm with samtron45Bn with win xp.
Pl.help to fix this pblm.
Posted on May 27, 2008
3 Suggested Answers
shaggyrat
  • 1224 Answers
SOURCE: problem with the samtron 45bn monitor
sounds like your video card went out simple check of this
if you have another computer that works hook it up to its computer if screen comes on it will be your video card in the comp now if the screen still doesnt work it will be the cable the pins in the end has some how bent or come loose this will require a service tech electrician to repair simple quick job
Posted on May 26, 2008
SOURCE: samtron 45bn problem
HI I AM SAMTRON 45BN COUSTUMER
MY PROBLAM IS MY MONITOR HAVE ON AND FEW MINUTE LED GLOW AND AUTOMATIC OFF
Posted on Dec 15, 2008
When I switch on my computer, Windows XP start loading and then my Samsung Samtron 45Bn monitor's screen goes blank and the green light keeps flashing every 0.5 secs.
It sounds like your video is set to the wrong resolution. Try booting into safe mode by pressing F12 at the start of the boot process. If you get into windows that way, then adjust the display to something you monitor can display like 1024x728@32bits. The monitor can only display a certain amount of pixels and if you set the video card to high you will lose visual. Hope this helps.
Mar 19, 2011 | SAMTRON 55V 15" CRT Monitor
To open the Samton 45Bn crt monitor
turn off power.
Get a long philips screw driver and remove the base and all fixing screws. some are hidden behind blanking plates and the com off with a sharp knife and a getle lifting at the join.
After all screws are removed the lie the screen downwards and start to pull away the backing.
you should get the case apart easily.
You must be aware of the tube holding a full charge at its end. DO NOT touch this at any point. The only thing you should try to inspect is the fuse or adjustment to the focus slant contrast etc.
AndystUK
Aug 30, 2009 | SAMTRON 55V 15" CRT Monitor
BLINKING OF SCREEN
check for Dry Soulders & FBT....
Jan 06, 2009 | SAMTRON 55V 15" CRT Monitor
EHT PROBLAM
EHT Problemsymptems :1.If U find R457 - 33k,R452 -1k,R458 - 10k Resisters are Burnt In Zenith 14"and15" monitors To replaced all thease resisters and LOT FSN14B016S
2.HCL HCM 482M, 580M,582M, 780M models getting FAT - FAT sound coms from LOT when u switch on the monitor It's LOT Problem . replaced it
3.Samtron Samsung Models like 45Bn, 55V,56V when u switched on the monitor Power indicator (Led )glow one time First u can check Boosting FET IRF630 bitween (SMPS O/P to LOT supply) and also replace LOT.
4.some Old Gold star anlog and LG monitors If U found 12k Resister near by LOT and also bulched 1Mfd/63V capacitor
It's LOT Problem
Oct 04, 2008 | Computers & Internet
Desktop screen is stretched abnormally
please trie and double check the resolution on the screen that its correct.
Also check so you dont use too much Hrz on the monitor/settings.
Jul 14, 2008 | SAMTRON 55V 15" CRT Monitor
Problem with the samtron 45bn monitor
May 25, 2008 | Computers & Internet
Samsung 45bn H output transistot over hating and burning out after a fewminits
THE MOST ECONOMICAL SURE FIRE FIX IS TO REPLACE YOUR MONITOR WITH A QUALITY LCD SCREEN IT UTLIZES 50% less electricty AND RUNs A LOT COOLER.
IF THE HORIZONTAL OUTPUT TRANSISTOR IS BAD MOST LIKEY THE POWER CONTROL BOARD IS GOING BAD you may also have a bad resistor or diode allowing to much current on power control board
Jan 16, 2008 | SAMTRON 55V 15" CRT Monitor
Computers & Internet Logo
487 people viewed this question
David Payne
David Payne
