Faulty Enermax Liberty ELT620AWT
My PSU will not power up. When AC is applied the fan starts to turn for about 0.5 sec then stops and I have no o/p on any rail. The +5VSB is present. I think theat U7 (PS223 monitoring IC) is faulty preventing the PSU froms starting but cannot verify this nor locate a suitable replacement
  • 14 more comments
  • Dave May 22, 2008
    I have tried to power up PSU connected to my MoBo etc, with no load, and with a light loade (2 old HDD). It used to power up and run perfectly if I manually pulled pin 16 of the AXT 24 pin connector (PS_ON) to ground but it no longer does this. That's why I suspect the PS223 IC as this is where pin 16 goes to. I have verified that the AC is getting to pcb, the firts stage rectifier also appears to work as I get the HV DC. Without a cct diagram though I am poking in the dark somewhat.
  • Dave May 22, 2008
    Thanks. I already have the PS223 datasheet.
    The PS223 pin votlages are as follows
    PIN - SIG - Voltage
    1 PGI - 0
    2 GND - 0
    3 FPO/ - 1.15VDC
    4 PSON/ - 0
    5 IS12A - 0
    6 RI - 0.72VDC
    7 IS12B - 0
    8 VS12B - 0
    9 OTP - 0.2VDC
    10 IS5 - 0
    11 IS33 - 0
    12 VS12A - 0
    13 VS33 - 0
    14 VS5 - 0
    15 VCC - 5.19VDC
    16 PGO - 0
    A simple ohm measurement across the various o/p donot reveal any hard shorts. These are the measurements I am getting WRT GND.
    +3.3VDC (orange) - 16 ohms
    +5VDC (red) - 30 ohms
    +12VDC (yellow) - 75 ohms
    -12VDC (Blue) - 1.5K
    PWR_OK (Grey) 10K
    PWR_ON (Green) 20K
    +5VSB (Purple) 450 ohms
  • Dave May 22, 2008
    Pin 4 of PS223 is connected to pin 16 of the 24 pin connector via a 1K resistor so pulling pin 16 low will not have any effect as pin 4 of the PS223 is already at 0VDC. None of the other voltages change either
  • Dave May 22, 2008
    With AC ON and PSU in OFF state the pin 4 of PS223 is 0Vdc isolated from all other circuitry. Pin 4 measures 20K WRT to Vcc pin 15 and a20k WRT GND pin 2
    If I trigger pin 4 with 5VDC the PSU momentarily energises then stops - same effect as if I power on from cold.
    I am confused as to how this chip stops the PSU from starting... There are 2 outputs which I assumed were used to enable the PSU however tracing pin 3 FPO/, It goes via a 750R resister to VCC - The ref cct on data sheet shows it with a LED and resistor to vcc. I conclude that this is a "visual" fault indicator in the ref cct. The other is pin 16 PGO witch goes direct to pin 8 of the ATX connector. Neither seem to in any way control the PSU? I am confused but since pin 4 is not correct voltage (+5V) when floating, and pin 3 is low (1.15V) which I think is FAULT conditiion and pin 16 is low (0v) which I think is "power OK" condition. I conclude that the PS223 is in fact faulty. Can you at least clarify how the PS223 enables the PSU
  • Dave May 22, 2008
    I must admit I have been thinking that too... I was going to disconnect pin 3 and/or 16 to see if it allowed the PSU to run.
  • Dave May 22, 2008
    ok I decided on disconnecting pin 3 of the PS223. I desoldered the 750R and let pin 3 float. Applying AC the PSU immediately came to life ans powered the 2 xHDD and 2X CDROM I was using as load. Checking all rails they all appear OK.
    Checking the PS223 pins in this state...
