Message "Read access error ! Cant read from hard drive" is displayed when I switch it on
SOURCE: Format Hard Drive Error
If the unit detects any form of Hard Drive Error it asks you to format the drive. Connect the unit to your PC and run ScanDisk or DOS Chkdsk on the drive. Will help to rectify any issues with the FAT. Windows XP & 2000 Running Check Disk Utility (ChkDsk) ? HARD DRIVE mode only If you still have problems with the file system on your AV 500 you can try to fix it using the DOS utility, check disk (chkdsk). Do the following; ? Make sure external AC adapter is powering the AV 500. ? Quit all running applications. ? Properly connect the AV 500 to your computer ? Wait patiently (up to 5 minutes) for Windows XP to show the local drive as mounted. ? Open a DOS window. Programs > Accessories > Command Prompt. ? At the prompt, type chkdsk e: /f . Use e: or f: or whatever drive letter is representing your AV 500. The /f argument tells the program to automatically fix errors. ? Be patient, this may take a while. ? When finished, exit the DOS Window and properly disconnect the AV 500 from your computer. Now try using the device. DO NOT try to defrag the drive. Let us know how you get on.
SOURCE: Klackitey Klack
If the drive is ticking, it suggests the actual HDD is dying. You can try the following to see if you can fix any disc errors through your PC, however if your PC does not recognise a drive has been attached you may be unable to do anything other than have it repaired elsewhere. If you have problems with the file system on your Gmini you can try to fix it using the DOS utility, check disk (chkdsk). Do the following; ? Make sure external AC adapter is powering the Gmini. ? Quit all running applications. ? Properly connect the Gmini to your computer ? Wait patiently (up to 5 minutes) for Windows XP to show the local drive as mounted. ? Open a DOS window. Programs > Accessories > Command Prompt. ? At the prompt, type chkdsk e: /f. Use e: or f: or whatever drive letter is representing your Gmini. The /f argument tells the program to automatically fix errors. ? Be patient, this may take a while. ? When it is finished, exit the DOS Window and properly disconnect the Gmini from your computer. Try using the device now and see if makes any difference. This method should help to fix any disc errors that have occurred within the FAT and help your PC recognise it again. If you have more problems, try formatting it using a DOS prompt. You MUST make sure NOTHING is trying to access the disc before you can format it - this includes windows explorer.
SOURCE: Archos AV700 I/O Error
Offhand, I would suspect that the remaining files were somehow corrupted. Is it possible for you to verify those files using the external HD and a PC?
Either that or the format of the Archos AV700 was not that "clean" and would require a redo.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
SOURCE: i have a archos av400
If it is a av400 series
plug it into the computer and attempt to format it.
If it fails its a very high probability the hard drive has failed.
there is a slight possibility its the ribbon cable that connects the drive to the main board or the controller in the archos so I would check the drive after removal and prior to buying a new one.
this can be done in a usb caddy or with a 3.5" to 2.5" converter (about $5 on ebay) letting you put the drive in a PC for testing.
If its above 40gb any 2.5" laptop drive upto 100gb can be fitted.
If its a 20gb you need a single platter 1.8" ata drive
any further questions just ask
I have an Archos AV500 which is basically the same as the AV700 but with a smaller screen... sometimes Im getting the "Read access error ! Cant read from hard drive" problem and does not boot... but other times it start just fine... with all my files in it....
Is the Hard Disk Drive going bad...?
