Question about Cameras
Smasung D75 Digital Camera
I purchased my camera last year however last week it turned itself off and now when i try to switch it on, the music plays however the camera doesnt respond, all the batteries i have tried are fully charged...
  • saz194 May 22, 2008
    Thanks i had the batteries out for a few days, i tried ur solution even for an hour but its still not coming on ...
  • 1,142 Answers
Remove the battery first and leave it turned off for half hour reconnect the battery and that should reset the camera and it should work.
Posted on May 22, 2008
  • Maanita Chadha
    Maanita Chadha May 23, 2008
    try connecting the usb cable and with a new battery then try turning on the camera once you get anything on the screen try to format the internal memory it should work then and if still nogo then you would need a technician to have a look
I purchased a samsung ES70 compact digital camera last year and lately a black line has appeared across the bottom of the screen, could I get rid of it or would i have to purchase a new camera?
If the line is only on the display and not also on the photos when you download them to the pc, then you only need to have the LCD display replaced. The screen should cost like ~$20 as you can see here:
Mar 30, 2011 | Samsung Digimax S630 Digital Camera
When i want to take a icture on my d75 camera, it
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting its contents. The position nearest the contacts unlocks the card. If the slide is already in the proper position, try sliding it fully the other way and then back.
If that doesn't do it, try another card.
Feb 13, 2010 | Cameras
Hello, I purchased a finepix s5700 about 18 months ago. It has worked perfectly until the last few weeks. I can turn the camera on if I hold the playback button and switch on the power, and can scroll...
Your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera and give them a full charge (assuming that you are using rechargeable batteries). This cleaning clears the problem about 90% of the time. If it doesn't work for you, it may be time for new batteries, or the camera may have a problem that requires professional repair.
Dec 29, 2009 | Fuji FinePix S5700 Digital Camera
Olympus FE-230 Digital problem
Someone on here with the same problem mentioned that they shook the camera violently and it fixed the problem of it not focusing. I tried the same thing and actually gave it some light slaps on the tabletop. Well, now it works! I'm somewhat concerned that this fix won't last long.
Like many others' FE-230s, this camera began not focusing shortly after the one year warranty expired. I found my receipt and it turns out that I purchased the 2 year service plan at Best Buy and could get the camera replaced. But, now it works. Will it fail again after the 2 year plan expires? Jeez....
Jul 27, 2008 | Olympus FE-230 Digital Camera
P850 shuts itself off for no reason
Try using a liquid contact cleaner. I read about this fix on another site, worked great for me.
A product called DeoxIT in the U.S. is what was suggested, I am in Canada and can't get that here so I picked up a product from a company called NexxTech. Just a liquid contact cleaner.
Take out the battery of the camera. Put a few small drops of the contact cleaner on the power button and let it drip down into the switch. Rotate the on/off switch back and forth 5-10 times, put the battery back in and Voila! Fixed!
No more random on/off irritations, camera works just like it did before the problem arose a few weeks ago.
It worked great for me.
Good Luck!
Nov 28, 2007 | Kodak EasyShare P850 Digital Camera
Unable to turn on my Canon Powershot A95 camera.
Here are some simple things to try first for a camera that won't power on:
Nov 01, 2007 | Canon PowerShot A95 Digital Camera
C-8080 Turns off/on randomly..
Hi Galaxy,
Try running camera directly on DC from charger and see if it stays functioning.
If it does, they you either have:-
1) a faulty Lion battery
2) the battery detect circuit in the camera is faulty (reporting low battery and forcing shutdown)
3) the power switch on top of the camera may be leaky or partially collapsed
4) internal power supply circuit in camera has developed a fault.
Good luck...hope that the issue is the battery.
Jun 05, 2007 | Olympus Camedia C-8080 Wide Zoom Digital...
Cameras Logo
98 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
