Question about Panasonic NN-S262SF Microwave Oven
Turn table When I turn the turn table off the microwave switches off within 30 sec. Leave the turn table on and it work well?
  • Mell4 May 22, 2008
    Turns off with just one cup of water after 22 sec. Just stops and goes back to the present time display. I can start a new time sequence and it will start up right away. It not like hitting the stop pad because the remaining time is not displayed.
  • William Miller
    William Miller May 11, 2010
    Interesting!
    What are you cooking / heating when it does that?
    Does it do it with just one cup of water?
    Does it do it with several cups of water?
    When it switches off, does it die completely, or just act like someone hit the Stop pad?
    When it switches off can you restart it right away?
  • Panasonic Master
  • 9,098 Answers
The 22 seconds is the giveaway.
In most cases, this is a problem with the inverter or a bad magnetron.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
I would recommend that you contact your nearest Panasonic-authorized servicer. You can find one here.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on May 23, 2008
Sharp microwave & convection & turn table on model R1874F won't work
That would be just a defective secondary interlock (bottom door switch) or its mount.
My help file on door switches is here.
The service manuals you need are here and here.
You can get other Sharp parts from Encompass here or you can call them toll-free at 866-779-5835.
Jan 07, 2013 | Microwave Ovens
Hi, I have a Sharp R-254 microwave and the turn table turns for approx 30 seconds. After 30 seconds it stops and makes a clunking noise, if you open the door and manually turn the glass plate 1/4 of a...
Either the coupler that is located in the center of the oven cavity that the turntable sits on is defective or the turn table motor is defective. . Either repair is rather simple (coupler being the easiest) with parts available online.
Nov 11, 2017 | Sharp R-254 Microwave Oven
Microwave Drum not moving Problem
Remove the plug and take the turn table out of the microwave cabin. Now keep the microwave rested on the side andopen the back pannel,you can see the turn table belt drive.If this is broken replace.if not trace the motor connection and mark them.Now heat the microwave in normal position,place the turn table and a cup of water.Close the door and switch on the microwave set for a minute.Now check the voltage on the motor line marked.If present ,then the motor is fault.If not the controller board is faulty, and must be traced.Can be the relay drive or the relay. hope the other sections are working fine.
Aug 31, 2010 | Microwave Ovens
Microwave settings switch off after 22 secs/30 secs
If it stops after 22 seconds, that means the controller has detected a problem, usually a problem with the inverter, controller, magnetron, or a bad connection from one or the other.
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here.
In Canada, you can find an authorized Panasonic servicer here.
Aug 30, 2009 | Panasonic Microwave Ovens
Tappan TMV151FS over range microwave starts to work and then dies
Never run the microwave without a load (something to heat)!!! That kills the microwave generating parts.
Sounds like a 'thermal' protect switch is activating after running. Make sure that (if the unit is mounted in a cabinet) that there is sufficient space around the unit for proper air flow and that nothing is blocking the vents. Try setting it on a counter top and heat something. If it works properly and doesn't shut off, the venting space is the problem. You may have to have the cabinet that it sits in redesigned for more clearance.
Aug 19, 2009 | Tappan TMT104E1 Microwave Oven
MW 8115 SS Turntable doesn't turn
You probably have a stick door switch or broken door switch mount.
If you or someone you know decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, and our link is at our listing here on FixYa.
Aug 20, 2008 | Emerson MW8108P Microwave Oven
Microwave Oven EM-804T
You need to trace the power feeding the high voltage transfomer. Because the table doesn't turn, it implies that a door switch or safety interlock is the problem.
Jan 01, 2008 | Microwave Ovens
Microwave works for a few seconds and then the lights and turn table inside shuts off.
hi the light and turntable work of a common relay located on main pc board.relay probably dry jointed or sticky or check switches behind door catches
Feb 27, 2007 | Maytag MMV5000 Microwave Oven
Panasonic NN-S262SF Microwave Oven Logo
126 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
