I have a Maxtor 3000LE. I connected it to my new computer but cant seem to find it under "my computer". when I look up under drives it says is working properly. my new computer is a Compaq presario SR5350F with the vista program.
    Genius:
  • 1,226 Answers
try to do these:
click run
type: "compmgmt.msc" then, enter
you will be bring to computer management window.
find "disk management" and click. on the right corner you see the drive series.
right click and then format the "Uknown disk" or any hard drive added in the list.
remember : the disk you not found on the may computer thats the one need to format.
May this help:
melnavz
PS:
pls do not rate me if my solution not solve the issue and you need more further information. but if is invaluable solution rate me fixya.
Posted on May 22, 2008
Windows vista does not see it
It should see it.
Try connecting it to a different computer, to see if the problem "follows" the Maxtor unit around.
Does it show up in "Device Manager" (under 'Disk Drives' and/or under 'USB devices') ???
Is it brand-new?
Is it "defective"?
Is it still under warranty?
Jan 23, 2011 | Maxtor Personal Storage 3200 (U01E200) 200...
My computer isnt reading my maxtor onetouch 4. i hear the click that it reads but i cant find it anywhere on my computer or disk management. and yes it is blinking. please help, i have 8 years of info on...
If the OneTouch does not appear in My Computer or cannot be found by Maxtor Manager, right click on My Computer icon and select Properties, Device Manager, Disc drives, and expand Disc Drives. There will probably be a yellow overlay over Maxtor drive, to show it has a problem, so right click on it and select 'Choose drivers for this device' to reinstall them. Without going online they seem to be found somewhere locally on the PC and I hope this will do the trick.
Dec 30, 2010 | Maxtor OneTouch 4 500GB External USB 2.0...
My maxtor is not recognized any longer on my laptop..i have owned it for 5 years and have not had this problem before..i checked device manager and it appears to be "functioning properly" but i...
Means only that the plug-and-play hardware has been recognized, and that the correct device-drivers have been loaded. It says _nothing_ about the physical condition of the Maxtor.
An external storage-device has four major components:
* the USB cable
* the power-adapter
* the disk-drive inside the enclosure
* the USB-to-disk-drive adapter inside the enclosure.
One of these components has failed.
Try a different USB cable.
Try connecting to a different USB port on your computer.
Try connecting to a USB port on a different computer.
Take a "multi-meter" and measure both the voltage and amperage output from the AC adapter, and compare with the specifications on the label on the adapter.
Open the enclosure, and remove the disk-drive, and then connect it as a "slave" disk-drive in a desktop computer, to see if it works at all.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Get the part-number and serial-number from the label on your disk-drive, and access the manufacturer's web-site, and use "check warranty status", to see if they will replace the device, at minimal cost to you.
There exist commercial "data recovery" services that can try to repair your device, just long-enough to rescue and copy your files. For example, see: https://services.seagate.com/index.aspx?lng=en-US for a "no data - no charge" guarantee.
Dec 26, 2010 | Maxtor Personal Storage 3200 (U01E200) 200...
I have a maxtor 5000LE the device shows under
Could be that the control board inside the device is going bad. Have you tried other cables to connect to your computer?
If that fails, then I'd suggest removing the drive from it's enclosure and using an adapter to connect the drive directly to your PC as an external device. I found one on eBay, years ago, for about $13USD.
Oct 25, 2017 | Maxtor Personal Storage 5000XT (S01J250)...
Maxtor 3000LE makes noise and will not show up on my computer
You will need a data recovery specialist. Hard drives making noise need to be taken apart and put into a special machine to pull what data is not damaged. The more you leave the drive on or play with it the more data is destroyed.
Jun 18, 2009 | Maxtor Hard Drive
Don't know how to upload data to new computer
Browse to the location on the new computer where you want to save the old data.
Right click and choose New Folder.
Name the folder Files from Old PC
Press enter twice and the new folder will open.
Plug the Maxtor USB into the new computer and turn on the power.
The drive will install and be given a drive letter in my computer.
Browse to the drive in My Computer and double click the Maxtor drive.
Browse to the folder where you saved the old data and open it.
Now do the keyboard command CTRL + A (select all) this will select all the files.
Click one of the selected files & drag them all to the new folder you have open and let go.
All of the files from the Maxtor will copy to your new computer.
Jun 16, 2009 | Maxtor OneTouch III Mini Edition (R01E100)...
Just got new computer w/vista. Cant download maxtor software
Try this link. It has a software for Vista for your Maxtor drive. Download the ZIP version and install it. Hope this works for you .
http://www.seagate.com/ww/v/index.jsp?locale=en-US&name=ot3-emc-vista&vgnextoid=b6623428ab622110VgnVCM100000f5ee0a0aRCRD
May 14, 2009 | Maxtor OneTouch III Mini Edition (R01E100)...
Maxtor external hard drive stopped working
How is it connected ? USB?
If you start w/o Maxtor connection is your PC starting correctly?
Is issue showing when you connect USB cable on working PC?
Jan 04, 2009 | Acer Extensa 4620 Notebook
Maxtor one touch 4 mini makes chirping sounds while trying to link up with the computer , does this for aprox a minute then stops , the conmputer dosnt see the drive.
Usualy this thing happens with my WD Elements drive when the cable is not connected properly or some dust went on the connector, try using a paintbrush and get rid of the dust, sometimes the usb cable's end is corrodated and that's why id doesn't work properly anymore, sometimes it connects and a bit later suddenly it dissapears, this case try another cable. And also a good idea to try out the drive on a different USB port.
If none of these works, try it on a different computer and see what happens there, if it's not working over there with any of these tricks than it's time to bring it back to the shop and use your warranty to get a new one.
Nov 23, 2008 | Computers & Internet
Old Maxtor/New Maxtor
If files you are trying to restore are encrypted you will have to use same software to retrieve them.. If not, any file in the external hard drive should be viewable with your windows explorer.
And U do not need drivers for external hard drives. They just plug into your usb port and work with modern OS after the unit is recognized.
Apr 15, 2017 | Maxtor OneTouch II external hard drive...
Computers & Internet Logo
60 people viewed this question
David Payne
David Payne
