Question about Metz 70 MZ-5 TTL Flash
Inconsistent exposure. even if i change my settings. but this is only sometimes. i can shoot twenty shots and they may all be perfect. but then for no apparent reason the exposure is either over or under for a while. what am i doing wrong? when its right the pictures are beautiful!
  • hope1 Jul 09, 2008
    I recently got three of these units. All three in manual mode for no reason and no pattern will give out only a wink of flash causing under exposure. This occurs in day light with fill flash and with night shots with the flash fully exposing the subject. Nobody can tell me why. It is not recyle time or any other straight forward problem caused by the photographers. Never had this problem with the older ct60 units. In manual mode the flash output should be the same every shot. Good luck.
  • v_e_roberts2
    v_e_roberts2 Mar 28, 2012
    Hi, I have just upgraded from a Metz 70 mz-5 (since the controls seezed up in manual full power) to a Metz 76 mz 5 and the exposure in manual or auto is completely inconsistant... It's appears to be alsomst random ... And I can't find anything to help... It's brand new and it's driving me insane... Does anyone know what the could be down to? Please please help me I will be eternally grateful :) thanks, Johnny.
  • 22 Answers
There are dozens of causes of inconsistent exposure with automatic flash systems. More common ones are inadequate recycling time (shooting before the ready light comes on), weak batteries that lengthen the recycling time or an intermittent anomaly in the internal circuitry of the unit which can only be traced by a qualified technician.
If the unit is used in auto mode (not TTL) dirt or ones hand can block the photo-electric sensor on the unit and affect exposure accuracy.
One other cause of inaccurate exposure is something called “subject failure”. This can occur in a large room like a church, ballroom, gym or a large rotunda. What happens is the automatic system in the flash or the TTL system in the camera reads the entire room and not a smaller subject in the image. Think of a bride and groom dancing in a large hall, the system would read all the space and possible darkness surrounding the subject and overexpose the subject. This often happens with automatic flash equipment that was originally designed for film cameras. On DSLRs, the sensor in the camera may react differently in terms of the area that it is reading. Some of the newer flash units are more compatible with digital equipment.
If you are missing only 1 shot out of 20- that’s not too bad considering all the variables.
I hope this helps!
PS- If there are problems in the circuitry, unless you are an experienced technician with high voltage devices, it is not advisable to try and service the unit at home. Many flash units harbor lethal voltages that can cause burns, nerve damage, serious electrical shock or even death. Theses voltages can remain in the unit even after it is turned off.
Ed
Posted on May 28, 2008
My Nikon D 80 on the same exposure settings in
You have a shutter problem that can only be fixed by a service technician.
Aug 03, 2010 | Nikon D80 Digital Camera with 18-135mm...
I recently bought a Canon powershot SX200is and I was using it to photograph my 4 year old grandson's birthday party, however a lot of the shots were blurred, these were mainly taken indoor, when I checked...
I don't know your camera but on my fuji there is a setting that changes the "film speed". If it is set too low such as 100 or 200, it will make the exposure take too long causing blurry photos.
The higher the number, the faster it is.
Worth a try.
It should be under settings area. Also check to see if the flash is working or what I have seen sometimes, people don't realize that when shooting a picture, their finger is covering the front of the camera where the exposure meter is.
Mar 25, 2010 | Canon Cameras
Canon Digital Rebel XT auto focus
Auto Focus does not determine exposure. Only sharpness. "Wrong" exposure could be due to the metering mode being set in Spot Metering. Set it back to Evaluative Metering which may improve the overall even exposure of your shots. Test your shots in full auto or P mode. M (Manual) mode will require you to check the exposure setting manually (you can see the indicator in the viewfinder when you half-press the trigger)
Nov 05, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Exposure inconsistency with 18-200mm on my Nikon D300
A plus-or-minus one-third stop is perfectly normal if you're handholding the camera, especially when metering a high-contrast subject such as a lit lamp. If you really need to lock the exposure, use the exposure-lock button or set the camera to manual.
Sep 22, 2009 | Nikon 18-200mm f/3.5-5.6 G ED-IF AF-S VR...
