My hard drive runs almost constantly.
When it does, everything slows way down.
The drive is a Toshiba MK 8025 GAS. 80GB with about 1/2 used.
I have 2 GB memory. I rarely use more than 1 GB of the memory.
I have scanned for viruses and Malware.
I have run diagnostic programs on the hard drive and it checks fine
I am running XP SP2.
  • 4 more comments
  • John Christensen May 23, 2008
    I have run sfc twice. It takes 2-3 hours and appears to have made a slight improvement.
    Whenever I run anything with audio/video content, when the hard drive runs, it appears to be stopping the audio/vidio in very short chops at about 10-15 times a second. This causes the A/V to slow down and the the audio to become just a choppy growl. This lasts for 1-10 secomds, 2-3 times a minute.
    Rebooting takes 3-10 minutes with the HD running almost continously.
    The system does not crash, just takes forever.
  • John Christensen May 31, 2008
    The solution provided did not work. I posted additional information a week ago and have received no reply. Can someone else help?
    Thank you but I do not have usoft Office on my machine. I use Open Office.
    Something that may be unrelated but, when I try to bring up the Task Manager I just get a msg "Task Manager has been disabled by your administrator". I am my administrator and I did not disable the task manager.
    This just started 2-3 days ago while the HD problem has been going on for weeks.
    To Ekse: No PIO. Dev 0: UDMA 5, Dev 1: UDMA 2.
    None found on other dev.
    Thank you.
  • John Christensen Jun 01, 2008
    Ekse: The problem with the task mgr is fixed.
    Thank you.
    Each of you have helped a bit. I was waiting until the problem was completely cleared before I accepted. Some of the recommendations took hours to run. I have also run 4 different virus/malware programs, some more than once. Each one discovering different things. I have run 3 different regestry scans.
    I thought the McAfee suite was protecting me but it appears something turned some functions off.
    My last tests today appear that my system is fixed. Thanks to all, I accept.
  • 13,433 Answers
Run CHKDSK /F /X c:
It may be that your harddrive is in pio mode.
read this page
http://winhlp.com/node/10
Posted on May 31, 2008
  • 2 more comments
  • Ekse May 31, 2008
    This might have noting to do with a virus.
    Give me your attention for a minute.
    Open device manager
    (right click my computer -> manage -> on the left side Device manager)
    Open IDE ATA/ATAPI controllers
    Open Primary IDE channel properies
    Open the Advanced settings tab. look at the ide devices.
    Do you see PIO on any device? If not then all is well here
    Open the secondary Ide channel propeties and the advanced settings tab there.
    You can also check this on SATA controllers.
    So did you have any devices in PIO mode? If you did, thats the problem. If not then its something else.
  • Ekse May 31, 2008
    if any devices / harddrives where on pio mode read this page
    http://support.microsoft.com/kb/817472
  • Ekse May 31, 2008
    heres how to enable the task manager
    http://www.fixya.com/support/r569935-tas...
    heres how to enable the registry editor
    http://www.fixya.com/support/r570503-reg...
  • Ekse Jun 01, 2008
    maybe you should try reinstalling your windows? It saves alot of headache and you can start fresh.
    President:
  • 2,712 Answers
Try THIS from the Microsoft Knowledge base..
  • 3 more comments
  • Swilin Sampson
    Swilin Sampson May 31, 2008
    Too many start-up
    programs will slow the boot down considerably, and will consume system resources
    that will slow it down during use. One start-up program in particular, is a anti-virus
    application set to load at start-up, and set to check every file that is opened
    for viruses. This slows the system down, so you should turn this feature off.
    Use an anti-virus program to scan downloaded files after that have been downloaded,
    scan the hard disk drive periodically, scan CDs that will autoload, and scan e-mail
    attachments. There is no need to have it set to scan the system the whole time
    it is operating.
  • Swilin Sampson
    The
    most likely reasons for a system slow-down or a 'thrashing' hard disk drive are
    an outdated, slow hard disk drive that has outdated drivers installed, has become
    crammed with applications, is overloaded with programs loaded at start-up, as
    a consequence has a Windows Registry that has grown bloated with redundant
    entries, or a system that has insufficient RAM, either on the motherboard as system
    RAM, or on the video card as graphics RAM, a dying BIOS battery, or a failed processor
    fan.
