Question about Hoover U5450-900 Windtunnel Supreme Bagged Upright Vacuum
Broken front cover
Hey the cover over the bag broke, the clips snapped, where can I get a replacement part for it?
  • robcraigw Nov 24, 2008
    same problem here
    Problem Solver:
  • 8 Answers
Go to hoover .com and look for the thing that says parts and it will ask u for a model number the model number will be on the bottom of the vacuum.
Posted on Feb 22, 2009
I need instructions on how to change the belt on my Hoover Model U4264-930 vaccum.
Tool Needed, flat head screwdriver (larger one works a little better). Serious Safety Precaution: Make sure unit is unplugged. Preliminary: Check: that nothing is caught like threads etc, preventing roller brush from turning. I've had this model vacuum 10 years and have pulled threads out countless times. However it still has the original belt on it. To change belt: 1.) There is a plastic plate underneath roller, towards front.. Pry the 3 tabs at front, the plate hinges downward slightly (to clear the front tabs). Next, there are 2 little clips at bottom of plate. Insert screw driver at each of these clips to fully release the plate the rest of the way. (Or it may even come off without having to pry back on these. The plastic clips need pushed towards front, to clear the ridge that catches towards the back). Pry one, then the other, clip forward, while gently pulling the plate the rest of the way out. (Gentle prying will assure it will snap back together OK, so you still get a good seal.) You now should see the whole roller brush. 2.) Remove the shell/motor cover: To do this, a.) pull off the rug height adjuster lever, and take not where you put it so you won't loose it. b.) push foot release down and keep vacuum bag in the vacuuming/hinged/operating position (not the upright/locked position), and position cleaner on it's side, or upside down. c. Pry around the bottom edge, starting at right corner, then go around, prying in about 4 different places. Shell/motor cover will now easily pull off (upward and out towards front), exposing motor shaft and light bulb. 3.) remove belt from motor shaft. 4. slide roller and old belt out the bottom. 5.) remove old and place new belt on roller 6.) slide roller back into place. 7.) wrap other end of belt on motor shaft. 8.) shell cover, rug height adjuster knob, and bottom plate snap back into place. check that roller turns without much effort. 9.) It now should be ready to plug in and vacuum.
Aug 21, 2011 | Hoover Soft Light Supreme U4262-930 Bagged...
How do you change the dust bag on the Nilfisk King 505?
Press the middle rectangular Nilfisk button in the top centre of the machine. The front cover will fold down. There is a greay retaining bracket which clips forward off the top of the old bag. Fold that forward, replace the bag, clip the holder back on, and then close the lid.
May 20, 2010 | Vacuums
HOW TO REPLACE CORD BROKE INSIDE UNIT CAT TAKE IT
you know the cord is broke? and you wish to remove and replace the broken one? well it has to be opened to remove or reconnect the broken wiring. is there screws attaching the removable parts in order to get to the broken cord? recommend you locate broken wires and reconnect each wire to its color either white and black. and use electrical tape to cover each wire reconnected.
Mar 12, 2010 | Hoover Elite U5061-900 Bagged Upright...
Stand up lever is plastic, broke when stepped on to release handle, can it be repaired, replaced with a better one, plastic breaks too easily?
The pedal release can be replaced but the base will need to be checked for cracks as well. if the base is broken most common is the socket the pedal release snaps into. some of the plastic parts have been made with better materials
Oct 20, 2009 | Hoover Ultra U6430-900 WindTunnel Bagged...
I have a worn clip - the open close clip to secure the adjustable handle in place. I have the new part but, not sure how to fit it. Can you help?
Yes. Remove the handle and cable, then remove the bag compartment cover. At the back of the bag compartment, towards the top, you will see four screws. Ignore the one furthest to the left, and unscrew the other three. That will release the cover at the rear, and expose the clip you want to get at. The clip is held in place by a metal C-clip, which can be levered off with a screwdriver, but be careful not to damage it because you will need it to secure your new clip. when you've got the new clip in place, re-position the cover (not that it clips in at the top first), replace the three screws and the job's done.
I value your feedback, so please remember to rate this response.  Good luck!
Jul 22, 2009 | Sebo X4 Bagged Upright Vacuum
Hoover Flair S2220 cleaner w/power nozzle disassembly instructions
With the head flipped upside down, take a flat tipped screw driver and carefully pry up the rollers on the front the head. Underneath, you'll find a screw. Remove the screw under each roller, and the front cover will come off with ease. The rollers are just friction fit.
Aug 16, 2008 | Hoover U8185-900 Upright Vacuum
Replacing the foot pedal
there is two C clips on the pin that must be removed first. then the pin will come out. if you need a picture of this or have any other trouble feel free to let me know. I also stock those foot pedals if you need one.
Aug 10, 2008 | Sharp Twin Energy EC-12TWT4 Bagged Upright...
Electrolux Oxygen3 model EL7001
If it is the top cover, the monitoring panel just pops off from the backside. You can use a thin knife or screwdriver and push on the locking clips, it then just hinges off of the front clips. After that is off you can see the two screws and after the top cover hinges off the actual door to the vac bags is attached to that cover it too hinges off.
Hope this helps
Mar 08, 2008 | Electrolux EL7020A Oxygen 3 Ultra Canister...
My vacum power head wont work
fan belt might have snapped.  take off top by snapping out plastic over light.  good luck!
Apr 18, 2007 | Kenmore 23313 Whispertone Bagged Canister...
Hoover U5450-900 Windtunnel Supreme Bagged Upright Vacuum Logo
57 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
