Question about HP LaserJet 9000n Printer
Paper jam from optional cassette
I am facing the problem from cassette no 4 paper not feeding from cassette 4 and the massege is coming open the right door to clear the paper.but in the right door there is is nothing.
You are giving us assistance by money why i tell u the solution free.by the way i solve my problem.
Posted on May 22, 2008
Getting a error message JAM11 on copier CS-1815?
A paper jam in the
paper feed section
is indicated during
copying or printing
(no paper feed from
the cassette).
Jam code 11
Paper in the cassette is
extremely curled.
Check if the feed roller is
deformed.
Defective registration sensor.
Check if the feed clutch
malfunctions.
Electrical problem with the
feed clutch
The above is taken from the sm
Also the feed tyre needs cleaned / changing and or cassette springs need stretching !!!
Dec 03, 2013 | Copystar CS-1815 Printer
Paper jam and no paper jam
Probably paper never being picked up and not feeding out of cassette which explains why you see a jam indicated but cannot find a jammed paper. Probably time to rebuild the cassettes.
Aug 28, 2012 | Canon iR 2016i Black and White Copier
When i switch on my photocopier tohiba 2860, it asks for service and gives an error code 08221-918100. what could be the problem?
Hi tkasirye,
Welcome to Fixya.
You may need to check again the error code. According to the manufacturer's checklist for error codes, only the following are documented;
  1. Error Codes - Toshiba 2860
  1. "E01" Paper jam inside machine. "E02" Paper jam near the fuser. "E03" Paper jammed inside machine when power supply is switched on. "E04" Front cover open while copying. "E05" Paper jam near the aligning roller "E08" Paper jam at stacking area in the ADU "E11" Paper feeding jam at the ADU "E12" Manual feeding jam "E13" Paper jam from cassette 1 "E14" Paper jam from cassette 2 "E15" Paper jam from cassette 3 "E16" Paper jam from cassette 4 "E17" Paper jam from cassette 5 "E19" Paper jam from the LCF "E21" Paper jam in transport route 1 (LCF) "E22" Paper jam in transport route 2 (COPIER) "E23" Paper jam in transport route 3 (ALIGNING) "E25" Paper jam in transport route 4 (PFP) "E71" Original feed jam in ADF "E72" Original transporting jam in ADF "E73" Original exiting jam in ADF "E75" 2nd original feeding jam "E81" Paper jam before sorter "E82" Paper jam in sorter "E83" Sorter early arrival jam "E84" Paper in sorter when power is turned on "E85" Joint open jam while copying "E88" Paper jam outside the sorter bin "C01" Abnormal operation of the copier main motor "C04" Abnormal operation of the PFP main motor "C05" Abnormal operation of the ADU main motor "C11" Abnormal operation of the ADU side motor "C12" Abnormal operation of the ADU end motor "C13" Abnormal operation of the upper cassette tray "C14" Abnormal operation of the lower cassette tray "C15" Abnormal operation of the PFP upper cassette tray "C16" Abnormal operation of the PFP middle cassette tray "C17" Abnormal operation of the PFP lower cassette tray "C18" Abnormal operation of the LCF tray "C21" Optics carriage initialize error "C22" Lens initialize error "C23" Mirror initialize error "C26" Faulty exposure lamp "C33" Easy set-up is failed "C35" Developer material exists at the transfer separation adjustment "C41" Faulty thermistor or heater "C43" Faulty thermistor "C44" Faulty heater "C45" Sub thermistor is open
Shoulg you not find any of these mentioned error codes, I suggest you contact the tech support especially if the machine is still under warranty.
Hope this helps.
Takasashi
Jul 05, 2011 | Toshiba Office Equipment & Supplies
Sir! the problem of our kyocera mita fs 3800 is this that it gives us message that the paper is jam please open the cassette 1.and remove the paper. we opened the cassette 1 checked the tray but there is...
Try cleaning the paper feed rollers for that cassette. Sometimes the rollers get dirty causing the paper to slip and not feed from the cassette causing the machine to register a paper jam.
The rollers can be cleaned with rubbing alcohol and a cloth.
Apr 04, 2011 | Kyocera Mita FS 3800 Laser Printer
WILL FEED PLAIN WHITE PAPER BUT WILL NOT FEED PHOTO PAPER
Follow the steps:
•1
Turn on the printer and press the Paper Feed switch until the Auto Sheet Feeder indicator light turns on.
•2
Pull up on the paper sheet feeder on the top and back of the printer and slide out the paper support.
•3
Take a stack of no more than 10 pieces of photo paper and flatten the corners, if they are curled. Curled corners may cause jams within the printer.
•4
Place the paper in the paper sheet feeder with the printable side of the paper facing up. The printable side of photo paper is the shiny or whiter side of the paper.
•5
Print your documents as needed.
Paper Cassette :
•1
Switch on the printer and press the Paper Feed switch until the Cassette indicator light turns on.
•2
Pull on the cassette on the bottom of the printer to slide it out of the printer.
•3
Flatten the corners of a stack of no more than 10 sheets of photo paper if the corners are curled. The paper may become jammed in the printer if the corners are curled.
•4
Place the stack of paper in the cassette so the paper is touching the right side and the printing side of the paper is facing down. Adjust the plastic paper guides so they touch the paper. The paper stack guides help facilitate the paper moving into the printer.
•5
Slide the cassette back into the bottom of the printer. The printer is ready for printing.
