Question about Niles ZR-4630 2 Channels Receiver
Niles ZR-4630 yes I did bt now I checked the fuses and they look fine
  • rmashao May 22, 2008
    not yet sorted out..can we pls try some
    President:
  • 1,944 Answers
Thanks for the update. Did you try power cycling the unit?
Posted on May 22, 2008
Is there anywhere/anyone that repairs these units?
hi customer service 1-800-BUY-HIFI- (289-4434) outside us call (760) 710-0992.......techsupport@nilesaudio.com.,.........cheers
Dec 20, 2015 | Niles ZR-6
COMO CONECTAR DOS AMPLIFICADORES
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Sep 13, 2014 | Niles Audio Niles Si-2125 2-channel...
Mg zr common faults
Bad cabling.
You need to check earth for the motor.
If you are getting bad earth then it will overload the fuse.
Jul 11, 2014 | 2005 MG ZR
Reverse light not working
have you checked reverse back up switch for bad switch or bad contacts/corrosion/bad or shorted wiring
Dec 20, 2013 | Cars & Trucks
None of the scientific atlanta codes work to program remote. tried to find the code, still no luck. Any ideas?
To which device do you want setup codes with this remote control? Provide more details please. If you wish to get code list for Scientific Atlanta remote control, check this link.
Feb 23, 2013 | Niles Audio Niles R8L FG01446 8 Source...
Niles ZR-6
I had the same issue as Brian, the Niles ZR8630 stays in initializing mode. At first, the unit would not turn on, so opened it and replaced the fuse, power was restored. But now the unit continually stays in INIT mode.
any body has an answer/solution?
Jul 30, 2012 | Niles ZR-6
I have a kawasaki zr 750 h1, i start it up fine but 10 mins down the road she splutters and stalls ( yes she does have petrol!) any ideas on what could be wrong?
Sounds like a malfunction vacuum petcock. Possibly just a cracked or leaking vacuum line operating the vacuum diaphragm. With the choke on there is enough vacuum to operate the petcock , but as it warms up the reduced flow from the partially closed petcock feeder line causes you to run out of gas when trying to drive at speed. Check the vacuum line for damage and replace if necessary. Check the fuel petcock for internal damage. If vacuum diaphragm is cracked or has a pinhole replace the petcock assembly about $75)(K&L may have a rebuild kit about $30).
Jun 30, 2011 | 2002 kawasaki ZR-7
Niles audio zr-4630 powers on then shows error code e1
Power cycling?!?!? Are you serious?!?!? Do you work in tech support?? Power cycling , what a genius.
Feb 02, 2011 | Niles ZR-4630 2 Channels Receiver
Niles ZR-4630 2 Channels Receiver Logo
429 people viewed this question
Top Niles Audio Players & Recorders Experts
 Grubhead
Grubhead
Joseph Hoffmann
Jeff Tilburn
Jeff Tilburn
Are you a Niles Audio Player and Recorder Expert? Answer questions, earn points and help others
