Question about HP OfficeJet Pro k550 Printer
Paper Jam : feeds through and tears
Paper feeds through and tears on rollers. One set of rollers not aligned. Please find me someone who can assist to get this corrected
    Scholar:
  • 32 Answers
False paper jam hp laserjet 4200
Do you have this problem if you try to feed the paper from the manual paper tray? Does this happen all the time or only once in a while? It may be that the paper feed rollers are slipping and this is throwing off the timing of the printer and it stops because it does not know where the paper is. If the printer will feed fine from manual then check the rollers in the tray 2 cavity. The white cored roller is the pickup roller and the blue cored roller is the feed roller. Clean both with a paper towel dampened with water. Post back what you find and I can assist further.Also make sure that the paper guides in the tray are set properly. The back stop on these trays has a habit of either sliding back or cracking.
Sep 02, 2014 | HP LaserJet 4200 Printer
Paper Jams
The printer should be on,remove the paper from the printer(if there is any),press and hold the down arrow/cancel button, release the button when the power light blinks 3 times ... The printer will rollers will automatically revolce and clear all the jams.. When the power light is green then repeat the same step 3-4 times.. To confirm the paper jam is cleared then feed 8 1/2 * 11 paper in the printer and again press the down arrow button and release the button once the power light bliks for 3 times and then release the button. If the printer feeds properly it confirms the hardware of the printer is fine.
Software issue: Go to printer and faxes in computer and check the icon. If it says.. 0 paper jam then, delete the icon and chcek in the device manager if there is an entry of usb printing support under Universal Serial Bus controller .. if the entry is there then delete it. Insert the printer cd in the computer and unplug and replug the usb cable from the printer. If the setup screen comes up then exit out of it and the printer drivers will get updated. After that tried to print another tets page from the computer. It will definately print.
Aug 06, 2008 | Canon PIXMA iP90 Mobile Printer
Fujitsu fi-5650C Error U1
Hello Ismail,
Error U1 referes to Frequent paper jam in Fujitsu fi-5650c scanner. In order to troubleshoot your scanner issue, you are advised to follow the steps provided below:
1. Do the documents satisfy the paper specification?
2. Have the documents been prepared properly?
- Align the edge of documents for stable paper feeding.
- Remove documents with creases or dog-ear corners.
- Scanning different widths documents may cause skew and result in paper jam.
3. Is the imprinter EXT cable connected to the scanner properly? (only when the imprinter is installed)
4. Clean the Pick roller, the Separation roller, the Brake roller and the Chute roller and see if the error is resolved.
5. Clean the Feed rollers and the Plastic rollers and see if the error is resolved.
6. Replace the Pick roller, the Brake roller and the Chute roller, and see if the error is resolved.
- Check the consumable counter in the software operation panel. When the counter exceeds the values, replace the Pick roller or the Brake roller.
If the above steps do not help, then yuo are recommended to contact the nearest Fujitsu service center for assistance.
Thanks & regads,
ScanCare
Dec 16, 2013 | Fujitsu fi-5750C Flatbed Scanner
Error J1
Hello Sharon,
When a document jam occurs, "J" and "1" will display alternately on the function number display panel of the scanner.Please perform the following:
  1. Remove all documents from the ADF paper chute.
  2. Open the ADF while pressing down the ADF open lever. If you are using fi-6130 with the imprinter option attached, please open the imprinter and then open the ADF.
  3. Remove the jammed papers from the ADF.
  4. Close the ADF pushing the center part of the ADF carefully.
If document jams occur frequently, please check the followings:
1. Do the documents satisfy paper specification?
2. Have the documents been jogged?
• Align the edge of documents for stable paper feeding.
• Remove documents with crease or dog-ear.
• Scanning different width of documents may cause skew and result in paper jam.
3. Are Chuter Unit (ADF paper chute),Guide P ASSY (Sheet guide), Feed roller cover (plate guide) and Brake roller cover installed correctly?
