Question about Braun Activator 8595 Electric Shaver
Mine beard trimmer is pulling the hairs on my face and not cutting properly
Sounds like it is very dull
Posted on Oct 13, 2008
Brand new andis trimmer pulling hair and not cutting good
The questions about Andis T-Outliner or Andis Styliner II, about not cutting or pulling hair.
On the Andis T-Outliner trimmer if the sharpness of the blade is worn out, all the tricks and treats won't make this blade to cut hair. Before I do any kind of work to the trimmer, I first test the coil for the right amount power, I can get out of the coil, without this power, it doesn't matter how new or old the trimmer is, the trimmer will not cut hair at all. If the coil is good, I will sharpen the blade and set it according to your needs (lineups or shave setting) after the blade is sharpened and set. The trimmer will need to be, adjusted for alignment to the blade, adjust the power of the coil, and adjust the tension for the blade. All these factors are involved in the Andis T-Outliner to cut hair clean especially lineups or shaving. These adjustments work together for the trimmer to work properly. I know that we all trying to save money, which is part of life, but sometimes frustration will take over and say hell with it, I'll buy another or forget it. Manufactures make mistakes, sometimes the trimmer was not sharpened or adjusted correctly. Any case, what I'm trying to say here, if you try all the tricks & treats and can get your trimmer to work, it may be easier for you to send it to a professional to sharpen & repair the problem and set the blade according to your needs (lineups or shave setting) We specialize on Andis T-Outliner Trimmers. Our complete sharpening & repair service is $19.99 each trimmer, this includes return shipping. We sharpen the blade, adjust and set the blade according to your request (Lineup or Shave setting) make all the necessary adjustments for alignment, power, tension to make your trimmer work better than new. Our mail order service is one day turn around. We are well known throughout the United States for our service in sharpening. Check us out at or call us at 323 237-2885. Service You Can Trust Since 1990. Manny Mobile Sharpening and Clipper Parts Supplies
Nov 26, 2013 | Andis T-Outliner Hair Trimmer
How to disassemble Philips QG3080 Beard Trimmer
dimitris, use brush to clean hair and don't open the machine.
Nov 09, 2013 | Philips QG3080 Beard Trimmer
Remington mb300 battery replace how
The rechargable nickel-cadmium is hard-wired and not replaceable.
Instructions for removing the battery from the user manual:
1. Make sure your groomer is unplugged from any outlets so you don't risk an electric shock.
2. Remove side panels/grips
3. Remove the 4 housing screws
4. Pull or gently pry the clipper halves apart, exposing the batteries.
5. Remove batteries from the unit.
6. Twist batteries to break wires. Wires may also be cut.
I also own an MB-300. The battery still works good and I loved this trimmer but I need a new cutter blade for mine.
Jan 01, 2013 | Remington MB-300 Beard Trimmer
Remington MB-70 mustache and beard trimmer is very loud. Is there any way to adjust it?
That is why it was so cheap. It will always be noisy, but you may try cleaning if with the brush after every shave.
Nov 10, 2017 | Health & Beauty
Razor making vibrating noises and not shaving properly - feel like hairs being pulled out. beard trimmer will not cut and will also not clip back down in to main shaver when not needed
You should try detaching the head of the shaver and cleaning it thoroughly. You should then try oiling it with the oil that came with it, or any lubricating oil that is safe with metals.
Let me know if this helps!
May 02, 2011 | Remington Health & Beauty
I have a Conair GMT189CGB 13 piece styling trimmer how do I change the nose/ear trimmer? I have no idea how it snaps in? what a terrible design!
You do not need to unscrew anything. Instead, simply take the beard trimmer (with the beard shaving blade still screwed on) in your hand, with the power button and "CONAIR" logo facing you. Then, put your thumb under the shaving blade and apply force to pop it off. So, the shaving blade, and the top part of the unit that it's screwed into will simply pop off. Then, you simply align the nose/ear hair attachment, and snap it in to the beard trimmer unit.
Jan 16, 2011 | Conair GMT 170 CS Beard Trimmer
Remington HC600 hair clipper stopped clipping
To all of you: adjusting the screws won't help, unless you screwed something up yourself, of course LOL The same problem bothered me a few years, and an hour ago I found out it could easily be a single hair stuck between the blades, thus separating them a bit. Get rid of it and the trimmer will probably work again. It can even get out spontaneously, which happened to me and kept me wondering what was going on.
P.S. DON'T lubricate unless you are required to (check your manual) The model I have (HC210c) does't need lubrication, I guess yours is similar to it. And remember that NOT every oily substance is a machine lubricant.
Jun 28, 2007 | Remington HC-600 Hair Trimmer
Braun Activator 8595 Electric Shaver Logo
131 people viewed this question
Top Braun Health & Beauty Experts
Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
