Question about JVC AV-48WP74 48" Rear Projection HDTV-Ready Television
Jvc av-48wp74 the convergence has a downward green curve when I removed chaisse drawer Inoticed that the green tubes cooling system leaked out the ruber poutch on the unit was empty ?what to do to rep
  1. jvc av48wp74 I have a green downward curve on the screen iremoved the chassis drawer and noticed the cooling liquied had leaked out of the green crt ????what to do to repair ?? do I need a new C.R.T?????
  • 2,322 Answers
Check the info from this website in regards to the leaky CRT you got.
If the coolant liquid spread over any board, I would suggest to clean it throughout using a paint brush and rubbing alcohol.
Good Luck.
Posted on May 22, 2008
JVC AV-48WP74 convergence
The ICs are most likely defective if the old ones allow the set to power up.
Nov 20, 2009 | JVC AV-48WP74 48" Rear Projection...
Panasonic pt-51hx41e
This is a convergence output IC problem. convergence board (main Board) would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually charge between $200-$300
Sep 26, 2009 | JVC AV-48WP74 48" Rear Projection...
JVC AV-48WP74 BLUE CONVERGENCE ADJUSTMENT PROBLEM
Make sure you bought genuine Sanyo chips...if not goto www.TvRepairKits.com and get theirs.
Aug 05, 2009 | JVC AV-48WP74 48" Rear Projection...
Jvc AV-48WP74 i no its a convergen issue but..
you can get the convergence repair kit at the following link which usually fixes that issue. The kit contains the parts and detailed instructions on CD of how to do the repair.
http://www.tvrepairkits.net/
Jul 07, 2009 | JVC AV-48WP74 48" Rear Projection...
Need wire diagram jvc av-48wp74
http://www.nodevice.com/manual/newmans/jvcupdate/AV-48WP74PDFpdf/get52302.html#
That should have everything you need.
Feb 05, 2009 | JVC AV-48WP74 48" Rear Projection...
JVC AV-48WP74 48 in
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Sony Convergence
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
Jan 24, 2008 | JVC AV-48WP74 48" Rear Projection...
Red Convergence on JVC AV- 65WP74
have pts rebuild the board which will cost around $130, www.ptscorp.com, or replace the stk392-110 x 2 located on the convergence panel.
Dec 08, 2007 | JVC AV-48WP74 48" Rear Projection...
Green tube not converging properly
Replace both convergence IC's.....STK392-110 X 2........T.
Nov 15, 2007 | JVC AV-48WP74 48" Rear Projection...
JVC 48WP74 HDTC rear projection
While it is true JVC tubes rarely fail, they can give trouble.
Another possible solution is bad screen / focus block......
Remove lower front grill panel and access board...Check for
smooth adjustment of RGB screen and focus.....let me know....T..
Sep 28, 2007 | JVC AV-48WP74 48" Rear Projection...
JVC MODEL # AV-48WP74 48 IN. BIGSCREEN TV.
I had a problem with my TV colors not lining up. One day I turned it on and the green was out of wack. I checked this message board and replaced the STK chips, bad soldering and all led to me just giving up on that and buying a whole new Convergence Board ($185). I just plugged this in and though now my Green lines up okay, my red is out of whack. Is there something I am doing wrong? Can anyone help me? Did i miss a step? Frustrated......Bruce
Jul 29, 2007 | JVC AV-48WP74 48" Rear Projection...
JVC AV-48WP74 48" Rear Projection HDTV-Ready Television Logo
61 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
