Question about Sylvania LC370SL8 37 in. LCD Television
I have a sylvania LD320SS8 32" digital/analog lcd tv witha built in dvd player
I hooked everything up and went to turn it on it will turn on and display digital telvision in the lower right hand corner then it just shuts off
  • aaron7 Nov 05, 2008
    Same model, same problem. Mine was made November 2007. Guess you get what you pay for!
  • ejones14kt Jan 30, 2009
    I have the same problem. Unit powers up and shows the digital television in bottom right hand corner and then powers back off. I checked the board and did not see anything blown.
    Please Help
    Problem Solver:
  • 17 Answers
Take the Inverter Board out and check for Open windings on the 6 Transformers along the edge of the board. When you find one open, get the number off of the Transformer, Google it, buy one and replace the bad transformer. I was given one of these TV's and fixed it for $11. It's not rocket science, if you can use a DMM and a soldering Iron, you can fix this.
Posted on Nov 06, 2009
  • Todd Dec 18, 2012
    on that inverter board my wires are melted and burned can those be replaced also?
  • Todd Dec 18, 2012
    check with power on? and what about the wiring off the board to back lights if they are burned
    Problem Solver:
  • 10 Answers
I can rebuild the invertor boards in that model to fix the shutting off problem. The boards themselves are on eternal backorder. Email me at aplusrepairs@triad.rr.com for more information.
Posted on Sep 29, 2008
I'M trying to get my u-verse remote to operate the tv do anyone know the code to tv too enter in too remote
Posted on Dec 12, 2008
Im having the same problem with my set as well, i have opened it up and determined it was the inverter/power supply board causing the problems. now im debateing wether i should buy a board for 119.99 or just throw it out.(i trashpicked the tv)
Posted on Jul 13, 2008
How do I connect my Sylvania DVD VCR Player to my Westinghouse LCD TV?
Your Sylvania player probably has three outputs: right audio (red), left audio (white), and video (yellow). Use a corresponding three conductor cable to connect to corresponding inputs on the rear of your Westinghouse TV (if it has them).
Sep 19, 2015 | Sylvania Televison & Video
Tip
Sylvania LD200SL8 Manual Download
Download Sylvania LD200SL8 LCD TV with DVD Player Manual
Have you misplaced your Sylvania LD200SL8 LCD TV with DVD Player Owners Manual?
Would you like a digital, searchable, pdf version of the Sylvania LD200SL8 LCD TV with DVD Player Users Guide?
Follow this link (& click Free) to download a pdf version of the operations manual.
I hope that helps.
on Apr 27, 2010 | Sylvania LD-200SL8 20 in. EDTV LCD...
Tip
I hope that helps.
on Apr 27, 2010 | Televison & Video
The converter box is hooked On the TV and working. I have the TV with the rabbit ears and only video n audio in the front (yellow n white). I recently purchase a DVD player n I am trying to hook it on the...
you have to change the input on the tv to AV. there should be an input button on the remote, but if your remote doesnt work you might not be able to change the input. you can try to use the channel up and down on the tv and once you get to the end of the numbers, some tvs will change inputs before restarting the number list. make sure you hook the yellow cable to the yellow plugs on the dvd and the tv and either of the red or white ones to the white one on the tv. red and white are left and right audio and the yellow one is the video
Dec 24, 2010 | Insignia Digital-to-Analog Converter for...
Have Problems with getting Channels?
You've not given us the manufacturer, make and model number, but I see 3 analog inputs on the left and the usb on the right. This tells me the analog audio and video signals must come from a dvd or vcr or tv-tuner. You say getting channels, so I'm assuming you've not hooked up to a digital ready tv hooked to cable or dish or digital converter. THERE ARE NO MORE ANALOG SIGNAL CHANNELS ANYMORE. Everything went digital in June 2009. So there you have it. If you don't have usable information going in, you can't get it out. try it with sterio audio and video from a digital tv that is receiving channels, and I think you'd then see sterio and video out of your pc. Regards --- GooseBay_Camper
Sep 28, 2009 | RCA Analog (RCA) to Digital (USB)...
Sony str-dg820. having a problem getting video on tv
Hook up Composite / Component Monitor Out wire from receiver to TV video input because receiver will not change analog input into HDMI
You need to connect receiver and TV through analog video terminals as above.
Actually you are expecting that receiver will convert DVD player and Xbox analog video input into digital HDMI signal for TV and This is incorrect.
Jan 04, 2009 | Sony STR-DG820 Receiver
Hooking up converter box when i have a dvd player and direct tv
Hook your Insignia box between your antenna and your television. You still need the antenna.
Jan 01, 2009 | Insignia Digital-to-Analog Converter for...
Ilo DVD player/recorder
> jfthr - Tv convertor boxes transfer digital signals into ANALOG. So when it goes to the dvd recorder it IS ANALOG. I have my antenna hooked to my convertor box, the converter hooked up to the ILO (A/V connections) then, the output on the ILO to the input of my analog tv. (Video selection on my tv). It works great to watch tv and/or record. I switch to the "DVD SOURCE" to watch dvds. Maybe you have the conv box hooked to the tv then the outs on the tv to the dvd. That would explain why you can get a picture but not watch dvd? The ILO has to go between the box and the tv in order to watch dvd.
Aug 07, 2008 | iLO DVD Recorder DVDR05
DTV????????????????????????
From the side of the carton in which it came:
CONSUMER ALERT: This television receiver has only an analog broadcast tuner and will require a converter box after February 17, 2009 to receive over-the-air broadcasts with an antenna because of the U.S.'s transition to digital broadcasting. Analog-only TVs should continue to work as before with cable and satellite TV services, gaming consoles, VCRs, DVD players, and similar products. For more information, call the Federal Communications Commission at 1-888-225-5322 (TTY: 1-888-835-5322), or visit the commission’s digital-television Web site at: www.dtv.gov.
The only other thing I could add to this, is that the Post Office in 2009 will get the task of handing out $40.00 coupons to to anyone wishing to purchase a converter.
Nov 15, 2007 | Sylvania 6620LG 20 in. EDTV-Ready LCD...
Sylvania LC370SL8 37 in. LCD Television Logo
1,250 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
