TYPEWRITER STOPPED PRINTING
RIGHT IN THE MIDDLE OF TYPING A FORM, THE HAMMER STOPPED HITTING THE KEYS. IS THERE A RE-SET PROCEDURE, OR AM I LOOKING AT A SIMPLE MECHANICAL REPAIR TO REPLACE A DEFECTIVE PART?
  • 3,594 Answers
If this a wheelwriter the platic cap on the orint solenoid is probably broken. They are available but a little tricky to install.
DickyO
Posted on May 22, 2008
Where is the TYPEWRITER SOLENOID on a IBM Wheelwriter 6 Series II
The "print" solenoid is what hits the hammer that hits the printwheel and makes it type on your paper. If you remove the ribbon and look straight down in the carrier on the left side you can see the solenoid. It is below the blue piece of rubber that sits on the hammer arm. The end of the solenoid is supposed to have a cap on the end of the plunger. This cap gives a specific clearance so when it is activated, it hits the hammer arm to propel it forward to strike the printwheel.
Apr 28, 2014 | IBM Wheelwriter 6 Typewriter
Replacing the print solenoid cap
The best way to find what you are looking for is to look at your printwheel. Right in the middle of the carriage there is a part that hits the printwheel. That is called the hammer. If you look down on the left side you will see a blue piece of rubber that attaches to the hammer. If you continue to look further down the hammer you will see the solenoid that activates and hits a screw that sticks out from the hammer. The end of the solenoid is where the "cap" can be attached. You do not have to remove the solenoid to install the repair "cap" if that is what you are really looking for. A technician can put in a new cap in less that 30 seconds.
Apr 11, 2014 | IBM Wheelwriter 6 Typewriter
What does the print solenoid look like
Mar 25, 2014 | IBM Wheelwriter 6 Typewriter
I am trying to revive an IBM selectric 6746 wheelwriter to complete some statutory Govt forms that do not have softcopy. It worked perfectly for a while then suddenly stopped printing. All motors seem to...
There is a solenoid that hits the hammer when a key is pressed. There is a plastic spacer on the solenoid plunger that falls apart and keeps the plunger from hitting the hammer. Therefore it looks and sounds like it is working but no letters appear on the paper. Try to find a typewriter repairman to fix it. It is a common problem on wheelwriters so any repairman should know what part is needed.
Jun 16, 2010 | Office Equipment & Supplies
Wheelwriter 3 Selector Assembly
The selection motor bearings just right of the print solenoid get dry a little WD40 on the front and rear bearings usually takes care or this.
DickyO
Dec 14, 2009 | Lexmark Wheelwriter 3 Typewriter
Striker hits the ribbon but it will not print. Replaced the ribbon but it did not help.
If you are sure the hammer is hitting the printwheel and platen (try printing on a multi part form if the carbons print the ribbon is probably not lifting, wiggle the big black gear on the right side of the printer. If it doden't print the print solenoid cap is probably broken.
We sell the cap with instructions and shipping for 20.00.
DickyO
Cleveland Business Machines
216-241-0027
Aug 21, 2009 | IBM Wheelwriter 30 Typewriter
Type is faded and old looking even with new ribbon.
Put in a multi part form, if the carbons print well then try a fresh ribbon,. not one that has been sitting around for a long time. If it is bad check for debris around the print hammer, If its clean either the print solenoid is gummy or the solenoid cap is broken.
DickyO
Jan 06, 2009 | Lexmark Wheelwriter 1500 Typewriter
Wheelwriter 5 --cant set the right margin
A beep 5 spaces before the margin is all you are suposed to get, no lock or stop just a beep
Dec 07, 2008 | IBM Wheelwriter 30 Typewriter
If this a Wheelwriter the print solenoid pad is probably cracked. They are available but a little tricky to install.
DickyO
Sep 15, 2008 | Office Equipment & Supplies
Poor quality impression
I am supprised your repairman couldnt fix this, either the hammer is binding or the V 1 resistor on the logic board needs adjusted I do this repair in my shop quite often.
Jan 18, 2008 | Swintec 7040 Typewriter
jasbo
jasbo
