Question about Sharp 27H-S60 TV
Sharp TV model 27H-S60 convergence
Since it was new in 1997, picture has had color fringes, especially noticeable on text except CC. Otherwise picture looks great on digital converter. Can I adjust convergence without special tools like a dot-bar generator?
    Problem Solver:
  • 7 Answers
HI ,USE A PATTERN GENERATAR DOT OR LINES TYPE AND USE THE CONVERGANCE RINGS BEHIND THE YOKE OF THE SET ,THERE ARE THERE RINGS FOR EACH COLOUR RED GREEN AND RED .SLIGHTLY MOVE THE RINGS AND U CAN SE EIN THE PATTREN THE COCLOUS WHICH IS FRINGES EACH BY EACH U ADJUST ALL THERE RINGS FOR PERFECTION , FIRST LET THE SET BE SWITCHED ON FOR 1 HOUR AND THEN DO THE ADJUSTMENT. THANSKS
Posted on May 22, 2008
Sharp 27h-s60 turns on but not tunning into any stations
Maybe the program was erased. go to menu and press the auto search program,,, check the bad solders around the tuner. or its possible that the tuner is bad.
Jun 24, 2014 | Sharp 27H-S60 TV
Hi I have a sharp 27H S60, has worked fine for many years. Now, I get fine sound but no picture. When it is first turned on I get a thick white line in the center of the screen for a second, then it is...
The problem is a vertical deflection issue, it means the picture from top to bottom has collapsed. The set will require two or three capacitors and an ic and it is quite fixable.
Feb 07, 2011 | Sharp 27H-S60 TV
Can i realine the lens myself it has a yellow tint and yhe lettering is out of focus
If you have yellow coloring on everything, this is not a lens alignment problem. Either you have a color balance problem (weak blue) or the coolant fluid in one or more CRTs is going bad. The coolant liquid is supposed be clear, but with age it breaks down and turns yellow.
First, unplug the set and remove the back. Use a mirror if you have to, but look down at the top of each CRT using a bright light. They should be colored red, green or blue, with no yellow to muddy the color. That's a quick check on the coolant condition.
You can replace the coolant, but be very careful not to spill any inside the set. Broken-down coolant can short out electronics and cause a lot of damage to the circuitry, especially in the high-voltage sections. Some people prefer to remove the CRTs from the set for this process, but that is a considerable amount of work. Others use kits with pumps to remove the coolant, and work inside the set with reasonable precautions - if there is enough room. There are a number of good tutorials on-line, or at least there were when I last looked two years ago.
I recommend getting the color right before attempting the focus. Bad coolant may scatter the light and fuzz up the picture, so check that out first and post back what you find.
If you have yellow fringes on otherwise normal colored objects, the blue convergence is off. This will also make lettering appear out of focus. Most RPTVs have a procedure for bringing up a convergence pattern (a grid of dots) using the remote control. The dots should all be white or have very little color fringing. Follow the directions, and make small adjustments, then check the effects all around the picture. Correcting one section may cause a change elsewhere. Use a ruler to make sure the dots stay in the right place; otherwise you may end up with a distorted picture.
Caution to other readers: do not try to adjust convergence if you have a "bow-tie" shaped picture in one or more colors. This indicates a convergence amplifier failure, which must be fixed first.
Oct 12, 2010 | Samsung HCN5527W 55" Rear Projection...
Missing resistor
1.8 ohms at 2W
Dan
Sep 23, 2008 | Sharp 27H-S60 TV
Sharp 27H-S60 TV problem
Good day.
With regards to the brigthness issue, you can adjust the brightness control of the your unit through the Screen control located along the flyback of your TV.
chris
Feb 28, 2008 | Sharp 27H-S60 TV
No power
Solder any / all bad solder connects.While doing that,Look for
overheated areas in power circuits,caused by bad capacitors,
resulting in burnt/open resistors,shorted diodes,etc,.........T.
Nov 13, 2007 | Sharp 27H-S60 TV
Sharp 27G-S60 TV analog or digital?
Call 1-800-237-4277 1-800-BE SHARP
FAX 1-630-378-9981.................................................
Oct 21, 2007 | Sharp 27H-S60 TV
Sharp model 27H-S60
on your remote that you bought there should be a button that says code search hold that button untill it lights up then press tv then put in the codes depneding on the model either it ahould automaticly put it in or press enter. Repeat untill it works
Oct 20, 2007 | Sharp 27H-S60 TV
Color Turns Green
HI PLEASE ADJUST THE SCREEN CONTROL OF UR TELEVESION SET IT IS INSIDE THE TV..IF U KNOW THE SCREEN CONTROL IN THE SET THAN MAKE IT LITTLE ANTICLOCKWISE.AND THE SET WILL BE OK..
May 13, 2007 | Sharp 27H-S60 TV
Televison & Video Logo
130 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
