Question about Epson LX-300 Matrix Printer
Epson Lx300+ printing problem
When i give print; it prints one line (@~#...like ),then paper comes out ,next paper same one line ,repeat this proses. No proper print out comming.how can i solve this problem.Already changed the printer cable.kindly give me a solution.
    Scholar:
  • 107 Answers
Hi
pls check printer test print
  1. switch off the printer .
  2. insert paper in printer
  3. hold the button ll/ff pressing .
  4. switch on the printer
if you get test print OK then. you need to be Reinstall Printer Drivers on your Pc
Posted on May 22, 2008
  • Techpoint
    Techpoint Jun 10, 2008
    If this information is useful for you please rate me ...
Printer will not print all pages will only print what is on screen
There is little bite problem when you try to print a file ( More pages). To Solve these problem follow these proses
go File>print( new Dialogue box comes) In page range box select ALL . Then print as usual. I think you would print all the pages what you wnt to print.
Thank You.
Apr 14, 2013 | Epson Stylus Multifunction Inkjet Printer/...
I cannot print the endless paper
The Epson LX300 has a paper release lever which should be set
; forward for continuous paper printing and
: back for single sheets.
Oct 03, 2011 | Epson LX-300+ II Matrix Printer
Printing on a customise continuose paper
Check the printer settings about page length by the procedure given in the user manual.
If OK check your software if it is giving soft commands to adjust paper lengths.
Sep 28, 2009 | Epson LX-300 Matrix Printer
EPSON LX300+II PRINTS THE SMALL FONT & LEFT SIDE
change the fonts of the printer by pressing the font button on the panel (Refer user manual for more details)
Feb 04, 2009 | Epson LX-300+ II Matrix Printer
Prints on the sides only and not in the middle
it print on the sides only even though the paper is fitted well give solution to solve this problem
Dec 19, 2008 | Epson LX-300 Matrix Printer
Printing shows doubling
alguien por favor envieme los drivers de la impresora EPSON LX300 les agradesco
May 26, 2008 | Epson LX-300 Matrix Printer
Sending Reverse Line feed to Epson LX-300+II USB printer
Hi Shery,
I went through the manual of LX300 printer series.I believe that if u read that manual, you can Fix the problem as it has all instruction about the Reverse feed and pull tractor mechanism.
Download Manual
http://ftp.epson.com/pdf/lx300p/lx300ppg.pdf.Any issue contact me.
Thank you
Riz (zyrixdown3@gmail.com)
Feb 11, 2008 | Office Equipment & Supplies
Epson lx300+ii with serial port to fujitsu pc
use the com1, and use a baud rate like 9600, with 8 and 1 bit stop. dont. be sure that is in ESC/P or IBM as you requiered. if your software use directly the serial port, be sure that the bios set up is properly. i think that the lx300+ have less buffer than lx300+2
and if you use high speed, could loose info.
Jan 28, 2008 | Epson LX-300+ II Matrix Printer
Printer not Print data in English Language
Hi, you may want to reset/restore the Epson LX300 to default settings. This can be done by pressing down on the FONT button while powering on the printer. If done right the LX300 will print a test page with the firmware version. It is also possible that the drivers are corrupted. In Start, Printers & Faxes, delete the LX300 printer, restart your PC and then re-install via Add Printer. In some cases, defective parallel cable can also cause problems. Unfortunately the only sure way of checking is by replacing the printer/parallel cable with a known good/operation cable. If the printer would really be requiring service, a Service Manual is available at (http://www.eserviceinfo.com/index.php?what=search2&searchstring=DPA-300) Hope this be of some help to you. Good luck and pls post again how things turn up.
May 26, 2007 | Epson LX-300 Matrix Printer
Epson LX-300 Matrix Printer Logo
426 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
