Question about LG TROMM WM2688H 4.0 cu.ft. Front Loading SteamWasher
LG Tromm 8/4 WD R8012
My washing machine stops in the middle of the cycle and gives me a IE error message. What can I do? What does it mean?
  • Anonymous Jun 09, 2008
    Hello! I have an LG TROMM and am receiving an LE error, how do I fix it?
    Thank you!
  • Anonymous Apr 01, 2014
    IE error when the machine has run for about 4 - 5 minutes. I switch it off for a while and try again and sometimes it works but on most occassions it just gives the same error and beeps 6 - 10 times and stops
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 16 Answers
The manual suggests to shut the water off ,
remove the inlet hose and check the screen for blockage.
The ie message is the inlet water is insufficient.
Posted on Jun 22, 2008
Make sure your not using to much detergent; that will cause an IE error. It happens a lot to new users of front loaders because they think the recommended detergent amount will not be enough.
Posted on Jun 07, 2008
I have this Model : WD-R8012.. Water keep on dispence to the outlet ... during filling water and rotation
Posted on Oct 13, 2009
Lg top loader ie error message, fills ok, but water running out of bottom of machine
Hi IE means Inlet Error. The machine thinks that it is not filling (as a certain time has passed without reaching level it wants).
This makes sense if water is running out the bottom.
You will need to find the leak. Maybe the tub to pump hose, or the drain pump itself. Once you stop the leak and the machine can fill in the correct amount of time, you shouldnt see the IE error any longer.
Cheer
Jun 01, 2014 | LG WD-1045FH Front Load Washer
Lg tromm wd 85485 error code cl mean ?
Possible that the drain valve is clogged if the inlet line is working and so you need to remove the drain and back flush.Also check after the power plug is removed for few hours and see if the fault resets to start the machine only to show the error a few minutes later. if so clean the drain lines, check the inlet flow and the door switch.
Dec 15, 2011 | LG Washing Machines
Lg Tromm front loading washing machine. Model # WM0532HW.I keep getting the UE and IE codes. Also makes alot of noise in the spin cycle....warranty is done....should I not bother & get another
IE: Water level (246) was not reached in 8 minutes
UE: Imbalance: Load too small, too large objects between tubs
OE: Drain problem took longer than 10 minutes to drain
FE: Overflow issue drain pump running to comp
PE: pressure sensor (sensor out)
dE: door error. open door. switch is out
LE (with a a slash in the
middle of L. Upside down F) Thermistor out
CE: Over amping Too much soap wrong soap
LE: hall sensor shorted/destroyed from sudslock
bE: Ball sensor loose connection/out of order
EE: eeprom out test mode only
PF: power failure momentary interruption of shocktricity
Service notes and manual
Jul 23, 2011 | LG WM-2277HW Front Load Washer
My lg intello wd 8074fhb washer will be in the middle of wash cycle and an error message comes up se ..Can you tell me what this error message means..
LG's 'SE' means 'sensor error'. Sorry but you will need a repair visit I fear ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Jun 12, 2011 | Washing Machines
LG Tromm WD R8012 Owners manual
GO TO THIS SITE AND LOOK FOR YOUR MODEL NUMBER UNDER WASHERS. http://www.lge.com/us/support/product/support-product.jsp GOOD LUCK.
Jun 11, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
My LG Clothes Washer has stopped mid cycle and is displaying an "OE" error code. How do I get the machine to finish the cycle?
oe means drain error (outlet error)
Poss causes:
drain hose kinked,
filter blocked,
pump impellor blocked.
Hope that Helped
Please Rate Me
George
Apr 29, 2009 | LG WM2688HWM TROMM SteamWasher
Tromm washing machine, front load from LG
Peace,
ngafm at your service!
Lets try this first!
Did you try to open the door when the breaker was off or only when you turned it back on??
How old is the washer?
I'm here all night if you want to write me back!
Bless You,
Please leave me a good rating in this site before you sign off!
Sep 03, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Washing Machines Logo
833 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
