Question about Canon PIXMA MP210 Photo All-In-One Printer
Ink cartrige placment
How do you put the ink cartride in its slot the direction say to put down push back pull forward every single time i try to do that it wont snap into place
  • 2,122 Answers
Make sure that the unit is powered on. Open the top and wait for the cartridge holder to move over to the left side. If it won't move, check to see if there is anything blocking it. Once the cartridge holder has moved over to the left, then put the cartridge in and lift up on the edge closest to you to lock it into place.
Posted on May 22, 2008
Not print magenta or yellow
If you use CISS system. The problem may occur CIS. To solve these follow this proces:
1. put out cartrige from cartrige carrier
2. put a plastic seringe into the hole of the cartrige and try to out the ink from inside the cartrige ( mainly magenta or yellow)
3. Then run a head clean.
If result is No Try these:
1. Put off cartrige from cartrige Carrier
2. find out 4/6 stick inside the carrer
3. put a plastic seringe one after and push air on it.
4. After that take a seringe with ink and push it gentally into the stick.
I think you will be rid from your problem.
Thank you.
Jun 02, 2013 | Dell p713w AllInOne InkJet Printer
Hp officejet j3500- refer to device documentation to troubleshoot
problem with any one of your cartrides. open the carridge door and renove color cartridge and close it.if it says insert left cartridge then it could be the problem with color cartrige.or the same error come then put the color cartridge and remove the block cartrige.if display says insert right cartridge then it could br the problem with black cartridge.try clesn the cartridge contacts & ink nozzles and put it back (use a soft cloth to clean the cotact)
Aug 04, 2011 | HP Office Equipment & Supplies
Please let me know the direction of cartridges
You can follow the steps below to replace your ink cartridges.  Feel free to click on the link at the bottom to pull up a document that gives you information including pictures on how to replace the ink cartridges.
To take out the old ink cartridges:
When replacing the tri-color print cartridge, remove the print cartridge from the slot on the left.When replacing the black or photo print cartridge, remove the print cartridge from the slot on the right.Pull the print cartridge toward you and out of its slot.
To install new ink cartridges:Remove the new print cartridge from its packaging.Remove the plastic tape by using the pink pull tab.Slide the new print cartridge forward into the empty slot. Then gently push the upper part of the print cartridge forward until it clicks into the socket.When installing the tri-color print cartridge, slide it into the left slot.When installing a black print cartridge, slide it into the right slot.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00620122&cc=us&lc=en&dlc=en&product=1138373&tmp_track_link=ot_search
Apr 19, 2011 | HP Officejet 4355 All-In-One InkJet...
Need to find out how to put ink cartrdiges back into hp 5610 all in one printer.
First, turn the printer on. Open the print-carriage access door by pulling it forward. The print carriage moves to the far right side of the HP All-in-One. Wait until the print carriage is idle and silent, and then lightly press down on a print cartridge to release it. If you are replacing the tri-color print cartridge, remove the print cartridge from the slot on the left. If you are replacing the black or photo print cartridge, remove the print cartridge from the slot on the right Pull the print cartridge toward you out of its slot.
Now we're ready to install the new cartridge. Remove the new print cartridge from its packaging and, being careful to touch only the black plastic, gently remove the plastic tape by using the pink pull tab. Slide the new print cartridge forward into the empty slot. Then gently push on the upper part of the print cartridge forward until it clicks into the socket. Close the print-carriage access door.
Mar 21, 2011 | HP Officejet 5610 All-In-One InkJet...
How do you place cartrige in printer
Step eight: Install the cartridges
  1. Raise the top cover of the product. Figure 5: Raise the cover c00830210.jpg
  2. Remove the new cartridge from its packaging and, being careful to touch only the black plastic, gently remove the plastic tape by using the pink pull tab. Figure 6: Remove the tapec00442146.gif 1 - Copper-colored contacts 2 - Plastic tape with pink pull tab (must be removed before installing) 3 - Ink nozzles under tape CAUTION: Do not touch the copper-colored contacts or ink nozzles. Touching these parts can result in clogs, ink failure, and bad electrical connections.c00442147.gif
  3. Slide the new cartridge forward into the empty slot. Then gently push the upper part of the cartridge forward until it clicks into place.
    • Slide the tri-color cartridge into the left slot.
    • Slide the black or photo cartridge into the right slot.
    Figure 7: Insert the cartridgec00830211.jpg
  4. Close the cartridge door. Figure 8: Close the cartridge doorc00830212.jpg
Aug 08, 2010 | HP Officejet 5780 Printer
Even though I have install the ink cartride
Hi there please try this.
Error 1203 is an issue that occurs either when a cartridge is bad or the printer cartridge Slot is bad...
1 - try cleaning the copper contacts of the both carts and cart slot in the printer and try again..
or
2 - when error shows up, shut the printers power off; wait one minute and turn it back on press copy.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Jul 01, 2009 | Dell 924 All-in-One InkJet Printer
I can't arm my rifle 66 powermaster
there is a slot that says open open it and put bbs in.. close it ther is a switch on top pull it back... turn the gun upside down and shake it... push the button up... pump 3-15 times and pull back bolt... and push forward thenturn safety off and shoot
Apr 07, 2009 | BSA Air Gun Scopes
CANNOT CHANGE INK CARTRIDGE,CARTRID GE IS ON FAR LEFT SIDE OF PRINTER SO THAT i DO NOT HAVE ACCESS TO IT. iT IS A MODEL 8300.
turn off machine, open and get a knife (or something flat) and put on top of the cartridge and push down, then try pulling to the middle.
The problem is that somehow the latch that holds the cartridges is open.
Aug 20, 2008 | Lexmark Office Equipment & Supplies
Installing an ink cartridge
I struggled with this for ages! I thought there is no way this cartridge will slot into this printer!!
you have to switch on the printer first and wait for the slots to allign, then the cartridge will slide back and you click it up into place.
look on youtube, there are some videos of how to do it, really helped seeing it.
it is possible! don't give up!
Aug 11, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
Refilling ink cartrige 22
black on the right color on the left
Jun 05, 2008 | HP Deskjet F335 All-In-One InkJet Printer
Canon PIXMA MP210 Photo All-In-One Printer Logo
47 people viewed this question
old marine
old marine
