Question about Mitsubishi WS-55511 55" Rear Projection Television
MITSUBISHI WS-55511
TV WILL NOT COME ON When plugged the power lite on the front just blinks continuously.  Have no remote.  I'm new to TV repair but have a long history with PC's.  So point me to the parts to check and I should be able to find the problem.
    Genius:
  • 1,226 Answers
Try to fix and resoldered cable connection from specifically on the horizontal and vertical panel. there some loss connection it it. but if this not solve the problem you need to test the voltage regulator that regulate the power to project the picture.
may this help,
melnavz
Posted on May 22, 2008
  • Emelio Navaja
    Emelio Navaja May 22, 2008
    warning: high voltage inside the TV.
Tip
Reset Mitsubishi HDTV VChip Password
Bypass or Reset Mitsubishi HDTV V-Chip Password Lock
Models: WS-B55 / WS-48511 / WS-55511 / WS-55711 / WS-65511
Models: WS-65611 / WS-65711 / WS-65712 / WS-73711
Would you like to bypass, defeat or reset your Mitsubishi HDTV Parental V-Chip parental lock? Have you forgotten your V-Chip passcode or password?
If you forget your V-Chip passcode, you can view the locked TV without entering your password.
When your passcode is requested, press the number 9 and the QV button on the original TV remote control at the same time. This process temporarily unlocks your TV.
When you enter the V-Chip Lock menu, pressing the number 9 and the QV button on the original TV remote control at the same time will delete your old password and prompt you to enter a new passcode. Pressing HOME at this time will cancel the entire passcode.
I hope that helps.
________________________________________
Bypass Mitsubishi HDTV Front Panel Lock
Mitsubishi WS-55511 Manual Download
on Apr 30, 2010 | Mitsubishi WS-55511 55" Rear Projection...
Tip
Bypass Mitsubishi HDTV VChip Password
I hope that helps.
I have a mitsubishi model WS-55511. The green light keeps blinking. Have reset by unpluging and then pluging back in and holding the reset but for 5 seconds and press the power button. worked once, but...
TWO possible reasons for the blinking light:
1. The DM unit (caps and or fuses) are bad---no longer made and only (to my knowledge) PTS electronics repairs/rebuilds them.
2. Less likely but Possible: remove front speaker grill and inspection plate behind it----locate the two bundles of wires from front keyboard on set and follow them down and to the right---unplug both plugs and plug set in and wait 70 plus seconds and try to turn set on with Mitsubishi remote.
The blinking light is the DM trying to boot up--if set works with front keyboard unplugged---the tiny reset switch on it is bad.
If set does NOT work that way DM UNIT IS BAD.
SD TECH
May 03, 2011 | Mitsubishi WS-55511 55" Rear Projection...
We just got a used Mitsubishi WS-55511 55in. Rear projection Television. There is a green light blinking on the front by the power button, and the tv does not come on?
very easy repair caused by failed DM capacitors. You can get the WS55511 DM repair kit from www.tvrepairworld.com which has the upgraded capacitors and the CD with repair instructions which should solve that issue.
Mar 03, 2011 | Mitsubishi WS-55511 55" Rear Projection...
Mitsubishi ws-55511 does not turn on
Listen: you need to wait for the set to first shut off! then push on the TV(not the remote) Input and Menu both at the same time for 5 seconds and then release---the power light will then blink---this model has this feature--
Sep 13, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Your Solution to the WS-55511
There are 2. One controls the front panel and the other controls the front output. Unplugging it will not interfere with the remote. In fact, you will only be able to operate the tv with the remote. Let me know how you make out. Incidentally, I sent an email off to Mitsubishi and surprisingly they got back to me in a day. I informed them about the problem all these people are having and they are actually looking into it. They even offered to pay for my new front panel. Go figure!!
Nov 06, 2008 | Mitsubishi WS-55511 55" Rear Projection...
Mitsubishi WS-55511 Problem TV out - Getting only continously blinking green light on the front-panel
I had the same problem with the blinking light on the front of the TV and it would not power up. I read all the problems everyone was having and thought I was going to face a huge repair bill. The service guy came out, pulled off the front panel where the speakers are and disconnected the circuit for the front display panel. 3 1/2 minutes in my house, $90 service call. Apparently, when you give the TV too many commands at once, it's safety feature is to"shut down and lock up". He mentioned also that sometimes when these sets get to be about 4-5 years old, the wires in front can "leak" causing a shortage and then locking up the TV. I keep the circuit unplugged and operate the TV solely by the remote. Give it a try, what can it hurt!! Hope this helps.
Oct 05, 2008 | Mitsubishi WS-55511 55" Rear Projection...
Mitsubishi WS-55511 55" Rear Projection Television Logo
56 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
