Computers & Internet Logo
Posted on May 22, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Since intalled roxioeasy cd and dvd disc nothing working right it says not compatible with window viista what can i do
Nothing working right since installed roxio cd and dvd disk it said its not compatible with vista what can i do to straighten my computer back up
Anonymous
Level 2:
Champion:
  • Expert 207 Answers
  • Posted on May 22, 2008
Anonymous
Expert
Level 2:
Champion:
Answers
207
Questions
0
Helped
57375
Points
478
Unistall the roxio and try nero 7
Sony DRX840U DVD/CD RW Burner won't play a DVD!
you hvave to check the compatibility first. next is the location rights to play the movie dvd ., other wise., the dvd locks the play.
2helpful
3answers
1helpful
2answers
Dvd/cd is not working
You can follow these methods to try to isolate and resolve the problem. Use these methods in the order in which they are presented.
Method 1: Clean the disc
When you have problems with a CD or DVD drive, always check the disc first to see whether it is damaged or dirty. To clean the disc, follow these steps:
1. Remove the disc from the drive.
2. Clean the disc with a disc cleaning kit or by gently wiping the silver side of the disc from the center outward with a dry, soft, lint-free, cotton cloth.
Note Do not use a paper cloth, and do not use a circular motion to clean the disc. These can scratch the disc.
3. Reinsert the disc in the CD or DVD drive.
If the computer can read the disc, you are finished.
If the computer still cannot read the disc, go to step 4.
4. Try again to clean the disc by using a cloth dampened with water, or dampened with a commercial CD or DVD cleaning solution.
5. Dry the disc thoroughly, and then reinsert it in the CD or DVD drive.
6. If the computer can read the disc, you are finished.
If the computer still cannot read the disc, go to method 2.
Method 2: Check the disc for damage
If the disc is clean, check whether it is damaged. To do this, follow these steps:
1. Remove the disc from the drive, and then examine the disc for scratches or cracks.
2. If the disc is damaged, try another disc to see whether the CD or DVD drive can read it.
3. If the computer still cannot read a disc, there may be a problem with the drive. Go to method 3 to troubleshoot the CD or DVD drive.
If the computer can read the other disc, there is a problem with original CD or DVD. Contact the manufacturer of the damaged disc to obtain a replacement.
Method 3: Try a different disc drive
If the disc is clean and undamaged, check whether there is a problem with the drive. To do this, follow these steps:
1. If the computer has more than one disc drive, insert the disc in a different CD or DVD drive to see whether it can read the disc.
If your computer does not have more than one disc drive, you can insert the disc in a different computer.
2. If the other CD or DVD drive can read the disc, there may be a problem with your CD or DVD drive. Go to method 5.
If the other CD or DVD drive cannot read the disc, the disc may not be compatible with the drive. Go to method 4.
Method 4: Make sure that the disc is compatible with the drive
Check the following list to make sure that the disc that you are trying to use is compatible with your CD or DVD drive.
* A DVD disc is incompatible with a standard CD drive.
* A CD-RW disc is incompatible with a CD drive that does not support CD-RW discs.
* A DVD disc is incompatible with a drive that does not have a DVD logo on the front.
If the disc is compatible, go to method 5.
If the disc is incompatible, use a compatible disc or contact the vendor for a compatible replacement.
Method 5: Use Windows Update to check for updated drivers
If the disc is compatible with your CD or DVD drive, check for updated drivers that the CD or DVD drive may be missing.
Good luck
I have had to replace my hard drive on my pc how can i get my music back on to pc from my ipod and back into i tunes
Backing up your iTunes library to a CD or DVD To burn a CD (CD-R or CD-RW), your computer must have a compatible CD burner. To burn a DVD (DVD-R or DVD-RW), your computer must have a compatible DVD burner. Check in iTunes Preferences to see if a drive is compatible. See below for steps.