Oct 20, 2010 | HP PSC 2355 All-In-One InkJet Printer
I cant find my manual how to i place the paper underneath so it feeds through the bottom
You can use the paper cassette located at the bottom of the printer, on the front when the output paper tray is closed concealing the paper feed switch, the usb port and the cassette lamp.
1 Gently pull out the cassette from the printer.
2. Remove the cover from the cassette.
3. Place your paper in the cassette tray.
a. when using A5 or larger sized paper (non standard sized paper, pinch the tab and extend the cassette if needed.
b. legal sized paper is not loadable in the cassette
4. Do not load paper above the load limit mar4k.
5. Make sure the print side of the paper is facing down.
6. Align the paper stack against the right side of the cassette
7. Slide the paper guides so they fit the loaded paper stack.
8. The paper cassette will hold up to 150 sheets of plain paper, however you do not eant to stack any more than 50 sheets in the Paper Output Tray.
9. Reinsert the cassette into the printer. Then set the cover on the cassette. Now make sure the cassette is pushed al the way into the printer. (If long paper was used and the cassette was extended iy will now extend beyond the front of the printer
10. Prepare the paper output tray by opening the front cover and pulling out the tray extension until extended completely.
11. Press the paper feed switch so the cassette lamp lights.
You can slo select the paper source with the printer driver if you prefer .
Mar 07, 2010 | Canon Office Equipment & Supplies
Paper jams on right side when facing the printer
Please follow these steps :
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button.
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to t
May 01, 2009 | Office Equipment & Supplies
Error msg: Paper tray empty or jam, when there is not
Clean The Paper Feed Rollers Using The Unit's Operation Panel Ifthe paper feed roller is dirty, paper is not fed properly because thepaper feed roller slips. Cleaning the paper feed roller could resolvethe paper feeding problem. Please follow the instructions below toclean the Paper Feed Rollers directly from the unit. Caution:Since the cleaning process wears down the paper feed roller, performthis procedure only when necessary and no more than three (3) times.
  1. Ensure that the machine is powered on and remove any paper from the auto sheet feeder or the cassette.
  2. Use the <Feed Switch> button to select the paper source where you do the paper feed roller cleaning. Click for additional information.
  3. Press the <Menu> button.
  4. Use the right / left cursor button to select [Maintenance/settings] press the <OK> button.
    Note: This procedure is skipped if your machine is in Scan mode. Proceed to step 5.
  5. Use the right / left cursor button to select [Maintenance] and the press the <OK> button.
  6. Use the up / down cursor button to select [Roller cleaning] and press the <OK> button.
  1. Use the up / down cursor button to select [Yes], then press the <OK> button. (The paper feed roller cleaning starts.)
  2. Tocheck if the rollers are clean, load a sheet of Letter-sized plainpaper in the same paper source you selected in step 2, and press the<Open> button.
  3. Use the up / down cursor button to select [Roller cleaning] and press the <OK> button.
Use the up / down cursor button to select [Yes], then press the <OK> button. (Paper will be fed.)
Note: If paper is not fed properly, repeat steps 4 through 10 above up to three times.
Paper Source
Press the <Feed Switch> button to switch to toggle between the Automatic Sheet Feed (ASF) or Cassette. The light will come on when the <Feed Switch> is set for that paper source.
Cassette
Note: When printing from the computer, if paper does not feed from the source you have selected on the operation panel, check Paper Sourcesetting in the printer driver. If the option is not set to 'Paper FeedSwitch', paper will feed from the source selected in the driver.
Nov 27, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Error 391: paper jam
See below for Error 391:
CLEANING THE FEED ROLLER AND THE PAD
Clean the feed roller and the pad when [391: Paper Jam] appears frequently.
(1) Remove the paper cassette.
(2) Clean the feed rollers (large and small) with tightly wrung wet cloth or an LED lens cleaner.
Note! An LED lens cleaner is enclosed in an optional replacement toner cartridge.
Feed roller (large)
Feed roller (small)
(3) Clean the pad on the paper cassette with tightly wrung wet cloth or an LED lens cleaner.
Note! • If [392: Paper Jam] appears frequently, clean the second tray (option) in the same way.
• If [390: Check MP Tray] appears frequently, clean the feed roller of the multi-purpose
tray in the same way.
Pad
Apr 04, 2008 | OKI C5200n Laser Printer
Won't take paper
Clean The Paper Feed Rollers Using The Unit's Operation Panel If the paper feed roller is dirty, paper is not fed properly because the paper feed roller slips. Cleaning the paper feed roller could resolve the paper feeding problem. Please follow the instructions below to clean the Paper Feed Rollers directly from the unit. Caution: Since the cleaning process wears down the paper feed roller, perform this procedure only when necessary and no more than three (3) times.
  7. Use the up / down cursor button to select [Yes], then press the <OK> button. (The paper feed roller cleaning starts.)
  8. To check if the rollers are clean, load a sheet of Letter-sized plain paper in the same paper source you selected in step 2, and press the <Open> button.
  9. Use the up / down cursor button to select [Roller cleaning] and press the <OK> button.
  10. Use the up / down cursor button to select [Yes], then press the <OK> button. (Paper will be fed.)
Paper Source
ASF
Cassette
Note: When printing from the computer, if paper does not feed from the source you have selected on the operation panel, check Paper Source setting in the printer driver. If the option is not set to 'Paper Feed Switch', paper will feed from the source selected in the driver.
Click to return to step 2 above.
Mar 30, 2008 | Canon Pixma MP500 All-In-One InkJet...
HP LaserJet 9000n Printer Logo
29 people viewed this question
Seeker5211
Seeker5211
mukhtar21 shaikh
mukhtar21 shaikh
