Question about LG KU990 Viewty
Private number When i ring someone my number or name will not show up on their phone.
  • noexpert2 May 25, 2008
    I have phoned my service provider and it was a mistake on their behalf. They set my number to Private. Thank you for your help. Much appreciated.
  • 242 Answers
You have your phone set to hide your caller identification.
Go to Menu -> Settings (4th tab) -> Call settings -> Common setting -> Send my number
Select on to show your number to the people you call.
Posted on May 23, 2008
  • Thx_nb May 24, 2008
    Maybe you could explain why you have rated these solutions Thanks for Trying...
    It means that your problem is not solved, so it would be a good idea to post some information.
    If you do have your settings like i told you, there is another problem, but it is most likely not with your phone. You should contact your service provider about your problem.
  • 57 Answers
Its not yours phone or number problem it is their phone problem. if he stores your number without 0(zero) or (country code) then it will not show your name because all the incoming numbers will appeare with +(country code). so some cellphone have that problem so try it by saving your number with country code then see your problem will be solved.
When someone rings me their name or photo comes up, when i ring the phone just goes blank and doesn't show anything,its a lumia 650 thanks
Are you calling yourself from your own number? You can add a photo of yourself too your contact list, if you save yourself as a contact. If you are calling your own number from the same phone it will take you to the voicemail, good luck!
Feb 26, 2017 | Cell Phones
I want my phone to display private caller just to one number
You n3eed to contact your phone service for this.
Sep 22, 2016 | Panasonic Lands Phones
How can i get a another phone number to show up on my phone when i call someone or they call my cell phone
i dont think you can get another number to show up unless you get another sim card but u can put your number on private this is done through the phones call setting under block my number or hide my number along those lines
Nov 10, 2014 | Cricket Wireless Cricket - Zte X501 Groove...
No manual and am receiving unwanted calls at night just became threatening how do i block them
Using Call Block
If you subscribe to Caller ID, you can save phone numbers to the call block list. When a call comes in, the phone compares the received phone number to the numbers on the call block list. If the phone number is on the list, the phone replaces the caller's name with Call Blocked and disconnects the call. (The caller hears a reject tone.)
The call block list holds 20 entries, and all stations share the same list. You can add entries through the Call Blocking menu, by selecting Add Call Block in the CID menu, or by blocking incoming calls. (Only one station can edit the call block list at a time.)
Blocking incoming calls
  1. When the phone rings, wait until the display shows the Caller ID information (usually after the second ring).
  2. If you want to block the call and add this number to the call block list, press Block.
  3. When the phone asks you to confirm, press Menu/select or Block. Blocking an incoming call from an "Unknown" or "Private" number is the same as selecting Unknown Number or Private Number from the Call Blocking menu.
Call Blocking menu options
  1. With the phone in standby, open the menu and select Call Blocking.
  2. Choose one of these options:
  • Create New(Handset only) - Add an entry to your call block list. The phone will prompt you to enter a name & phone number.
  • Private Number(Handset only) - Block all calls from numbers reported by CID as "Private." (This does not count as one of the 20 entries.)
  • Unknown Number(Handset only) - Block all calls from numbers reported by CID as "Unknown". (This does not count as one of the 20 entries.)
Call block entry options
  1. With the phone in standby, open the call block list and find the entry you want.
  2. Press Menu/select to open the individual entry menu. Choose one of these options:
  • Edit(Handset only) - Edit this entry. The phone will prompt you to edit the name & phone number.
  • Delete - Erase this entry from the list & allow calls from this number.
Mar 20, 2011 | Uniden DECT21883 Trio Cordless Phone
When receiving a call my nokia 1661 displays private no even though the number calling is in the contacts list. Any idea what I need to tweak to sort this very annoying problem...?
it is not your handsets issue it is a features where if that particular individual subscribed for his number to be showed as private number to everyone whom he/she is calling. You cannot do anything it will show if that person activated this service and it will not show you the name. ask that person that he/she activated any kind of services for private number.
May 17, 2010 | Nokia 1661 Cell Phone
UNIDEN TRU8888-CALLER ID DOES NOT WORK
Hi
Thanks for using FixYa. I think you have stored more than 100 Caller ID messages and hence the caller ID is not showing on Uniden Tru8888. In the following cases the caller ID will not be shown-
If you answer a call before the Caller ID message is received (for example, before the second ring), the Caller ID message will not appear.
When the call is received via a telephone company that does not offer Caller ID service, the caller’s phone number and name does not appear. (This includes some international calls.)
When the call is via a private branch exchange (PBX), the caller's phone number and name may not appear.
You may receive any one of the following messages:
When a private name is received; Private Name
When a private number is received; Private Number
When a unknown name is received; Unknown Name
When a unknown number is received; Unknown Number
When invalid data is received; Incomplete Data
The Caller ID list stores information for incoming calls - even unanswered calls. You can store up to 100 Caller ID messages and phonebook entries (including Speed Dials) for each handset and the base. You can view the Caller ID list through the handset or base during a call or when the phone is in standby mode.
Memory locations for Caller ID messages and Phonebook entries (including Speed Dials) are common, you can store up to all 100 entries for each handset and the base. Caller ID messages are not stored when you have 100 phonebook entries. When you have stored a total of 100 phonebook entries and Caller ID messages, the oldest Caller ID message is overwritten.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 16, 2009 | Uniden Cordless Phone
Contact Name Doesn't Show Up
If only one number is not showing on your screen it means that you have blocked it with your application or messaging system that you'll need to take the number out of the blocking list. But if this doesn't help you the number itself might have a privacy feature that you cannot see the number itself but just showing private number.
Aug 07, 2017 | LG VOYAGER VX10000 Cellular Phone
I need to block my phone number from showing up when I call someone.
ring up your service provider and get your number set to private
that way your number dos not come up when you call people
Jul 17, 2008 | Lands Phones
LG KU990 Viewty Logo
255 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