    Most of these problems are easy to remedy. First try updating
    your video card's and hard disk drive's drivers by downloading them from the manufacturer's
    website, and then use the Windows Add/Remove
    utility to remove unnecessary applications, clear the Recycle Bin, and
    then use the Windows Disk Defragmenter (or your own third party program)
    to defragment the disk. The Add/Remove utility can often leave whole folders
    intact, so open Windows Explorer, and remove any left-over folders
    manually. You can download many Windows Registry cleaners.
    RegSeeker
    is a good free Windows Registry cleaner, or visit majorgeeks.com, zdnet.com,
    or tucows.com for other cleaners and program installers/uninstallers.
    Some
    of them will also be able to find unnecessary files that can be removed, such
    as the .tmp files that Windows or applications create and leave in the
    Temp folder - and elsewhere.
  • Swilin Sampson
    See if you have any of the following 2 processes running and stop them: SSDPSRV and LOADQM.
    I would also recommend running a full system scan at this FREE online antivirus scanner:
    http://housecall65.trendmicro.com/
    It is extremely efficient and sometimes finds malware undetected by more popular and famous AV software. Try it, it could help
  • Swilin Sampson
    It definitely looks like a virus issue. Could be the Worm Klez.H or Joke Train.A virus.
    FIrst disable the System Restore or the system will be reinfected via Restore files. Re-enable it after the virus is removed.
    Disable Restore:
    Click Start > Programs > Accessories > Windows Explorer
    Right-click My Computer, and then click Properties.
    Click the System Restore tab.
    Check the "Turn off System Restore" or "Turn off System Restore on all drives" check box.
  • Swilin Sampson
    Swilin Sampson Jun 01, 2008
    Shouldnt you be "accepting" the solution of the Expert who guided you best to a fix ?
    Master:
  • 555 Answers
Run "sfc /scannow"
Posted on May 22, 2008
Machine will not start when required, circle timer keeps spinning. Will start after hard close.
if your HDD is a refurbished drive then it may still have faulty sectors. try a new hard drive and if still doesn't work try changing the ram you are using it may still appear as if its working but is causing processes to hang
Jan 05, 2014 | Lenovo ThinkCentre M57 Desktop - Intel...
Can i add more memory to a sylvania netbook synet582
yes you can max memory 2 gig i just put 1 gig in mine make sure its DDR2 sodim 667 MHz it only has one slot its under the small cover on the back
Jan 23, 2012 | Sylvania Meso 1.6 Ghz Intel Atom 1 Gb 80gb...
I have been given a Toshiba MK 4025GAS laptop, it has 240 MB of RAM. How much more RAM can I put on it?
click start right click on my computer select properties you should how much ram you have installed and how much available it looks like it is capable of 4GB of ram remember when adding more ram try to keep the same brand/type as some motherboards will only work with the one type of ram together and always place the larger ram closest to the cpu central processing unit
Toshiba Mk4025gas Pm ... Shipping: FREE Total: $98.72 Memory Specifications Module Size(s): 2x4GB Type
CPU
Intel Celeron M 370 1.50GHz BIOS Phoenix BIOS. Press F2 to enter Chipset SiS 661 Memory 512MB PC2700 DDR SODIMM (2 memory slots. Max 2GB) ** Hard Drive 40GB Toshiba MK4025GAS CD Drive Philips DVD+-RW SDVD 8441 Screen 14" TFT (Native Res.1024x768) Video Card SiS 661FX (64MB shared) Sound Card Realtek AC'97 audio Network Card SiS 900 integrated fast ethernet
Atheros AR5BMB5 Wireless LAN * Modem Agere systems AC'97 modem Ports 1x Headphone
1x Microphone
1x PC Card
4x USB 2.0
1x Modem
1x LAN
1x VGA
1x S-Video (TV-Out) Touchpad Synaptics Touchpad Battery SQU-504 (11.1v 4400mAh) Dimensions 33 x 314 x 258 (HxWxD in mm) Weight 2.3kg Made By Quanta LE1D
The full system specs are:
CPU: AMD Sempron LV 3000+ (1.8 GHz.)
