Question about Samsung Yepp YH-J70 Digital Media Player
Samsung yh-j70 how do you replace the battery?
Battery life is getting less and less, now down to 2-3 hours of playing. Has anyone replaced the battery by themselves and could give (hopefully simple) instructions of how to do it? Pictures would really help, of course. The player was expensive, so I don't want to mess with it without some info on where to go. Anyone know where to find a replacement battery? Thanks, Anne
  • marezathus Jun 01, 2008
    I"m interested as well. I found an adress in Holland: www.selectro.nl, where they sell for €64,84
    For further information see:http://dapreview.net/p/forum/forum_viewt...
  • balimack Jul 27, 2008
    I require a new battery and I cannot get one in Australia can you give me some advice
Replace charging wire
Posted on Jun 10, 2008
Tip
Make your Lithium Laptop Battery last longer.
Hello folks,
Although I usually offer advice on backing up files or recovering them, I have been asked a lot lately how my 3 year old laptop still runs 1:45mins on a standard battery when many peoples 1-2 year old laptops can barely last an hour.
Simply put, most people do one of two things wrong. Both are common misconceptions and easy to remedy. First I've heard countless people tell me they pop the battery out of their laptop and toss it in the desk drawer until needed, often months. Second I have been told by more people than I can count that they leave their laptop plugged in 24/7 for most of the year.
Bottom line, although popping it out and leaving it in the drawer is less harmful to it's lifespan, both ideas are wrong.
The shelf life of most unused lithium batteries is shorter when unused than ones being used properly. The lifespan of a battery that is constantly being trickle charged is even shorter.
Most batteries in modern laptops are 4-6 cells, designed to give about 2 hours of charge and should last 3-5 years with charge life starting to degrade in the third year.
A "stored battery" has only 3 years of shelf life due to extended times sitting discharged and one that is trickle charged 24/7 may burn out in as little as a year.
Many laptop manufacturers have taken measures to improve this but ultimately the best thing for your battery is to use it. If you currently run you laptop plugged in 24/7, unplug it every night after you shut it off, then when you start it in the morning, let it run an hour before plugging it back in. This will give the battery both down time and exercise.
If your battery is in a drawer somewhere for safe keeping, put it back in the laptop, run it down then charge it over night and run it down then recharge it one more time. Store it back in the drawer charged and repeat the cycle at least once a month.
These tips will help drastically improve you batteries performance over time. My 3 year old laptop only ever got 2 hours of battery life and still gets 1:45 with no power saving measures, give it a try.
Crankstart
on Mar 20, 2010 | Computers & Internet
My sons rca 10.1 tablet wont power up.....right before this happened it was froze on the start up screen and wouldnt power off. I let the power run down hoping then I could charge it and it would power up...
Lithium ION batteries are usually rechargeable. The use mode for these batteries is that there are a set number of recharges that equate to the life of the battery. Usually that life is approximately 1,000 charges.
If you use your battery to 50% then recharge, you can do this ~2,000 times. As the life of the battery is used up, the maximum charge lessens which means where you may have had 8 hours of play time when the battery was new, you will only have 6 hours as the battery life is used up.
In order for a Lithium ION battery to recharge there must be at least a small amount of charge left as a "seed" for that recharge. If you drain a L-ION battery down to zero, it may never recharge again or the max charge will be reduced to an insignificant amount of the original full charge. eg instead of 8 hours you may only get 15 minutes, or 5 minutes, or no minutes.
You are much better off recharging when 50% depleted than using it up til your product stops.
L-ION batteries cannot be repaired only replaced. Most cheap products using L-ION batteries cannot have their batteries replaced.
Jan 19, 2015 | Tablets & eReaders
Hi My battery runs down after half an hour It seems it needs a new battery, are they easy to fit? or do I need to send to Samsung. Thanks P
Yes sounds like you need a new battery. Some are soldered in, others have a wire clip that can easily be removed and replaced.
Dec 31, 2010 | Samsung Yepp YH-J70 Digital Media Player
Insignia p1020 plays for approx 1/2 hour when plugged into car adapter then shuts down. After restart, plays for about 15 min then shuts down,
There are a couple of possibilities: the battery is failing or your car adapter isn't working properly forcing the unit to play from the battery. First, try removing the battery and playing from the adapter. Also, try using the player from battery alone to verify that you're getting the expected battery life. If it turns out you need to replace one or both parts, you can purchase them here. I hope this helps.
Sep 23, 2009 | Insignia I-PD1020
Battery life seems fairly short. How long should
In most laptops the standard idle life is around 3 - 4 hours. The drain from the internet can cut this down to between 1 - 1 and a half hours. Using games is around the same or less than what the internet takes and if your using an office application it is around 3 - 4 hours.
Using the laptop for power hungry multitasking will reduce battery life dramatically.
Regards.
Aug 18, 2009 | Acer Computers & Internet
Asus Eee PC Series 1000he Battery Life
You can try to completely discharge and recharge a few times to take it through its full cycle. However, you probably won't get much improvement. Batteries wear out with time and, after one year, I'd expect to see significant capacity loss on a machine such as this with typical usage patterns.
Aug 05, 2009 | ASUS P5PE-VM Motherboard
Battery Life Shortened
i have the exzact same problem with my laptop but its coz when u watch a movie, play games, listen to music or if ur using up a fair bit of memory it takes up battery life to store it all
Jul 24, 2009 | LG Dare VX9700 Cell Phone
No battey Life
check the factory specified details of the battery
Jul 07, 2009 | Samsung SGH-t819 Cellular Phone
Samsung Yepp YH-J70 Digital Media Player Logo
672 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
