Connecting the LE46A556P LCD TV to the HTZ310R Home Cinema System
I have just purchased the LE46A556P & the HTZ310R and cannot get the sound from my TV Channels e.g SKY Plus Box to come out of the Home Cinema System.
I have connectd the HCS via HDMI cable to the TV and the SKY box via a scart what am I doing wrong ???
  • Pat20855 Jun 02, 2008
    Thanks.....!!! Worked a treat sound & vision ok now
  • wendy183 Jun 15, 2008
    I have bought the new Series 6 40" samsung with the Samsung HT-Z310R.
    I can get the home cinema to work when I play a DVD but on TV the sound is only coming from the TV speaker and not the HT speakers.
    When I go into the menu to select or change Sound, half of the menu's are not highlighted so I can't even change the setup.
    Can you help
  • 3 Answers
You need to be connecting the TV and the Sky Plus to the HT box via optical (toslink) for full surround sound. As you only have one optical port on the HT, I would suggest buying a Optical selector such as this one. I would also suggest looking on avforums more more help. I use it for most of my questions if ever i need any help.
Hope this helps!
Posted on Jun 01, 2008
I have an LG TV with an LG HOME CINEMA SYSTEM problem is: watch dvd/blue ray - video fine sound fine (through speakers) watch tv / sky -- video fine sound None throughspeakers on...
There are two things that I can suggest.
1-Test your optical cables to make sure they a good on a known working source because they are very fragile and break very easily.
2-Try to eliminate the use of optical output from tv to receiver. There may be a problem from the HDMI to optical conversion at the tv. Instead, try running the audio directly from the source to the receiver, and let the tv deal with video input only.
Hope this helps,
Good Luck.
Jan 07, 2011 | LG Audio Players & Recorders
Samsung series 6 tv & Samsung 2:1 home theatre problems
if you got all the lead you should have fibre optics which connects from dvd to tv and then set your dvd to digi in. you should get the sound. i have same cinema system and i have done the same
Jan 13, 2009 | Samsung HT-X20 Home Cinema 600W Theater...
No sound through the Panasonic cinema surround sound on TV
Had a similar problem mate. I solved it by connecting the tv to the PT460 system with a scart lead. You then have to have the AV channel selected on the PT460 system to listen to the tv. You will always have to have the AV channel on the PT460 selected to listen to any sound transmitted through the tv - be it playstation/xbox or any other device that you may connect in the future with HDMI leads or otherwise. Hope this helps
Jan 04, 2009 | Panasonic Home Theater System System
Samsung htz310r home theatre system to samsung tv no sound
make sure the HDMI is a output not an input. then try your settings and see if you have a setting for output audio
Dec 13, 2008 | Audio Players & Recorders
Can't get tv sound from home cinema system speakers
you need an optical cable going from the TV to the home cinema for an audio output, it worked for, had the same problem!!
Dec 04, 2008 | Panasonic Home Theater System System
How do i get the sound from my Philips TV into my samsung 2.1 home cinema system?
To get sound from any TV (including Philips) to an amplifier or a home cinema system, the TV should have a LINE OUT RCA pair. Thereafter, it is a simple case of connecting said Line OUt to one of the INPUTs of the cinema system.
Often (but not all), Cinema Systems have their own TV tuner and would provide a video out that could be connected to the Video IN of the TV.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jul 19, 2008 | Samsung Televison & Video
How to hear sky tv's voice from home cinema system?
PUT A SET OF PHONO CABLES FROM AUDIO OUT ON SKY TO AUX INPUT ON YOUR SAMSUNG.SWITCH SYSTEM TO AUX INPUT SET SOUND 2 PROLOGIC 2,AND HEYPRESTO SURROUND SOUND I HOPE.
HOPE THIS HELPS.
CABLE GUY.
Jun 26, 2008 | Audio Players & Recorders
TV sound to Cinema system?????????????
Thi is not possible so I exchanged the TV for another one, This TV does not have AUDIO OUT function.
Mar 28, 2008 | Panasonic Audio Players & Recorders
37pf7531 tv
If you have a later Philips home cinema model: HTS3100, 3300, 3500, 3154, 3357, 6510 & others, the sound from the TV will go through the existing scart connection.
Just select TV on the home cinema remote control.
For any other models, use a scart - twin phono lead (red & white), from the TV to one of the inputs into the home cinema.
Scarts 1 & 2 on the TV will have different results. Try both.
Nov 29, 2007 | Philips 37PF7531D/10 37 in. LCD Television
Set up help!!
Firstly connect your home theatre outpu HDMI to HDMI input1 on the TV. Then connect the PS£ HDMI to the other HDMI input on the TV. Now connected the optical cable from the PS3 to the optical input of the home cinema system. Your should now have surround sound from the PS3 and DVD.
Sep 11, 2007 | Samsung HTP-1200 System
Televison & Video Logo
289 people viewed this question
Top Televison & Video Experts
