Question about Danby DPAC7599 Air Conditioner
Leaking water; reservoirs empty
I have a Danby DPAC 7599 (also called the 7599-2) and it dribbles water on the carpet, while the reservoirs to collect the water remain dry. I was told by a friend that he had the same issue with one, years ago, and that it is a blocked drain hose. But I've never taken apart ANY A-C unit EVER, and I'm not so sure I can remove and clean that hose. I wonder if I should pay to have it done, or if I can afford that.
The summer before, it was fine and worked as it should have.
THANKS
Rob
  • Rob_Canada Jun 12, 2008
    I didn't think it was over 5 years old! Oh great, now what do I / we do?
    If you know you need a new hose, then by chance is the hose out of the A/C? What color is it? Clear? How long is it? How it is that your hose failed? How is it different from 1/2" or whatever size, clear plastic tubing with a hose clamp of whatever sort, at one (or both) ends??
    Thanks!
    Rob in Canada
  • ccevans Jul 01, 2008
    I'm struggling with the same issue here...I bought it off a friend (or not) who stated that it worked perfectly since he bought it last summer. Now - dribbling on carpet. Have you had any success in rectifying the problem, Rob
I bought my Danby Premiere portatable A/C a few years ago and it has ALWAYS leaked from the first time I used it. I keep it in a boot mat so it doesn't ruin my wood floors and just keep sponges in the boot mat to mop up and toss out any water that leaks. It's not likely the safest thing to do but I'm not paying any more than I already did for the **** thing. Very DISSATISFIED and will never buy "portable" again.
Posted on Jul 06, 2012
I have this too we had that problem as well, nothing we could do about it either..
i need a new hose and exaust kit you know anywhere to get that?
this unit is ancient
Posted on Jun 12, 2008
In Dry and Air Condition mode, my Danby dpac 7597 is leaking from the bottom; not from the drain hose.
It is leaking water correct? Check your hose for clogs or a crack, follow it up and find where it is exactly coming from. If you need a part replaced, let me know and I can find you a replacement. If you have questions about accessing parts, let me know but the outer panel should be held together with simple screws.
Aug 13, 2008 | Danby Heating & Cooling
Danby dpac 10071 air conditioner is not cooling. a red light is on next to an icon with a full cup. Does anyone know how to make it cool?
That indicates that the water collection bucket is full and needs to be drained. Once the unit is turned OFF, unplugged and drained, the unit will start up and start cooling again. The drain hole is on the rear of the unit, just above floor level. You can either drain it in a shallow sided pan capable of holding 1 quart of water. Or roll it to a floor drain or outside to drain it.
Hope this helps you and thanks for choosing FixYa.
Jul 29, 2011 | Danby DPAC10061 Air Conditioner
Can't find where to empty the water
I need to be clear on what you said. you "can't find where to empty the water." Meaning you have removed the water collection bucket and don't know where to empty it? If that's the case, emptying it in a bath tub, is the easiest way.
However, if you meant, you don't know how to remove the water collection tank. It's on the front of the unit, below the air intake louvers. It simply slides/pulls out of the dehumidifier, when you pull on the indented handles on both sides of the bucket.
To assist you further, I have included a link to the Owner's Manual to a Danby model similar to yours. You can download and print it for future reference.
http://www.danby.ca/cms/uploads/products/en_manual/DDR25E__DDR30E__DDR45E__DDR5011_manual_v3.pdf
I hope this helped you.
Jun 27, 2011 | Danby DDR586R Dehumidifier
My danby DPAC 12030 is leaking water down the front
Since, I believe your model s a multifunction unit (Air Conditioner and Dehumidifier), Which can be operated together or separately. There are two things which may be causing this problem. If the dehumidifier function is operating the water collection tank o bucket may be full and needs to be emptied. In conjunction with this, the air intake filter on the inside front of the unit may be dirty or clogged.
There is a third thing that is also playing a role in this. The tubing that drains the water into the tank may be clogged. Which causes the water to backup and overflow. You can clear any clogs by using an 18" long, plastic Zip Tie, that is appropriately sized to fit inside the tube or hole. Insert it carefully and work it in past the bend in the tube, until the Zip Tie bottoms out or you run out of usable Zip Tie. The rotate (twist) it as you carefully remove it. As you reach the end of the Zip Tie, be prepared for some water to follow. CAUTION: BEFORE ATTEMPTING ANY SERVICE OF THE UNIT, TURN THE MASTER ON/OFF SWITCH TO OFF & UNPLUG THE UNIT FROM THE ELECTRICAL OUTLET.
Also keep in mind When dehumidify mode is selected, the indicator light will shine ORANGE. Air is
dehumidified as it passes through the unit,without being in full cooling mode. The fan will operate on medium speed. If room temperature is 25°C (77°F), fan speed can be adjusted; otherwise fan speed is fixed to "low". Note: The warm air exchange hose must vent inside the room when using Dehumidify Mode, not outside as it does when cooling. If the unit is vented outside, some cooling will occur.
Hope this helped you troubleshoot and solve the problem. Please let me know. Thanks.
Jun 08, 2011 | Danby DPAC12030 Air Conditioner
I want to use my danby 7599 as a heater, do I need to have the exhaust tube vented to the outside on the back?
As per instructions on page 4 of the manual I printed out from the internet (which I cannot find again) :
The exhaust/window kit must be installed AT ALL TIMES WHEN THE UNIT IS OPERATING UNDER THE AIR CONDITIONING MODE.
There should be at least 11.8" clearance between the unit and any other objects or building structure. The unit should be installed on a level surface. The window kit does not have to be installed during operation of the remaining three modes. (Heating (DPAC 7599) /Dehumidifying/Fan)
Nov 21, 2010 | Danby DPAC7599 Air Conditioner
My Danby Premiere DPAC 13009 is leaking water through the bottom. I have attached the continuous drainage hose, and no water is going through it. I tried to manually drain the tank using the drain at the...
Water is collected from cooling mode, not just dehumidifier mode. It does not always evaporate into the exhaust stream due to design limitations.
Of course the water should never leak even on the hottest day. Two suggestions:
Try removing the hose and attaching the external tank to see if it has any effect. Otherwise, you'll need to locate the exact source of the leak.
May 25, 2010 | Danby DPAC12031 Air Conditioner
My danby air conditioner/dehumidifier model dpac 8399-4 leaks water all over the floor and never fills the holding tanks what can I do to fix this problem?
Probably needs cleaning. I assume it is on a level surface. Water drips from the evaporator coil into a collection tray of some type and then drains into the holding tank, this tray is either broken or the outlet is plugged.
Good Luck,
Gilsh
Nov 26, 2009 | Danby DPAC8399 Air Conditioner
Using the DPAC 8020 AIR Conditioner (Danby)
these portable units will usually have a knob reading from low to high. set it about half way and adjust as needed. half way is usually low 70's
Aug 03, 2009 | Danby DPAC8020 Air Conditioner
Danby dpac 7599 PC board fuse keeps blowing
Sounds like the Start capacitor might be shot.  I think  you need a professional to service it.
Jul 08, 2008 | LG Goldstar GWHD5000 wall/window Air...
Danby DPAC7599 Air Conditioner Logo
649 people viewed this question
Top Danby Heating & Cooling Experts
Dan Webster
Dan Webster
Dennis Boxerman
mintvl
Level 1 Expert
Are you a Danby Heating and Cooling Expert? Answer questions, earn points and help others
