Printer won't print using black
My printer won't print black. The black ink tank is held in a seperate removable printhead (a BC-30e). The red/mag/cyan have a printhead (a BC-31e) of their own that they occupy together.
I have purchased a new black printhead and put that it and put in the new ink tank, but still it won't print black. All the tabs are removed...I've had the printer for a few years now...so I know I put everything in correctly.
Do you have any ideas? Could some of the electronics have gone? Or maybe something needs a clean - but what? Would appreciate any ideas you can offer. Thanks.
  • slyjo Feb 02, 2009
    I have an epson cx6000 I want print black only, how do I change from all the other three colors
    Genius:
  • 1,224 Answers
The absorber should be cleaned and sometimes you have to set the print heads in just right or get no color at all
there is also a solution called priming your print head a little rubbing alcohol on the print head with cotton swab to see if the ink runs on swab
Posted on May 22, 2008
HP 6940 won't print black-new cartridge installed-prints color but no black
In all likelihood your print head has become clogged at the black ink outlet. Be aware that printheads can BURN OUT if you keep trying to print and there's insufficient ink reaching the printhead. The ink flow is relied upon to prevent overheating of the tiny resistors at the printhead. Best bet is to remove the cartridges from the printhead and then remove the printhead and try to clean it in warm water. You will find many youtube videos on suggestions for cleaning the printheads on HP printers. Do a google search for your model. If all else fails you can order replacement printheads for the part that has failed. They are not cheap so price compare. Oftentimes they will cost nearly as much as a new printer!
May 16, 2012 | HP 6940 InkJet Printer
Canon MultiPass MP730 purchased 2004 NOT Printing Black INK- did: new canon ink tank inserted (never used refills) ran: printhead maintenance mannually cleaned print head w/ rubbing...
You could clean the black ink cartridge. For this you need to remove the black ink cartridge which is present in the printer. In order to clean the laser or scanner block you could use a cotton swab as it would fully clean the dirt. You need to clean the grime and the dried ink present in the printer. This would remove all the hindrances which prevent the ink from flowing. Cleaning the printer heads would also help to solve the problem.
Dec 02, 2010 | Canon Office Equipment & Supplies
Nozzle test does not show pattern for either BLACK output; deep clean does not correct problem. both catridges have plenty ink. color displays are ok.
CANON MP780 BLACK DOES NOT PRINT
This is what works for me. Try at your own risk. I cleaned both areas.
CLEAN PRINTHEAD:
Perform a nozzle check using the Canon software under "maintenance." If the nozzle check prints successfully, the problem is most likely not with the printhead. Otherwise, 1) Lift up the lever above the ink cartridges. Take the ink cartridges out. Put them in a plastic zip lock bag. 2) The container in which the ink cartridges sit is removable. The container is inside the moving mechanism. The container is the printhead. Tilt it slightly and pull up. This should come out easily. 3) There are round pads under which the ink cartridges sit in the printhead you removed. The large one is black. On the underside of the printhead are small slits. The **** separated from the others is black. Fill a syringe with Windex. a. Run warm water over the printhead until no more ink comes out. b. Fill the areas where the round pads are with Windex. c. Set the printhead on some paper towels. The liquid will soak through and come out the underside along with the ink. Repeat steps a-c until no more ink comes out, but at least 10 times. 4) Let the print head sit and dry for two hours. Put everything back in the printer. Unplug the printer. Plug in the printer. Turn the printer off. Turn the printer on. Do a clean cycle.
CLEAN PURGE MECHANISM:
You will need a light. 1) Unplug the printer and move the printhead all the way to the left. On the far right are two rectangular basins. The smaller one is black. Take your fingernail or a tweezers and lift out the sponge pad (do not drop it). Soak the sponge pad in Windex until it turns white. Plug in the printer. 2) Fill a syringe with Windex. a. Fill the basin with liquid. b. Let it soak for 5 minutes. c. Turn the printer off. d. Turn the printer on. Repeat steps a-d until you see a small hole in the basin. e. Put the syringe over the hole and fill the basin, pushing the liquid into the hole. f. Let it soak for 5 minutes. g. Turn the printer off. h. Turn the printer on. Repeat steps e-h 5 to 10 times. 3) Put the sponge pad back in using your fingers (do not drop it). Unplug the printer. Plug in the printer. Turn the printer off. Turn the printer on. Do a clean cycle.
Nov 01, 2010 | Canon PIXMA MP780 All-In-One InkJet...
My large black ink cartridge with not print correctly on my Canon Pixma MP830. All the other colors work fine. I've done numerous cleaning and deep cleaning. Then replaced the cartridge and it still prints...
Are your black ink cartridges genuine Canon ones?
Are the contacts clean when you remove the cartridge?
If not blow off with compressed air and a clean brush, if necessary.
Canon.com's site covers the verification that the cartridges are installed correctly below:
Issue: Black ink does not print
Solution: Confirm that the recommended ink tanks are installed properly MP800R / MP830
Replacing an ink tank When replacing the ink tanks, confirm that the new ink tanks are installed properly. If the ink tanks are not locked into place, paper may not be fed properly, or ink may not be supplied to the print head. Recommended Ink Tanks:
  1. Confirm that the printer is powered on and press the Open button. (The paper output tray will open.)
  2. Lift the scanning unit (printer cover) completely. (The print head will move to the replacement position.)
    Note:
    When the scanning unit (printer cover) is opened more than ten minutes, the print head moves to the right side. If this occurs, close the scanning unit (printer cover), and open it again.