Inconsistant exposure in Manual mode
In manual mode the light meter result is the output of setting the apeture and shutter speed. It will constantly change as you change these and the ISO until you get the desired exposure. Is this what you mean by inconsistent? If it is giving verying results in the same conditions try it with ISO 100. That should fix it
Aug 04, 2009 | Canon EOS 40D mit 18-55mm / 55-250mm...
Over-exposure with AF Nikkor 70-300 telephoto
Friends have you tried not using the A-Aperture mode?? Set in on P-for Program or M-for Manual, this should produce the colors you are hoping for. If your photo is still "hot" use the + or - button called the Exposure compensation button on the top of the camera, push that little button and turn the outside main control dial where your right thumb sits 1 third stop at a time, (you have 4 to 5) The + adds light to your photo and the - will make your photos darker play with that and let me know. Barry Brown www.coralreefphotos.com
Jun 26, 2008 | Nikon D70s Digital Camera
Double-exposures
DMC-FZ10 and an external flash with a manual trigger can do it. Just set a high aperture number, slow shutter speed, take the pictures...change camera direction a little..then as soon as you can, re-trigger the flash manually.
Sep 07, 2005 | Panasonic Lumix DMC-FZ20 Digital Camera
Sequential shooting modes
There are four sequential modes: Sequential shooting, High-speed Sequential shooting, AF Sequential shooting and Auto Bracketing. Sequential shooting modes can be selected from the CAMERA menu: Sequential shooting: A maximum of 11 frames can be shot sequentially at approximately 1.7 fps in HQ mode. Focus, Brightness (exposure) and White Balance are locked at the first frame. High-speed Sequential shooting: A maximum of 4 frames can be shot sequentially at approximately 3.3 fps. Focus, Brightness (exposure) and White Balance are locked at the first frame. AF Sequential shooting: Focus is individually locked for each frame. The AF Sequential shooting speed is slower than for normal sequential shooting. Auto Bracketing: When Auto bracketing is set, exposure is changed automatically for each frame when you start shooting. The exposure differential can be selected in the menus. Focus and white balance are locked at the first frame.
Sep 04, 2005 | Olympus Camedia C-8080 Wide Zoom Digital...
There are four modes: Sequential shooting, High-speed Sequential shooting, AF Sequential shooting and Auto Bracketing. Sequential shooting modes can be selected from the DRIVE mode menu: Sequential shooting: A maximum of 11 frames can be shot sequentially at approximately 1.7 fps in HQ mode. Focus, Brightness (exposure) and White Balance are locked at the first frame. High-speed Sequential shooting: A maximum of 4 frames can be shot sequentially at approximately 3.3 fps. Focus, Brightness (exposure) and White Balance are locked at the first frame. AF Sequential shooting: Focus is individually locked for each frame. The AF Sequential shooting speed is slower than for normal sequential shooting. Auto Bracketing: When Auto bracketing is set, exposure is changed automatically for each frame when you start shooting. The exposure differential can be selected in the menus. Focus and white balance are locked at the first frame.
Sep 04, 2005 | Olympus Camedia C-60 Zoom Digital Camera
There are four modes: Sequential shooting, High-speed Sequential shooting, AF Sequential shooting and Auto Bracketing. Sequential shooting modes can be selected from the DRIVE mode menu: - Sequential shooting: A maximum of 11 frames can be shot sequentially at approximately 1.7 fps in HQ mode. Focus, Brightness (exposure) and White Balance are locked at the first frame. - High-speed Sequential shooting: A maximum of 4 frames can be shot sequentially at approximately 3.3 fps. Focus, Brightness (exposure) and White Balance are locked at the first frame. - AF Sequential shooting: Focus is individually locked for each frame. The AF Sequential shooting speed is slower than for normal sequential shooting. - Auto Bracketing: When Auto bracketing is set, exposure is changed automatically for each frame when you start shooting. The exposure differential can be selected in the menus. Focus and white balance are locked at the first frame.
Sep 04, 2005 | Olympus Camedia C-5060 Wide Zoom Digital...
Metz 70 MZ-5 TTL Flash Logo
128 people viewed this question
Top Metz Cameras Experts
Doberman
Neil
Level 1 Expert
Are you a Metz Camera Expert? Answer questions, earn points and help others
