Question about Jl Audio 300/4 Car Audio Amplifier
JL 300/4 problem
I have lost the left side channel of my JL300/4 amp what can I do I'm based in the uk.
  • 631 Answers
If both the left front and left rear channels are out, reverse the RCA cables to determine if the problem is signal related. If the left side plays when you reverse the RCA cables, reverse them at the head unit to see if the audio changes sides. If it does, the head unit is likely the problem. If it doesn't switch sides when you switch at the head unit, the RCA cables are the problem.
Posted on May 22, 2008
I recently got a JL 300 amp and at first the sub stopped working, then it came back on during the song I was playing. Later on it shut off all together. I don't know what the problem is..
Does it only happen on that channel. It is a 4 channel amp so make sure the other channels are working. It sounds like an RCA input prob. Try the sub on the other channel. if it works then it would be your RCA input needs resoldered.
Sep 04, 2011 | Jl Audio 300/4 Car Audio Amplifier
Which amp goes with 2 jl audio w3v3 4 ohm
Choosing a amp isn't always easy but it first begins with what you want.
--RMS of the speakers is what you want to use to find your amp.
That's going to tell you what watt's your speakers can REALLY handle @ 4 ohms.
--Also what you want to spend $$$ will determine how clear it sounds.
--I prefer a Rockford Fosgate amp for base and kenwood for highs.
--Also look at the RMS watt's rating to find the proper power and go a bit beyond what you want so that the amp performs with ease.
--Last but not least you chose the amp for how many speakers you are going to connect to that amp. For example if you are using 2 JL audio 12" for subs, then a mono amp is perfect. But if you are connecting 4 speakers, you should begin to find the amp with four channels so that you obtain left, right , front and rear sound.
Mar 16, 2010 | Jl Audio Car Audio & Video
USE THE PROCESS OF ELIMINATION. SWITCH THE RCA INPUTS AROUND AND IF THE PROBLEM STAYS IN THE SAME CHANNEL, THEN THE AMPLFIER OR SPEAKER IS AT FAULT. IF THE PROBLEM SWITCHES TO THE OTHER SPEAKER, THEN THE PROBLEM IS THE RCA CABLE OR RADIO ITSELF. YOU CAN VERIFY YOUR FINDINGS BY STARTING WITH THE SPEAKERS FIRST. SWAP THE SPEAKERS AROUND AND IF THE PROBLEM STAYS ON THE SAME SPEAKER, THEN THE SPEAKER IS AT FAULT. IF THE PROBLEMS SWITCHES TO THE OTHER SPEAKER, THEN THE AMPLIFIER OR INPUTS ARE TO BLAME. BY FOLLOWING THESE TWO METHODS, YOU WILL BE ABLE TO DETERMINE EXACTLY WHICH COMPONENTS ARE AT FAULT. REMEMBER, YOU HAVE AN INPUT, AN AMPLIFIER AND A SPEAKER. THIS PROCESS OF ELIMINATION WILL HELP YOU IN THE FUTURE WITH MANY TYPES OF PROBLEMS. LET ME KNOW IF YOU REQUIRE FURTHER ASSISTANCE. I AM LISTED IN THE REPAIR LISTINGS ON THIS WEBSITE......V
PS: MAKE SURE THAT THE GAINS AND BOOST CONTROLS ARE SET TO THE SAME LEVEL FOR BOTH CHANNELS BEING TESTED. ALSO MAKE SURE THAT THE BALANCE CONTROL ON THE RADIO IS STILL SET TO THE MIDDLE. DON'T WANT THESE CURVEBALLS INTERFERING WITH YOUR TROUBLESHOOTING......V
Dec 01, 2009 | Jl Audio 300/4 Car Audio Amplifier
I have 2 6x9 speakers up front 4 6 1/2 3-ways
Hello rjmiller4039,
Although amps with 5 channels are pretty rare, you can get one. Alpine, Boston Acoustics, Infinity, JL audio, MTX, and Polk all have 5-channels ranging in price from around $350 up to around $1,000. The Alpine PDX-5 will output 75X4 watts RMS for the front and rear stereo channels and 300 watts to the mono sub channel. It is priced at $599.99 at Crutchfield.
Hope this helps.
Sep 18, 2009 | Jl Audio 500/1 Car Audio Amplifier
Got jl300/2 amp confused which subwoofer sounds good
Hello drsubhakar26,
JL W6's will perform well with from 150-600 watts RMS. W7's with from 150-500 watts. Less expensive Alpine Type R's work OK with from 200-500 watts RMS. Either of the brands will sound good. None of them will perform to their full potential with 300 watts RMS. Powering any sub with a 2-channel amp is a compromise. A monoblock is more efficient.
Hope this helps.
Jul 12, 2009 | Jl Audio Slash 300/2 Car Audio Amplifier
Jl audio 1000/1 low voltage -keeps shutting off at high volume
You should definitely upgrade the power wire to the sub amp to 4 gauge -absolutely your choking your amp its starving for current-poor thing is starving !!!!!!!
Apr 16, 2009 | Jl Audio 1000/1 Car Audio Amplifier
Setting for...
HI DUDE .. U CAN ONLY SINGLE PC OF JL SUB BY BRIDGE MODE ... COZ UR MTX AMP HAVE 300WATTS RMS ....
Apr 05, 2009 | Alpine MRD-M301 Car Audio Amplifier
Scratchy single channel on amp
I had the same amp! It is the JL 300/4 and one of the chanels came in really fuzzy. It sounded as if the the wires were touching during my installation. I called JL and a JL authorized dealer it would have costed me 190 dollars total to get the amp fixed. Instead I opened up the amp to see if anything looked out of the ordinary. When you open the amp, see if the green fuse looking things are aligned. If they are not aligned then straighten them out. I think they had gotten out of place from being dropped becaue I baught my amp used. My amp works perfectly now!
This is no joke man, I did this just yesterday and was really excited to save 190 bucks. I'm not a technical guy or anything all I know is the green things are located behind the out puts inside the amp.
Jan 09, 2008 | Jl Audio 300/4 Car Audio Amplifier
Lost Right Rear Channel
These are very complex amps that mainly use surface mount components. This amp has 4 vertical boards for the individual channels. It's difficult to work between boards and it's easy to damage the main board if you don't have good quality equipment to desolder them. If you want to learn to repair audio equipment, this is not a good starter amp. I'd suggest sending it to JL or a reputable local shop. If you're lucky, it could simply be a case of a dirty contact on a switch or a switch that's not set correctly. Try moving all of the controls and switches before sending it off for service.
Sep 17, 2007 | Jl Audio 300/4 Car Audio Amplifier
Jl Audio 300/4 Car Audio Amplifier Logo
196 people viewed this question
Top Jl Audio Car Audio & Video Experts
Tygh Duval
Tygh Duval
matthew walsh
Level 1 Expert
Matthew Spark
Matthew Spark
Are you a Jl Audio Car Audio and Video Expert? Answer questions, earn points and help others