  3. Open the inner cover.
  4. Press on the tab to release the ink tank, then remove it from its slot. If you are replacing multiple ink tanks, make sure to replace one by one.
  5. Check the ink tank. If the orange tape is as shown in Figure <1>, it is properly removed. If the tape is not removed (as in figure <2>, pleease remove the extra tape).
  6. Insert the ink tanks into the print head.
    Note:
    Press the mark "PUSH" on the ink tank firmly until you hear a click.
  7. Ensure that all the ink tanks are installed properly and the ink tank lamps light red.
    <7> The ink tanks are installed properly.
    <8> The ink tanks are not installed properly.
    Note:
    Ink Tank Lamp
    You can check the status of each ink tank according to the way its lamp flashes.
    • - On: The printer is ready to print.
    • - Slow flashing (at about three second interval): Ink is low. Prepare a new ink tank.
    • - Fast flashing (at about one second interval): Ink tank is empty, or the printer is not ready due to an error.
    • - Off: An error has occurred and the printer is not ready to print.
  8. Close the inner cover and the scanning unit (printer cover).
    Note:
    1. When closing the scanning unit (printer cover), be careful not to jam your finger.
    2. When starting printing next time, the print head cleaning launches automatically.
Jul 27, 2010 | Canon PIXMA MP830 All-In-One InkJet...
My printer only prints color..have installed new black cartridge but still only prints color so installed another new black cartridge and still only prints color
Unlike most printers where the print cartridge and printheads are attached and sold together, the ESP 3 has a separate printhead from the cartridges.
Remoe both cartridges. Then look at the place where the cartridges sit. There is a latch you push down in the back. This will release the printhead to allow it to be removed.
Remove the print head
Take a cotton swap and a little alcohol and clean the printhead of all ink. Repeat this until it is totally clean.
Make sure the printhead is dry and clean of all ink and alcohol.
Replace the printhead.
Place cartridges in and test.
If this does not work, then you need a new printhead for this printer.
here is an example of how to remove and replace printheads for thsi unit.
http://faqs.kodak.com/atg/faq/attachments/AUR1780-2.pdf
to gt a new printhead you must contact kodak
http://www.kodak.com/go/contact
probably as expensive or almost as expensive as a new printer.
The seperate printhead from the carts are why kodak can have their ink so cheap. Those other brands cost that extra 15-20$ for the attached new head with each cart.
Jun 12, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
Black ink cartridge holder not working , can not print with black ink cartridge holder, when i use the colored ink holder printer works ok
The problem you are describing is with the black ( BC-10 ) print head and not with the printer.
1. Check your black ink tank and be sure it is not dry.
2. Run the printer through one DEEP cleaning cycle and see if that improves the print.
If your black ink tank is full, and the deep cleaning cycle produces no improvement, you will need to replace the BC-10 print head.
Mar 11, 2010 | Canon BJC 85 InkJet Printer
Picked up a Canon S450 - nice printer, but....
Keep running the cleaning cycle. You may have to run 20X's to break the clog. And I would not perform any of the "maneuvers" you mentioned. Alcohol will turn the plastic to mush.
gurutim
Mar 21, 2009 | Canon BJC S450 InkJet Printer
Cartridge recommendations
You can purchase Canon cartridges directly from Canon here. The BC-10 is a cartridge that prints with black ink only. The BCI-10 is the replacement ink tank for this cartridge (a new cartridge comes complete with an ink tank). The BC-11e is a cartridge that prints both black and color, and has two ink tanks, the BCI-11 black and BCI-11 color. A new BC-11e cartridge comes complete with two new ink tanks.
Oct 03, 2008 | Canon BJC 80 InkJet Printer
Parts
The BJC-55 takes 2 different types of print heads. And also a scanner head, that snaps into the same place and turns the printer into a scanner.
One print head is a Canon BC-11E. It has 2 ink tanks in it. 1 black and 1 tri-color. It prints in full color or black
The other print head is a BC-10. It prints only in black. But the ink yank holds 4 times the black ink of the BC-11E. It is very popular with business travelers who print only documents. The printer works about twice as fast with it. And replacing ink is a lot cheaper.
The scan head is called an IS-12.
Prices range from 40 to 60 dollars in supply stores ( Staples, etc)
Ebay is a good place to look for them
Oct 27, 2007 | Apple Canon BJC 55 InkJet Printer
Can't print in Black ink
I had the same problem I found this solution to be very effective: * Buy alcohol solution (70% or more). You can find it in any drug store. * Remove both cartridges from the printer head. Unplug the printer head from the printer body. Pour the alcohol into paper towel layer. * put the printer head on the top of wet towel with the face of HEAD touching the towel. * clean the head with the towel and get rid of all the built-up ink on the head. * Pour the alcohol into the printer head container (ink-receptacle area is where the ink cartridge normally sits, notice a small hole where the ink flow into the printer). Do not touch any electronic parts and let it dry over night. * Do step 2-5 again if necessary. * Install the cartridge back to the printer and run several head cleaning maintenance, print nozzle check, make sure to repeat this step until no more dead nozzle shown. It worked for me :0)
Jun 26, 2007 | Canon PIXMA MP780 All-In-One InkJet...
111 people viewed this question
k24674
jasbo
jasbo