    PIN - SIG - Voltage
    1 PGI - 1.88vdc
    2 GND - 0
    3 FPO/ - 0.48VDC
    4 PSON/ - 0
    5 IS12A - 12vdc
    6 RI - 0.72VDC
    7 IS12B - 11.82vdc
    8 VS12B - 12.16vdc
    9 OTP - 0.27VDC
    10 IS5 - 4.85vdc
    11 IS33 - 0.73
    12 VS12A - 12.15vdc
    13 VS33 - 2.51vdc
    14 VS5 - 5.12vdc
    15 VCC - 5.19VDC
    16 PGO - 5.0vdc
    The other side of the 750R is still +5vdc.
    This means pin 4 is shorted to ground intrenally as it should be pulled HI by the 20K internal resistor. I am not sure if the FPO/ o/p is being driven low of if it is in a failed state internally???
    Also the voltages on pin 11 IS33 (0.73vdc) and on pin VS33 (2.51vdc) seem low compared to the other rail inputs.
  • Dave May 22, 2008
    Yes the PSU now fires up immediately I apply AC. No not ideal for use... Yet. I intend on fixing it completely. I may have located a supplier of the PS223 chip so hopefully I will have a spare within a week from OS. My concern now focuses on the signal levels on pins 11 and 13. Are they wrong or OK? Are they the reason the PSU is disabled? Are they low because the PS223 is loading those lines? I'll disconnect them tomorrow and post back as it's almost midnite here is OZ
  • Dave May 23, 2008
    Having disconnected pins 11 and 13 individually and together, it seems to me that the +ve comparator input pin 11 is connected internally to pin 13 (not a hard short though) causing the internal logic to detect a "fault" driving pin 3 (PFO/) low disabling the PSU. This in addition to pin 4 PS_ON/ being internally pulled to 0V instead of +5V maakes for a very unhealthy PS223 I.C.
    Heres hoping I can get a new one soon.
  • Dave May 24, 2008
    Wonering if you can point me in the direction of a similar IC that could be implemented to replace the PS223 which seems impossible to find. I am capable of moding the board, building a pigyback pcb or what ever is required. I dont want to build a functional replacemet from scratch if I can avoid it.
  • Dave May 24, 2008
    Thanks. I'll look at the options you have suggested
  • Dave Jun 30, 2008
    I have managed to locate a PS223 IC so hopefully I will have it soon to install and test
  • Dave Jun 30, 2008
    I dont remember rating anything?? How do I review the rating?
  • Dave Jun 30, 2008
    there is no option to change the rating
  • Dave Jul 09, 2008
    The PS223 I was hoping to get fell thru but I have discovered that the Fairchild SG6520 is a pin for pin and functional replacement. On order from Mouser Electronics in the USA so will have Ic in a couple weeks.
  • Dave Jul 24, 2008
    I have installed the new IC and on the bench, the PSU turns on but when installed in the 'old' PC with the GA-K8NF9 it will not unless I manually short pin 16 to ground...
    The weird thing is that the PSU works just fine in my new rig with the GA-EP35DS3R powers on/off as expeced.
    Even weirder is that the other PSU works just fine in both the 'old' and 'new' PC's...
  • Dave Sep 08, 2008
    the Fairchild SG6520 works just fine
    Brigadier General:
  • 6,966 Answers
Are you checking the voltage outputs of the PSU with it connected to a motherboard or standalone? Most designs will not power up if there is excessive load (as in a short/high current), however, there are also designs that will not power up if there is no load.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on May 22, 2008
  • 11 more comments
  • Louie  Role
    Louie Role May 22, 2008
    Perhaps there is a way you can verify if the PS223 is working, pls reference this spec sheet. There is a typical application schematic diagram which may be of information. Additionally, typical pin voltage readings may be gleamed from the said document.
  • Louie  Role
    I understand the need for the schematic, but of course Enermax wouldn't be publishing this for reasons we both know hence my suggestion of winging it from the schematic of the data sheet.
    pls check if pin 4 of PS223 would change from 0 to ~5 when you pull the PSU's connector pin 16 to ground (POWON); pls also check if there is a similar change in pins 3 & 10 (again of the PS223) from 1.15 & 0 respectively to 0/~5 & ~5.
    would appreciate update on results of voltage readings.