To create your backup disc
  1. Choose File > Library > Back up to Disc.
  2. Select the option you want from the resulting dialog and click Back Up.
  3. The two options you can select from are:
    • Back up entire iTunes library and playlists
    • Back up only iTunes Store purchases
    Whichever of these two options you choose, note that you can also choose "Only back up items added or changed since last backup" to perform an incremental backup.
  4. Insert a blank disc (CD or DVD) into your computer's optical drive. iTunes will scan the disc and begin burning.
  5. Note: If the disc you insert does not have enough space to hold all of the content you will be backing up, a dialog will appear asking whether you wish to backup to multiple discs. You can click Data Discs to continue.
iTunes burns the number of items that fit on one disc and then asks you to insert subsequent discs to continue burning the remaining files. Don't eject a disc while a backup is in progress.
Spoken programs purchased from the Audible.com website are not backed up.
Discs you create using the iTunes backup feature can be used only to restore; they can't be played in a CD or DVD player.
Restoring from a backup disc
  1. Open iTunes.
  2. Insert your backup disc.
  3. iTunes will ask whether you want to restore from this disc. Click Restore.
Check drive compatibility
  1. Choose a playlist on the left side of the iTunes window.
  2. Click the Burn Disc button on the bottom right corner of iTunes.
  3. If the drive is listed, it's compatible.
Installing sql2005 in windows7
try this.
1 - start , my computer, right click CD or DVD that you have the SQL , then click explore,
2 look for the setup installation of SQL2005 right click it and go to properties, Next to the general tab is the compatibility tab click it., then checkmark the run as compatibility mode as,
Windows XP or Windows Vista
3 on the bottom checkmark the Run as administrator.
then try intalling it this way.
1helpful
Drive can not read CDs..read Dvds
I suppose that you have windows XP. Pls follow these steps Clean the disc - Clean the disc with a disc cleaning kit or by gently wiping the silver side of the disc from the center outward with a dry, soft, lint-free, cotton cloth. Check the disc for damage - Remove the disc from the drive, and then examine the disc for scratches or cracks. Try a different disc drive - If the computer has more than one disc drive, insert the disc in a different CD or DVD drive to see whether it can read the disc. If your computer does not have more than one disc drive, you can insert the disc in a different computer. Make sure that the disc is compatible with the drive -Check the following list to make sure that the disc that you are trying to use is compatible with your CD or DVD drive.
  • A DVD disc is incompatible with a standard CD drive.
  • A CD-RW disc is incompatible with a CD drive that does not support CD-RW discs.
  • A DVD disc is incompatible with a drive that does not have a DVD logo on the front.
Use Windows Update to check for updated drivers - If the disc is compatible with your CD or DVD drive, check for updated drivers that the CD or DVD drive may be missing. To check for driver updates that you can install, visit the following Microsoft Web site: http://windowsupdate.microsoft.comRegards
2answers
Discs will not format nor will device read or write to disc in any operation
  • make sure that the dics you are working is compatible with your cd or dvd dics drive, if not it will really format or read nor write
  • or else buy a dics (vcd/dvd) that has the same compatibility to your cd / dvd drive
Can't read dvd ram disk
Well not all DVD Rom's are compatible for DVD Ram. Other problem would be the formatting. Windows XP Home and Professional can only write directly to FAT32-formatted DVD-RAM discs. For UDF-formatted discs, which are considered faster, compatible device drivers or software such as InCD or DLA are required. Windows Vista can natively access and write to both FAT32 and UDF-formatted DVD-RAM discs, however Windows Vista uses its own version of the UDF format giving compatibility problems. Vista also has issues with XP formatted FAT32 discs as Vista uses the CPRM features. Even though it is possible to use any file system one likes, only very few perform well on DVD-RAM. This is because some file systems frequently over-write data on the disc and the table of contents is contained at the start of the disc.
3answers
DVD/CD RAM Devices
try some 3rd party software, nero, magiciso, poweriso,,,to burn discs,,,
Or
try using XP service pack 3..
good luck.
Grand Canyon Tech
Grand Canyon Tech
