Question about Motorola Mobility A1200
How do I format the SD card?
IPAQ rz 1710, how do I format sd card?
  • 32 Answers
If you plug it into your computer and go to "My Computer", you should see your SD card listed. Click on it and then go to File, and then format.
If that option (format) is not listed, then you could just select all of the files and your card and delete them.
Posted on Jun 01, 2008
My hp rz 1710 dont recognize sd card 4 gb
reasons for the problems u faced
1.system doesnot provide drive letter for ur sd card
solution:
1.Click Start, click Run, type compmgmt.msc, and then click OK. 2. In the console tree, click Disk Management. The Disk Management window will appear
3.On this disk management window, you can see some drives including the portable drive. Right click on your portable drive and click change drive letter and paths.
4. Now a assign a new drive letter which is not being used by any of your drives in My Computer.
5. After assigning the new drive letter your portable drive will show up in my computer with other drives
another way to solve
After plugging in the device. Go to device manager (In run type "devmgmt.msc") In Device manager go to "Universal serial bus
controllers" It should list the storage devices that you have connected to your PC. Right click and then click "Uninstall. Remove
the USB drive and restart your system.
Try connecting the device again, i think this should solve the problem.
May 15, 2010 | Computers & Internet
Looking for a manual for a HP iPAQ rz 1710 Pocket PC
Look here, and download the user manual you need.
Cheers! Carlos
Apr 30, 2010 | HP iPAQ RZ1710 Pocket PC
probably ur sd card is virus infected download usb virus scan utility to clean usb related viruses u can find it easily on net.
Mar 30, 2010 | Computers & Internet
PLEASE GUYS HOW CAN I CNNECT MY IPAQ RZ 1710
LOOKS LIKE I'M NOT THE ONLY ONE WITH A BROKEN CAPS LOCK KEY. Seriously, if you want answers and support, you don't have to write in capital letters, we will still see your problem regardless. But, as the person above said, you need a network card. If I'm correct, you need an SD wireless card. These simply fit into the SD card slot and allow you to have wireless internet. I'm hoping that this information is correct as I am a little hazy on the topic at hand, so don't blame me if I'm wrong. Hope this helps. = )
Mar 09, 2009 | HP iPAQ RZ1710 Pocket PC
IPAQ 6515 doesn't recognize new HP 8Gig SD card
Your 8 Gig card is a SDHC (HC=High Capacity) Card. All HC cards use a different format, which the 6515 can't use...
The biggest capacity the 6515 can use is 4 gig on the SD and 2 gig on the mini SD.
My 4g Transcend card and 2g Sandisk cards have been faultless for about 2 years now.
Sorry, but the 8 gig card is a wonderfull card, but is useless in a 6515
Dec 13, 2008 | HP iPAQ hw6515 Pocket PC
HP ipaq with navtec gps software and sd card fails
Ok, nice job Robert,
I'm posting your solution here to remove it from the unsolved problems list.
Solution by Robert:
This problem was finally resolved as a corrupted map file on the SD memory card in the hp ipaq 5550. Solution was to reformat the memory card using fat32 memory format. I used a SD memory card slot on my laptop and right click the drive letter and select format to format the memory card. After that, I reloaded map files to the memory card and all was OK. Note that previously I had loaded map files on the memory card successfully but that was not good enough. A reformat of the memory card was apparently needed.
I had also previously tried a hard full reset of the ipaq by pressing and holding the lower two buttons (calendar and itask) while holding in the reset button with the stylus for 5 seconds and resynced my contacts and reloaded the gps software, but this was to no avail. Try the re-format.
Jun 22, 2008 | HP iPAQ H5550 Pocket PC
Ipaq 2400 series will not recognize Compact Flash card
Hello :-) I have a HP Ipaq 4350 and something similar like this happened to me. Except when I tried to take out the SD and put it in again the screen would go different colors and I would have to reset. But sometimes the SD will not get read because of the way you in and outsert  it. Do you push down on the SD card and it will pop automatically or do you pull out the SD card. Because if you pull it out that might be your problem because if you DO pull it out it can damage the metals that read the SD card. Now If you do pull it out  I'd recommend for you to insert the card and then pop it out and reset your device. If you do not pull it out you should go into the finder app on your Ipaq and see if that finder finds you SD card. If it does that means that your program is the problem and that its not fully compatible with your ppc or your specific SD card. Im sorry if this doesn't resolve your problem.
Dec 31, 2007 | HP iPAQ H2210 Pocket PC
HP IPAQ RZ 1710
try to connect to ur PDA harddrive where u have uploaded those files via ur PC sync conn. and delete them
Sep 09, 2007 | HP iPAQ RZ1710 Pocket PC
Is IPAQ rz1710 bluetooth technology compatible or not ?
The 1710 does not have bluetooth. You would have to buy a SD bluetooth card and then you could connect to the internet via a bluetooth phone if the phone had internet access.
Sep 08, 2005 | HP iPAQ RZ1710 Pocket PC
Motorola Mobility A1200 Logo
126 people viewed this question
Top Motorola Mobility Computers & Internet Experts
David Payne
David Payne
 Paul Flint
Paul Flint
Level 1 Expert
Unlockingcom
Are you a Motorola Mobility Computer and Internet Expert? Answer questions, earn points and help others