  • Louie  Role
    pin 4 of PS223 and therefore pin 16 of the connector should have an initial ~5VDC if AC mains is supplied. The 5VDC exists since as you posted pin 15 Vcc of the IC reads 5.19. Internally, there is a 20K resistor from the Vcc supply towards pin 4 (PSON) of the PS223 and therefore should read high at PSU OFF. Triggering the PSU to Power On/Start as you posted is grounding pin 16 of the connector which in effect brings down pin 4 of the PS223 which if you would reference the Data Sheet's Timing Chart, you would notice that PSON low is equal to PSON/turn on.
    Suggestion to see if the problem is internal to the PS223 or external to it. Float pin 4 by desoldering it or removing all components attached to it such as the 1K resistor. With AC in/PSU off, pin 4 should read high. Thereafter, grounding it should trigger your fan/PSUON.
    If it still reads low @ AC in/PSU off (floated and no components) then you have a no triggering PS223; defective.
    Which brings to the next possible concern, where to purchase a new PS223. They are not readily available as the LM series of regulator/monitors. And I am not aware of a substitute.
  • Louie  Role
    I am tempted to think that the PS223 is not meant to kick start the PSU but rather to prevent it from running based on any number of faults. As the name/description implies, it is there to monitor and shutdown the PSU in the event of over current or over temperature.
    Which leads me to suggest, try running the PSU without the PS223.
  • Louie  Role
    Re your query :...Can you at least clarify how the PS223 enables the PSU..." I don't think it enables but rather, it disables the PSU. All SMPS has an inverter/chopper and some sort of controller. The output of the PS223 could be wired to trigger the controller to OFF if in its monitoring it detects a fault.
  • Louie  Role
    ahhh, of course, pins 3 & 16 are the only outputs....
  • Louie  Role
    Did I understand you right, the PSU powered itself ON when AC was applied? If yes, then the PS223 is acting as the inverter/chopper controller and not only as a trigger/source. In effect the PSU operates like the old ATs utilizing mechanical switching of the AC for power on/off.
    I think any erroneous voltage/logic state at any of the inputs of the PS223 will not have any effect. Though am afraid with todays MB, WOL, hibernate/sleep and others, the PSU will no longer be appropriate.
  • Louie  Role
    Louie Role May 24, 2008
    The closest I could think of is a Motorola or Texas Instrument TL494 control IC. Data sheets are here and here respectively. An application diagram (for a lower wattage) maybe found here. It is very possible that you may have to use 2 of the TL494 to simulate the 4 channel capability of the PL223. Additionally the outputs of the 2 TL494 will have to pass through a dual OR gate.
  • Louie  Role
    Louie Role Jun 30, 2008
    and hello again,
    Appreciate the update and will look forward to any new development(s) if and when.
    A favor if I may ask, would you be so kind as to re-valuate the rating you gave me? Perhaps unknown to you, the "Thanks for Trying" actually brought my ratings down which is already a challenge as it is to attain and maintain. Hope you understand.
    Thanks much and good luck again.
  • Louie  Role
    Thanks for taking the time. Below my last response would be:
    "Was this solution helpful? Show your Appreciation by rating it:"
    Thereafter a selection of:
    Inappropriate Thanks for Trying Helpful FixYa!
    The first two (2) would give me a negative mark while the last two would improve my ratings.
  • Louie  Role
    Copy that, thanks anyway. No prob.
    Again will look forward hearing from you soon as the new PS223 IC is available and you have repaired the PSU. Lots of luck.
  • Louie  Role
    Louie Role Jul 09, 2008
    Thats great, the SG6520 would be relatively easier t get.
    Thanks for the update.
    Goodluck and would look forward how it goes.
    Cheers.
  • Louie  Role
    Louie Role Sep 08, 2008
    Appreciate sharing the findings. Am sure a lot of techs would benefit.
    Cheers.
My computer starts and then automatically stops after a clicking or ticking sound all my power cables will work but nothing appears on the screen and my fan stops working?help me out please?
