You can get the unlock code for a Samsung Gt-B7300 from www.unlocking4u.com at affordable cost with easy step by step guide on unlocking process. All the best mate.
Hey,
Once done this should solve your problem. Anyways omnia lite has a peculiar problem with the corner parts. Incase if thats what you are referring than nothing can be done. For everything else you may do the screen alignment from settings--general settings - align screen.
Regards,
Ritesh
The Pin code for a router is typically found below or on the back of a router. Just look for something that says SSID: xxx then right below that it should say PIN: xxxx.
No, because the phone uses proprietary Samsung software, you cannot download and install themes. The most you can do in terms of customization is download wallpapers (search for 240x400 wallpapers for your screen resolution). Alternatively you could install custom ROMs that have custom themes - but then you void your warranty and you may damage your device so I advise against it.
Hi, first of all you DO NOT need custom firmware to install themes onto your psp, you need a firmware 3.71 or later to do it. First of all go to a theme site E.G http://www.psp-themes.net/select a theme you want and download it to your computer. then connect your psp to your pc. open the psp files, go PSP, then there should be a folder called THEME. copy the theme you downloaded and viola. this is the folders in psp memory stick:
the theme file must be .ptf
Hope this helps.
