Question about Canon SmartBase MP730 All-In-One InkJet Printer
Canon MP730 not feeding properly.
When printing & copying the right hand side feeds in OK but the left hand side is jamming up after feeding in approx 25mm. Consequently the paper twists sideways and we get a "paper jam" fault. I can't see any obstruction without starting to take covers off. Any thoughts?
    Problem Solver:
  • 18 Answers
I am not an expert but I am on my second MP730.
If it is the scan feeder that you are having a problem with, I had the same problem twice. What I did is jamb about 1/8" of post notes between the far paper control thing and the cover. Using the post notes you can add and subtact sheets easy, and keep the whole spacer thing together. When you get up close to 30 sheets (or more), you have to assist the feed a little (page at a time until it can handle it), if that is a problem.
If it is the printer feeder that you are having a problem with, what I did is clamp two 1/8" wide by 3/8" deep sticks of wood on the feeder to prevent the paper from wiggling to much, but it has to wiggle a bit or it wont feed. Snug but not to snug.
Hope this helps
Posted on Jul 14, 2008
The machine had never given trouble before, only this time when a new person was using it. So, figuring they may have refilled the paper tray incorrectly, I took out the paper guides at the back and kept hand feeding one sheet at a time. After each jam up I had to reset everything but after about 7-8 tries "something" cleared and now it works fine.
Regards BB
Posted on May 26, 2008
MP150 paper feed not working on left hand side
Check your paper feeding roller, first clean them
Apr 30, 2012 | Canon PIXMA MP150 All-In-One InkJet...
When the printer pulls a sheet down it grabs the right side of the sheet (as you face the machine) leaving the left side up, to warp the sheet and make a grinding noise trying to pull the sheet in. Of...
Solution: Cleaning The Paper Feed Rollers (Windows) iP1600
Clean The Paper Feed Rollers (Windows) Instructions how to clean the paper feed rollers. If the paper feed rollers become dirty, they may not be able to properly feed paper due to the feed roller's slippage.
If paper does not feed correctly, perform the following to clean the paper feed rollers:
  1. Open the printer properties.
  2. Click the 'Maintenance' tab and click 'Roller Cleaning'.
  3. Remove all sheets of paper from the auto sheet feeder.
  4. Confirm the following message, and click 'OK'.
    Note: Clicking 'OK' will activate the paper feed rollers 30 times. Thisactivation will take about 90 seconds. Do not perform other operationsuntil this operation has finished.
  5. Confirm the following message, and click 'OK'.
  6. After the continuous paper feeding operations in step 5 have finished, load three sheets of plain paper and click 'OK'.
  7. Confirm the following message, and click 'OK'.
    Note: The following message is displayed when the paper is fed and ejected.
  8. Click 'OK'.
Roller Cleaning is completed.
Jul 02, 2008 | Office Equipment & Supplies
I removed a jammed sheet of paper through the front opening, Had to pull real hard. Since then, when printing or copying, printer feeds up to 4 extra sheet with each printed page. I suspect some piece of...
Please see this solution from Canon. It is recommended you check your manual for the proper procedure for clearing paper jams. Incorrectly removing jams could damage your printer. Trust the following helps resolve your current issue.
If you do not have a manual it can be downloaded from here:
http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mx_series/pixma_mx300#BrochuresAndManuals
Issue: More than one sheet of paper feeds while printing
Solution: Clean the paper feed rollers using the MX300 operator panel
sikaku.gif Cleaning the Paper Feed Roller (Roller Cleaning) Clean the paper feed roller if paper is not fed properly. Cleaning the paper feed roller will wear the roller, so perform this only when necessary.
1. Make sure that the machine is turned on, and then remove any paper from the Rear Tray.
2. Clean the paper feed roller.
(1) Press the Menu button repeatedly until MAINTENANCE appears.
(2) Press the l_mark_s.jpg or r_mark_s.jpg button to select ROLLER CLEANING, then press the OK button.
The paper feed roller will rotate as it is cleaned.
3. Repeat step 2 twice.
4. Open the Paper Output Tray.
(1)Put your finger in the rounded indent beside the Paper Output Tray and open it gently.
(2) Open up and set the Output Tray Extension completely by pressing down the hollow on its front side.
5. Make sure that the paper feed roller stops rotating, then load three or more sheets of A4 or Letter-sized plain paper in portrait orientation in the Rear Tray.
Set the Paper Thickness Lever to the left.
6. Repeat step 2 three times.
The paper cleans the paper feed roller as it feeds through the machine.
If the problem is not resolved, wipe the paper feed roller (A) located on the right side inside the Rear Tray with a moistened cotton swab or the like. Rotate the roller (A) manually as you clean it. Do not touch the roller with your fingers; rotate it with the cotton swab.
Dec 25, 2010 | Canon MX300 Office All-In-One Printer
Canon LBP 1120 Offset paper feed and subsequent jamming.
G'day, I pulled the whole printer down and gave it a clean and put it back together and set it to work. All good.
May 11, 2009 | Canon LBP 1120 Laser Printer
Canon mx300 printer feeder pulls unevenly causing paper jam
the left side of the printer pulls the paper causing the printer to jam when trying to print
Apr 03, 2009 | Canon PIXMA MX300 All-in-One Printer
Copy Machine Canon GP335
OK i have seen this problem, whats is going on is ur paper feed tires are slipping and needs replacinGg, THIS IS GREAT NEWS FOR THE SERVICE TECH,
call ur indepentant serivce tech or if your in Ct we can help your feed tires need replacing and this could help your jam errors.
Mar 07, 2009 | Canon imageRUNNER 210S Copier
Printer feed
A lot of times its something jamming up the feed rollers that suck the paper in. I found a ring, rubber bands, banana stickers and more doing that to other printers
Dec 13, 2007 | Canon PIXMA iP1600 Printer
Paper will not feed correctly, keeps jamming up.
There IS something stuck in the feed path. If the paper starts to feed and then crinkles on the feed side, there is an object stopping the paper moving forward.
Lay the machine on it's back and take a sheet of very stiff card (A5 size approx) and push it through the paper path in reverse. So start where the paper would normally exit and push the card in. You may need to lift the pinch rollers just behind the print head by hand to aid the card through. Keep the card to the side that would normally crinkle but beware of the paper sensor flag. If you force it you could break it off.
Once you get past the pinch rollers behind the print head, push a little further then start to move the card in and out but along the length of the rollers. You should find that sufficient to push out whatever is in the path and having the machine on it's back will help it fall clear of the feed mechanism.
If it does not fall out using this method you will have to remove the covers and try to remove the ASF to get at the object.
Oct 14, 2007 | Canon PIXMA MP170 All-In-One InkJet...
Paper feed
Your printer is politely asking you to please get a torch, and open the lid of unit and thoroughly check inside all over for a tiny jam of paper or something else. I am willing to bet you will find some jam. I would also switch it off, and wait a while before turning on and printing again. Good luck
Aug 31, 2007 | Canon PIXMA MP530 All-In-One InkJet...
Canon SmartBase MP730 All-In-One InkJet Printer Logo
115 people viewed this question
old marine
old marine
