Question about Kodak EasyShare C613 Digital Camera
Kodak camera bad battery life
When i put new batterys in, it runs out of battery and turns off within 5 mins. i tried kodak batterys and they only lasted a day, what is wrong?
    Problem Solver:
  • 13 Answers
Okay, first of all, KODAK batteries are a waste of money. And second of all, make sure that you aren't using rechargeable batteries. And if you checked those, bring those batteries back to the store bub, because those are some lousy 5% charged from the factory.
Posted on Jul 15, 2008
Kodak M863 charge ok checked battery is charged and tried new battery. Within one day battery is flat.
Go into settings, close wi fi and blue tooth. change screen brightness , change time on screen shut down.
Oct 29, 2014 | Kodak EasyShare M863 Digital Camera
Kokak eassyshare z812is drains new battery in 5 miutes & makes a humming noise
The humming is probably your image stabilizer, and may be normal. Try turning it off in your camera's menus to see if that improves battery life. If it does, you may need to consider higher power lithium batteries if you wish to continue use of the image stabilization feature.
Dec 16, 2011 | Kodak EASYSHARE M1063 Digital Camera
My camera has new batteries and I cleaned the posts and tryed to turn on. It will not come on.
If your Kodak camera is not turning on, the answer to your problem is probably the batteries. But what I am wondering is what you said, QUOTE "I CLEANED THE POSTS" END QUOTE, if you used a WET soft towel you have water damage. To reverse the effects of water damage, remove batteries and take a blow dryer and blow it down and around the camera for a good 10 mins, first 5 low setting, 2nd 5 high setting. Let it sit in RICE for a good 5 days (typical business week) if not rice in a clothes drawer for a good 5 days also. Thanks!
Jun 27, 2011 | Kodak EasyShare C633 Digital Camera
Camera won't turn on using recommended KLIC-8000 battery
It is possible they sold you a faulty battery pack. .
Contact them and explain your problem; they should replace it at no cost to you
-a.
May 13, 2010 | Kodak EasyShare Z712 Digital Camera
I just put new batteries in my kodak easyshare c913 but will not turn on
Make sure you are using rechargable batteries. Normal batteries are not strong enough. Try using either rechargable Lithium Ion batteries, or rechargable Nickel Metal Hydride (NiMH) batteries. These are much stronger and should give you a good battery life.
Let me know if this helps :)
Feb 27, 2010 | Kodak EasyShare C913 Digital Camera
Hello
Here are the steps: 1. Make sure you will install a new or fully charged battery/batteries into your camera. 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Without the memory card, turn your camera on. 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a No power repair or a new cable.
Jan 02, 2010 | Kodak EASYSHARE M1063 Digital Camera
Put new batteries in but there still is no power
Check if your using the recomended batteries for this camera Easyshare C613. The batteries are 2AA Ni-MH batteries, 2 AA Lithium batteries or 2 AA Alkaline batteries. If your use this kind of batteries and they are new out from the box try this steps.
1. Remove the memory card and the battery on the camera
2. Clean the both battery contacts with clean dry cloth
3. Put the battery back in the camera in correctly
4. Set the camera in Auto "it's the camera icon on the dial of the camera."
5. Turn it on
*If it turns ON take photos and review them check if it will stay on
*If it doesn't turn ON or stay ON contact Kodak support line @ 1-800-235-6325 (23KODAK). You can also try to log on to www.kodak.com/go/stepbystep.
Nov 16, 2009 | Kodak EasyShare C613 Digital Camera
Kodak Z1085 IS - drains battery even when camera is not on
the camera takes 1.5v to operate it
anything less the camera will shut down
recharge batteries are only 1.4v so at full
recharge it won't last long
The best batteries are litheum that have the right
volts and capacity to keep the camera going.
try turning or the camera stablizer setting...
might save your battery power.
Mar 17, 2009 | Kodak EASYSHARE Z1085 IS Digital Camera
Turns on then automatically shuts of
FIRST CHARGE YOUR BATTERY OVERNIGHT AND THEN REMOVE YOUR BATTERY FOR ABOUT 10 MINS PUT BATTERY BACK YOU HAVE TO ADJUST THE DATE AND TIME AFTER DATE EVERYTHING WILL BE OK BUT IF YOU ARE USING 9 OR HIGHER MEGAPIXEL YOUR BATTERY WILL BE DRAIN IN THREE TO FOUR HOURS.
Dec 12, 2008 | Kodak EASYSHARE V1253 Digital Camera
Batteries are going dead within 5 min
What type of rechargables are you using? Ni-Cad are reputed to have a 'memory' so that if recharged whilst not fully run down this is accumulated so that only the new bit of charge is 'active'. So-put the batteries in a torch and leave it on until the batteries are completely flat, then recharge. And/or get a couple of sets of Ni-Mah rechargeable and a suitable charger and start afresh.
Apr 27, 2007 | Fuji FinePix 3800 Digital Camera
Kodak EasyShare C613 Digital Camera Logo
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
