Question about Lands Phones
Accidentally locked my home phone
It is a Sanyo CLT-D14 twin hand set. I was trying ot pu new batteries in it. I was pressing keys.. I can't find my manual to unlock it now and I can't receive or make phone calls. Help me please !!
Regards
Carole
Hi I found the manual. All that was required was to hold the * button down. Easy when you know how!!! Thanks anyway.
Posted on May 22, 2008
Hi.. I have a alcatel OT 4010x and i cant get my unlocking code anywhere.. Provider ID 4010X-2CTWIE1... Network is Tesco Moblie... And i live ine ireland... So if you can get m
There are 2 methods to make factory data reset on your phone:
Method 1: Under power on mode
Please go to menu > Settings >Privacy >Factory data reset
Method 2: Under power off mode
Turn off the handset, press the volume up key and the Power key at the same time for a few seconds until you see the reset interface, then press Home key >select wipe data or factory reset via volume key > Press Power key to confirm > Select Yes to delete all user data > Press Power key to confirm again > Please select Reboot system now and press Ppower key to confirm to reboot your phone. The handset can be used without screen unlock pattern after its reboot.
Please note that factory data reset will erase all data from your phone. If you want to quit it before performing factory reset, you can select Reboot System Now or remove the battery and re-insert it, then restart the phone
Feb 02, 2015 | Alcatel Cell Phones
I PUT A SERCITY CODE ON MY PHONE AND I FORGOT IT
Lock or unlock your smartphone
You can lock the keyboard to avoid pressing it or making calls accidentally and, if you have set a BlackBerry smartphone password, you can also lock your smartphone with a password.
Do one of the following:
  • To lock the keyboard, press the alk1319565787328_lowres_en-us.jpg key on the top of your smartphone.
  • To unlock the keyboard, press the alk1319565787328_lowres_en-us.jpg key again.
  • To lock your smartphone with a password, on the home screen or in a folder, click the alk1319565807422_lowres_en-us.jpg icon.
  • To unlock your smartphone, enter your password.
Apr 21, 2013 | Blackberry Curve 9310 Boost Mobile
My alcatel OT-906 phone is not opening
Hello My Dear:
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Dec 26, 2012 | MOBILESW Alcatel OT-906 2.8" Resistive...
What is emergency calls
YES you can unlock it yourself but unfortunately you will have to reset it and lose all your apps/pics etc.
1. switch off. Hold volume UP and power button and home button simultaneously. release home button (and press again) while still holding volume up and power button. A boot up screen will pop up. Use volume keys to select (reset and restore) press home button to select.
2.Once reset and the phone starts up again it will still show locked. Get another phone to call your phone. as soon as you swipe answer press back key (arrow key) (you gotta be quick) and the main home screen will come up!!! . press the left menu button and select settings and turn off pattern code then go to menu and factory reset the phone again.
It worked for me ,.. hope it works for you too
Apr 17, 2012 | Samsung Galaxy Y
Sanyo cordless model no CLT-79 a peep sound comes when i press the call bottom
Sir, I've lost hand set of SANYO CORDLESS TELEPHONE and modle no. is CLT-79, How will i get the same ? pl. hlep.
Oct 28, 2010 | Sanyo Cell Phones
Locked myself out of my mogul
You may have to do a hard reset.
You do this by:
Holding down both left and right soft keys (the buttons above the red and green phone keys) while pressing the reset button (on the bottom of your phone) with the stylus. Hol down the soft keys until you see a message asking if you want to reset. You then need t slide the keyboard open and press the appropriate key.
Warning: this will reset your phone to manufacturers settings; all data will be erased. Your phone, however, will no longer have a password, and you will be able to set a new one.
Feb 13, 2009 | HTC PPC-6800 Smartphone
Sanyo CLT 947
Two solutions. Replacement rubber key pad membrane or re-apply conductive coating.
1) Call Sanyo and see if they have a replacement rubber membrane keypad for your model of telephone. (I replaced the keypad membrane on my Sanyo CLT-2430 cordless phone). In Canada, the Sanyo telephone number is: (905) 760-9944. Their web page is: sanyocanada.com.
2) A rubber keypad repair kit is available from MG Chemicals. Rubber Keypad Repair Kit 8339.
This kit is described on their web page: http://www.mgchemicals.com/products/8339.html
In Canada, this keypad repair kit is available from ElectroSonic. See a description of this kit at: http://www.e-sonic.com/acc/products.aspx?command=detail&partID=8339&partIDExt=281
In Canada, this keypad repair kit costs about $14.00.
Apr 22, 2008 | Sanyo CLT-A902 Cordless Phone
Flash time setting
I'm trying to find out what flash time is. I have a KXTGA 550M. In menu, initial settings, set tel line, set flash time: there it has settings 700ms-90ms. What does this affect?
Jan 19, 2008 | Lands Phones
Keys will not work
Sounds like you locked the keypad.
I know you stated all the keys don't work, but let's give this a try.
Press the "unlock" key (the key in the upper left)
Enter your lock code (usually 0000)
Let me know if this helps.
Jan 11, 2008 | Sanyo MM-8300
Lands Phones Logo
100 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
