Question about RCA L46WD22 Television
L42WD22- NO SOUND
Sound started getting garbled then went out all together. No audio on any input. unpluging then plugging back in gets sound back garbled and only at very high volume. Tried software update, no help. Any ideas would be helpful since the closest repair center is over 2 hours away.
  • Anonymous Jun 24, 2008
    No sound .
Found a FIX.... Bought a new Sony ... I will never buy another Thompson product G.E., RCA TTE...None of them. The support is a joke. The "warranty" is as dependable as the product. COMPLETELY WORTHLESS
Posted on May 23, 2008
Toshiba TP50G60 50 in sound went out?
check the usual things first:
Speakers in set did not get switched to OFF instead of ON.
If using a box, or receiver that the sound is not turned down or low--not a bad idea to unplug units one at a time and plug back to allow them to reboot.
If set has connections for external speakers make sure they did not (either in menu or rear of set) get set to external.
Look to see if a DVD player or similar hooked to rear audio and video inputs works and has sound.
May 20, 2012 | Toshiba TP50G60 50" Rear Projection...
My 42" tv has a picture but no sound the sound started cracking then stopped and i cant get no audio
Look first to see if you have audio when a DVD etc. is connected to the audio/video input this set has on the rear.
May 17, 2012 | RCA L42WD22 42 in. LCD Television
Pc hooked up but can not get sound
You need to take the PC sound out (green jack) to the TV PC audio input green jack, you will need audio cable with stereo mini-phone plug at both ends. You will need to set the volume level at the PC nad at the TV.
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
Aug 08, 2010 | RCA L42WD22 42 in. LCD Television
Sansui 2000x Phone 1 and 2 inputs produce garbled sounds.
I imagine everything is also VERY LOUD.
Only a Phono (old school turntable) should be plugged into the Phono inputs. It contains a preamp for the tiny signal provided by a Phono cartridge, plus is alters the frequency response drastically to compensate for the RIAA curve applied when they cut the record from tape.
Mar 26, 2010 | Audio Players & Recorders
My Toshiba model number 51H83 has picture but no sound. I put a dvd in and the sound worked but when I went back to TV no sound. I dusted the back of my tv yesterday and since then have had no sound. Tv is...
Are you using the rf antenna input for TV or 1 of the VIDEO inputs from a cable box or sat receiver. If the latter check to see if you unplugged the audio fron the box White and red wires from box. If thats ok Plug that dvd player into that input using the cabes from the dvd player .If you now have sound change ables from box. if still no sound cable box bad. If still no sound from that input check for solder connection on input jacks. If antenna input is used replace the tunner intv.
Mar 25, 2010 | Toshiba 51H83 51" Rear Projection...
TV has no sound
First try resetting by unplugging totally from the AC, then reconnect and try again. if still no audio, check all inputs to make sure its not a bad cable/sat box , next check for a speaker switch either on the back of the Tv or in the menu. make sure the cable box and TV is not in SAP second audio program mode. if these all fail then you make need the audio IC replaced on the main board
Aug 12, 2009 | RCA L42WD22 42 in. LCD Television
Magellan Maestro 4210 no audio or garbled sound
I suggest you take it back to the seloloer before the warranty expires
Jul 20, 2009 | Magellan Maestro 4210 Car GPS Receiver
Microphone(MIC)Of head set not working(got removed wrongly)
This usually just gets reinstalled whenever you restart your computer be it Vista or XP. In your case, the drivers for the Microphone probably got deleted. The Microphone driver comes in the package together with the sound card. You'll have to re-install the whole sound card driver to have it start working again. You can do this from the Device Manager. After doing this, the microphone together with the whole sound card drivers should start working again.
Sep 17, 2008 | ASUS M2N-E SLi Motherboard
No sound and analog channels
THis is been an issue with these sets. Rca has issued a bullteen on these sets.. There is a problem with the digital board. you cant get them... but the fix is to replace a small(very very small ) suface mounted fuse on the board... most qualifed tech can do this repair. so if you can solder surface mounted componets ussally takes twezzers and a big lighted magnifer.. and if you can get the special surface mounted fuse(seems to be a shortage of them) Replacement fuse #275819. u might can fix this. repair is possible
Jun 01, 2008 | RCA L46WD22 Television
Component 1 and 2 audio inputs function poorly or not at all
They get old and get dusty, and with people in the house, things get stuck in those holes that shouldn't be. Try cleaning it out with some dust spray.
Apr 12, 2008 | Vizio L32 32 in. LCD HDTV
RCA L46WD22 Television Logo
352 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
