Question about Video Game Consoles & Games
I have had my ps3 connected to my hdmi lcd but now when i connect via the scart plug on an older tv no picture appears how do i sort this
  • twamaster448 May 22, 2008
    thanks for the solutiion m8 works perfect
    Novelist:
  • 109 Answers
This is because your PS3's Display Output it set to HDMI, therefore the SCART isn't active. I believe the PS3 has a video reset. This should be how it's done:
1. Shutdown your PS3 if you haven't done this yet.
2. Press and hold the powerbutton. It should beep once for power on and shortly afterwards beep again.
You'll have picture on the other cables and the resolution is reset to 480p. You can change the settings now.
You'll probably have to do this again when you plug it in to your LCD with HDMI again.
I hope this helps, please don't forget to rate.
Greetings,
DarkNeogen.
Posted on May 22, 2008
  • Pascal Willemen
    Pascal Willemen May 22, 2008
    Glad I could help, thanks for the rating.
    Greetings,
    DarkNeogen.
When i connect my ps3 via the hdmi socket i get no picture, only sound when i use the ps3 controller. i have tried using the new scart lead and still nothing. i have gone through all the AV channels also....
You may have it set to scart video audio hdmi , instead of the scart try using the analogue video also , yellow connector on tv if it has it , also AV and scart aren't always the same on tvs search through the source option on the tv
Dec 01, 2014 | Sony SELECT KDF-E50A12U Rear Projection...
Scart signal
check the tv mode av1 av2 and pal settings
Sep 05, 2008 | Televison & Video
I am unable to get a picture on hdmi when i connect my ps3, but am able to get sound when i use ps3 controller. any ideas ?
Steps
  1. Step 1 Check for an HDMI port Check the back of your television for an HDMI port and refer to your owner's manual for your television's resolution. A resolution of 1080p offers the highest quality.
  2. Most PS3 systems support 1.3 HDMI, but older systems may need a software update from the 1.1 or 1.2 version.
  3. Step 2 Disconnect cables Disconnect all the cables and adapters from the back of your PS3, and then unplug your TV to reduce the risk of shock as you work.
  4. Step 3 Connect HDMI cable Connect the HDMI cable. Reconnect the power cables on both the TV and the PS3 system.
  5. Step 4 Hold power button Hold down the power button until the PS3 beeps and continue holding it for an additional five seconds until the system makes a second beep.
  6. The Playstation 3 should detect the high definition cable and automatically adjust the settings to give you the best picture and sound possible.
  7. Step 5 Test the connection Test the connection. If the HDMI cable isn't working, turn everything off and reconnect the original cables to manually change the settings.
  8. Step 6 Adjust the settings Turn the system back on, select Settings, Display Settings, Video Output Settings, and then HDMI. Repeat the process for your Audio Settings. You can now experience your games with the highest video and audio quality available.
Dec 01, 2014 | Sony KDF-E50A12U 50" LCD HDTV
Ps3-hdmi connection gets cut-off
Again check setting from the menu of your PS3.
Do select reset all factory settings....... Hope this will solve an error based on software. But if still problem persists, call your authorized technician for repairing, because there may be some loose contact with your PS3 or LCD TV.
Apr 20, 2009 | Warner Bros. Interactive Lego Batman
JVC LT-32DS75SJ issue with HDMI
Try this
1. Turn ON TV
2. Connect PS3 to TV HDMI input
3. select TV HDMI input for PS3
4. turn OFF PS3 if it is ON
5. Press and hold the [I/O]Power button until the PS3 until you get the "HDMI Detected" message.
Also, this TV has a circuit that deactivates the HDMI if the rear cover is removed. It is possible the HDMI may have been turned OFF. This is reset in the service menu of the TV.
Dec 17, 2008 | JVC LT-32X575 32 in. HD-Ready LCD...
PS3 hdmi connection
With your PS3 on standby (red light) hold the on/off button down until it goes green and then back to red. This restores your PS3 to "factory settings", i.e. it is waiting for you to tell it how you want it to connect to your TV. Now disconnect any HDMI cables you may be trying to use and connect your PS3 to your TV via a scart connection. Now switch your PS3 on and turn to your AV channel and you should have both sound and pictures.
Oct 24, 2008 | Sony Playstation 3 (PS3) Console
PS3 No picture or sound
When you connecting sony via hdmi sony and tv must be shut down.First turn on sony then tv.Connect also and av cable or scart then go to sony settings and change out signal via hdmi or scart or av cabel and confirm.That should work
Jun 25, 2008 | Sony Playstation 3 (PS3) Console
Problem
i have my picture going through the hdmi and the sound going through the scart. plug the scart into the back of the ps3. then the white and red wire are into my tecnics sound system and it works perfectly you just need to set it up in the sound options in your ps3. which is very easy. just select scart in the sound options. hope this helps you.
Dec 26, 2007 | Sony Playstation 3 (PS3) Console
Video Game Consoles & Games Logo
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
