No booting sir, my computer doesn't produce any outputs although all power connections are all right. at startup the beep sound is not heard although the cpu fan rotates. no o/p shows on screen .power to vdu, mouse, keyboard all right. sir,my pc turn on,but after boot my pc turn off.the fan is also dead and my screen is also dead.then i restart again then booting again then suddenly it turnoff again
  • 3 Answers
Use a voltage meter to determine if power supply is in deed failing. Check all your LED connections e.g. the LED lead goes from the power button to the board. Also make sure motherboard isn't being grounded out.
I seem the common problems you described as a power supply about to fail. Just like the car battery in your vehicle.
contact jackmctav@gmail.com for more discuss and results.
Posted on Jan 16, 2009
    Genius:
  • 2,785 Answers
Plz try with new power supply
Posted on May 22, 2008
Hp 2060 printer
Hmm, perhaps some small object, perhaps a paperclip, is caught inside, along the paper path
Dec 18, 2013 | HP Computers & Internet
Gateway wont startup. One beep followed by two short
I would suspect the power supply or a power connection. The only other issue might be a motherboard, which is a bit more involved. Try another power supply if you have one around.
Nov 12, 2013 | Gateway GT5678 Desktop PC
Computer beeping
that sound indicated that you RAM is broken, replace the Ram with new one
i hope this hope this helpful
Jun 13, 2013 | Computers & Internet
Memory upgrade on gx280 beeps on boot but doesn't start. memory beeps 1 234 5 6
When your computer emits beeps when you power on the computer, it's usually means that you have a memory issue. Try re-seating the memory modules and power on the computer. If you have more the one module, insert one at a time and power on the computer. The other issue is if that model supports 4 gig memory.
Aug 30, 2012 | Dell Computers & Internet
My acer veriton desk top is not booting up and giving a beep continues beep also moniter is not displyaing omething
This is likely a result of the computer not recognizing the monitor. During the POST test during startup,the computer will check for a video output. It can range from the video card failing to just not having the monitor plugged in. I would check you connections, perhaps try a different monitor, even a television that has either HDMI, DVI, or VGA input. If that does not fix it, it is likely your graphics card or on board graphics from the motherboard. Is there anything new since the last time the computer worked? How old is your PC?
Jul 10, 2012 | Computers & Internet
Hello, i have an IBM net vista PC which is using 4 RIMM memory modules of 256Mb each, i removed one of them and later returned in position but from then henceforth my computer cant boot,instead its...
The IBM beep code indicates no power, loose card, or short. Was the computer unplugged when you removed the module? The first thing I would do is remove all modules, blow out any dust in the memory slots, and reinsert all. While you are in there insure any cards, sound, video, are firmly seated.
May 23, 2011 | IBM NetVista PC Desktop
Does not boot up, fans start, internet plugs light, clicks on and off.....seems this is a common problem for these machines, what is the fix?
Instructions
  1. When you press the Power button to start the boot process, the LED lights glow while the computer verifies that there is sufficient electrical power to activate the hardware.
    Effect & Solution: When you press the power button, the LED lights on the computer do not glow or the LEDs blink briefly and then stop. There is no sound of the fan or hard drive spinning, and the screen remains blank. The computer will not start if there is insufficient battery or AC adapter power.
  2. The BIOS queries various hardware components used for the startup boot process.
    Effect & Solution: When you press the power button, the LEDs glow but there is no fan or hard drive sound. The LEDs may glow briefly and then go out.
    Or
    The LED lights blink, stop, and then blink a second or third time, but there is no sound from the computer and the screen remains blank. The sequence of the blinking lights indicates a specific error code.
    Or
    A series of beeping tones is heard. The sequence of beeping tones indicate a specific error code.
    If a hardware component has recently been replaced, or if the PC has been jarred or shaken, there may be a loose connection to the memory chips or hard drive which prevents the computer from starting.
  3. The BIOS loads the basic input (keyboard) and output (advanced LEDs / display screen / boot drives) devices into memory.
    Effect & Solution: When you press the power button, the LEDs glow, the fan or hard drive sounds, are heard, but then the boot process stops and a black screen - with an error message - displays.
    The boot check has detected a communication error or conflict with a hardware component that must be corrected.
  4. The BIOS loads the Windows operating system and starts the services that allow low-level control of all of the background operations.
    Effect & Solution: When you press the power button, the LEDs glow, the fan or hard drive sounds, are heard, the HP or Compaq Logo displays on a black screen, but then the boot process stops and a blue screen - with an error message - displays.
    The boot check has detected a hardware driver error or a software conflict that must be corrected.
  5. Control is transferred to the Windows loader to initiate the display of the advanced settings in the Windows environment.
    The Windows logo displays during this step.
    Effect & Solution: When you press the power button, the computer performs all the steps in the boot process, but after the Windows Logo displays, the moving Windows progress bar or the rotating cursor stops moving and the boot process stops.
    An error message may display on a screen with the Windows logo. In some instances, there is no specific error message.
    Or
    A black screen appears and the computer attempts to restart.
    The Windows self-check has detected a software conflict that must be corrected.
Jan 09, 2011 | Gateway GT4016 Desktop PC
One beep at startup - System does not bootup
You have what sounds like a RAM problem. Try known good RAM as a test. If it still fails, remove add on cards except video. Make sure that video card works. If it still fails to boot. Replace motherboard.
Jun 01, 2009 | E-Machines eMachines Desktop PC
IX PACIUP4240 15'' LCD, No POST or boot
The error message "CABLE NO INSERT" refers to the lack of video signal to the LCD. To fix it you have to use a short VGA cable that connects VGA output of motherboard to VGA input of LCD. Only then you are going to see video output on LCD screen. Your other option is to connect external monitor to VGA output on motherboard. Either way you are going to see motherboard's video.
Oct 16, 2007 | R.A.M. Computers IX PACIUP4240 15'' LCD TV...
Computers & Internet Logo
136 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