I m no expert but it sounds like you need a new motherboard or at least your PSU. I had a similar problem and used the opportunity to have my techo genius up grade the mother board and a fresh PSU and upgraded to windows7 and everything works like a dream and much more power!!!!!
Jan 15, 2012 | Intel Computers & Internet
When is the power supply fan supposed to come on?
as soon as the PSU is turned on the fan should start if it doent the PSU is faulty
Dec 15, 2011 | Dell (PS-5251-2D) (PS52512D300WB) 300-Watt...
When i apply power, the cpu fan and power supply fan turn a few times then they stop and restart. This cycle continues for about ten minutes then the OS loads and runs fine. This happens every time I turn...
That means the PSU( power supply unit ) is already malfunctioning. Try to use a spare PSU and try that if that happens again.
Hope that helps you out!
Aug 09, 2011 | Intel DH55TC Motherboard
My pc was working properly when I turned it off. Upon returning I powered up my pc (HP 805n) but it will not turn on. The green light in the back of the pc is steady, but no response. I've own the pc...
to trouble shoot,
open case and disconnect all cables except power supply.
if the computer starts up okay, then shut down and connect the cd-rom then startup. if that's okay then connect any other cables . if any one of the parts are defective you will find the stinker.
if the computer still won't go, try another power supply/
if that's okay, then the board might be bad
Aug 03, 2017 | HP Pavilion a805n (PS519AA) PC Desktop
My psu will not stop beeping. I have an enermax EIN 720 AWT
the beeps are post during post the very first work is done by the ram,all the memory in the ram is first transferred to the hard disk,and remains active untill turned off.
make sure that your RAM is securely seated
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them they could be faulty
a computer needs its connections to continue its cycle and to have and end to function
obvisously the beeps are windows searching for some hardware it could be RAM cd/dvd hard drive or motherboard all of these must have secure connections for the computer to work
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure make sure the connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error
hope this helps
Jun 08, 2011 | Enermax EIN720AWT 720-Watt Power Supply
Both fans stopped working which overheats the PSU. Can this perhaps be a fuse?
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
Jan 17, 2011 | Enermax Noisetaker EG425P-VE...
Computer will not boot, When power point is switched on, after two seconds the CPU and PSU fans both start turning, the three LEDs on the key board flash and the power on LED at the front of the case...
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a hard drive
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps
Jan 12, 2011 | Intel D945GTP Motherboard
How do I test my power supply unit? iw-p300a2-0 When power button is pushed ccase fans turn on for split second then machine shuts off again
If your PSU is plugged in to the computer, this could mean that there is an overload condition on your computer.
If you have it unplugged and it shuts down when you turn it on, PSU is faulty, generally the components that fail are small electrolytic capacitors.
Easiest way to test is to plug it in to another computer if you have access to one.
Jan 03, 2010 | In Win (IW-P300A2-0) 300-Watt Power Supply
Hi, I have a problem with my Enermax Blue Viper CS-718-B, bought in 2006. When pressing the start button, the light and fan are working very short, or I get a peep, but the computer is not booting. Only if...
Your computer either has a fault with the power button in which you can request off the manufacturer a replacement (may cost money depends on warranty) or you do not have enough power for the computer components. Try removing all the peripherals except from screen, keyboard and mouse and then try booting. If it works then you dont have a large enough power supply for all the equipment you have. If it still does not work then it could still be a power supply (PSU) fault in which you can take the psu to your local computer store and they can test it for you.
hope this helps
Oct 08, 2009 | Enermax (CSXSEG718SNP) ATX Full Tower Case
Psu shut down
99% TIME IT IS A FAULTY FAN GOING OUT.
REPLACING THE FAN INSIDE THE POWER SUPPLY WILL RESOLVE THE PROBLEM.
P/S ARE CHEAP, JUST BUY A NEW ONE OOR REPLACE WITH ONE YOU HAVE ON HAND
CANDYMANGANDY
Jan 27, 2009 | Antec Solution SL400 Power Supply
Computers & Internet Logo
460 people viewed this question
David Payne
David Payne