RAM: 1 GB. DDR-333, Kingston
Chipset: ATI Radeon Xpress 200M (RS480M/SB450)
GPU: ATI Radeon Xpress 200M
HDD: Toshiba MK4025GAS (40 GB., IDE, 4200 RPM)
ODD: TSSTcorp Combo (DVD-ROM/CD-RW 8x24x24x24)
Other:
- Texas Instruments UltraMedia Card Reader PCI xx21/xx11
- Broadcom 802.11g Wireless LAN
OS: Windows 7 Ultimate (32 bits, obviously
as you can see there is a contradiction in how much ram but if its a windows 7 it will need a minimum of 2 gb of ram but it could use 4gb
hope this helps
Jun 17, 2011 | Toshiba MK4025GAS (c99529) 40 GB Hard...
Samsung 80gb hard driver looks 30 gb why ?
it may have been partitioned to be 2 seperate drive partitions. When a drive is first formatted, you can cut it up into seperate pieces.
explore your computer and add up your drives and gigs.
If not, then the Bios needs to be manually changed for that drive, but in todays modern computers this is rare.
Thanks,
James
----PLEASE CLICK ON 4 THUMBS UP 4 ME!!----
Apr 25, 2010 | Samsung SpinPoint SV8004H 80 GB ATA-100...
I have an AMD Sempron which I was told came with 40GB. My computer has been running slow and acting strange. When I went to My Computer and clicked on properties i discovered the following: Used Space 36.4...
The most common reason for slow processing speed is insufficient RAM memory.
Increase the RAM, if RAM available is no more than 512MB, then it must be upgraded.
Check also your hard drive state. If you have less than 1GB free, that will slow down the system. Go to Start>>Programs>Accessories>System Tools>Disk Defregmenter and do a Defrag of the hard disk.
If you have at least 1 GB RAM, and you took care of the hard drive, then you can check the process starting up on their own and remove the useless one, or spot mala-ware that can affect speed. You can use a software like Hijack This, and search on google te function of each process started on the list reported by the software.
You can download Hijack this here MajorGeeks | If download does not start, then click at the top of the page, where it says Click Here If It Does Not.
Be careful if you delete the wrong files using this software you can harm the system, and Windows may not work properly.
If you think you have malaware you can also install Spy Bot, and do a system scan. Download Spybot from The home of Spybot.
If all the above does not work, and there is no malaware, then you usually reinstall the system.
Check also the bios settings, BIOS can downgrade the CPU speed on default , even if this is uncommon on recent BIOS.
If a computer is still slow with a fresh system and enough resources then it is one of those rare occasions when you have an hardware fault.
Hardware that can cause slow down is: RAM CPU Motherboard HD Video card.
Some tips on procedure can damage your windows installation. Do not download Hijackthis software and do not change BIOS settings and do not touch hardware unless you are sure of what you are doing.
Mar 17, 2009 | Samsung SpinPoint SP6003H (SP-6003H) 60 GB...
I upgraded the memory from 1Gb to 2 Gb but my laptop's still slow
it can't be, check if the windows is reading 2gb from system under control panel.
to find out if your pc is fast, see if it plays a game faster than before or use a program faster than before
there is no diffrence in using windows itself. example i think in your mind you'd expect to click on my documents and it loads it super fast now with 2gb of ram? no, you're wrong weather you have 1gig or 2gig windows still works the same
the diffrence is Faster file transfer, faster applictions but not a faster windows.
it could also be the norton if you installed, it lowers your speed.
check Task manager, in the performance section
cpu usage should be under 10%
and pf under 500mb
Mar 03, 2009 | Toshiba Satellite M55-S3512 Notebook
Asus A7N8X-X (third memory slot)
Sounds like either a bad stick of memory or a bad dimm slot . Have you tried the memory on another motherboard ?
Jul 18, 2008 | ASUS A7V8X Motherboard
Computers & Internet Logo
140 people viewed this question
David Payne
David Payne