4. Clean the Feed rollers, Eject rollers,Plastic rollers, glass surface and paper feeding surface, and see if the error is
resolved.
5. Replace Pick roller or Brake roller, and see if the error is resolved.Check the consumable counter from the TWAIN driver screen or from the built-in Maintenance mode. When the counter exceeds the values, replace Pick roller or Brake roller.
6. If the issue still persists, then you are recommended to contact the nearest Fujitsu service center for further assistance.
Hope the above information is helpful.
Thanks & regards,
ScanCare
May 03, 2013 | Fujitsu Office Equipment & Supplies
Paper feed issues when there is no Paper jam. All the rollers move when the printer tries to feed paper. It'll feed about and inch and a half of paper and then stop showing a Paper Jam.
85% of paper jams are caused by worn rollers . The rubber treads in the rollers wears down, making them smooth, so they won't pick up the paper. Sometimes, they are aged, which also gives them a smoother rounded texture, causing jams. The quick fix is to liven up that roller with a mixture of alcohol and soap. Damp a rag with the solution and wipe the rollers clean with it. That's make them more pliable and the paper jams will cease. If you plan to keep your printer,
Replace the pick-up and feed rollers.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
May 19, 2011 | Canon PIXMA iP4300 InkJet Photo Printer
My Samsung ML-2010 laser printer grabbed up 2 sheets of paper and now both are jammed. I can't pull them out. Now what could I do?
Removing paper jams from printers can be tricky. You'll want to be careful to not tear off the paper. Always try to pull the paper in the feed direction if you can. The Samsung should have a doo in the back or in the paper area that can be opened to assist in removing the jam. If this persists, you may need to replace the paper feed rollers.
Feb 03, 2011 | Samsung Monitors&Printers Monochrome Laser...
My copier keeps tearing papers.
Paper tears due to the following;
a. Improper paper size on tray
b. Putting excess papers on tray
c. Dirty feed rollers
d. improper jam removal
Rectify the above.
Nov 12, 2009 | Sharp AR-5316 Advanced Digital Imager...
Paper jam is showing on printer info., but ther's no paper jam.
Ok this issue ussually occurs when the roller feed doesn't load the paper due to the following reasons:
1. If your printer is operating for  more than two years or so... gear tear will most likely to occur. If you can open the printer and check everytime the printer initiates after power on ad if the roller feed doesn't rotate but the leftmost rotary gear with the encoder wheel rotates, the gear is most likely to be loose even there is no paper jam nor dust contamination on the rubber and paper feed mechanism. You need to replace the said gear with the encoder strip . A simple solution would be aplying epoxy resin so it will be fixed on the rotary shaft. It may last for quite sometime but better yet replace the gear.
2. The feeder rollers might be dirty and needs to be cleaned and greased the gears.
3. Probable defective print cartridge. Try replacing it with a new one.
But based on the items above, if your printer is operating more than a year or two, and frequent paper jam is being experienced, gear tear near the motor is the culprit.
Dec 17, 2008 | HP PSC 1315 All-In-One InkJet Printer
Carriage Jam
Carriage jams that constantly occur are due to something in the path of the paper or a dirty feed roller. I would inspect it very carefully for any type of ware on the rollers or sticky rollers or anything that could interfere with the path of the paper. Could be at one point someone tried to print labels and one got stuck in there and was never cleaned properly.
Another thing could be something broke off and the feed guide is out of alignment.
Jul 13, 2008 | HP Officejet 7210 All-In-One InkJet...
HP Laserjet 3050 paper jam
The rollers may be worn so it is not getting picked up evenly. Also, be sure that your paper tray in aligned properlyand guides are keeping the paper straight. If both of these seems to be good then there may be something in the paper path.
Jan 16, 2008 | HP LaserJet 3050 All-In-One Printer
HP OfficeJet Pro k550 Printer Logo
172 people viewed this question
Seeker5211
Seeker5211
