Question about Car Audio & Video
Stero wire diagram/ 1995 dodge Intepid
I need to know witch wires are what to the previous stero, the wire harness has been cut off to the factory stero, but I'm going to install an after market Alpine cd player in it's place....Can you tell me witch wires are for what??
    Sergeant:
    Champion:
  • 359 Answers
Use a test light with ignition off when u find power connect it to yellow(memory) then on acc when u find power conect red connect black to earth blue is optional (power antenna) find the speaker wires colors at the back of each speaker and connect the two of the same color to each speaker striped wire + no stripe - hope this helps
Posted on May 26, 2008
Dodge wiring diagrams free
Try eBay and look for a factory service manual from Chrysler Corp...(Dodge) . They should have different manuals and one will be the electrical manual.
Sep 07, 2014 | Cars & Trucks
Color to insatll a new stero
Here are the colours of the factory radio harness and what they do.
1995 Toyota Camry Car Radio Installation Schematic
Car Radio Battery Constant 12v+ Wire: Blue/Yellow
Car Radio Accessory Switched 12v+ Wire: Gray
Car Radio Ground Wire: Brown
Car Radio Illumination Wire: Green
Car Stereo Dimmer Wire: N/A
Car Stereo Power Antenna Trigger Wire: Black/Red
Car Stereo Amp Turn-On Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Tweeter Size: N/A
Car Audio Front Tweeter Depth: N/A
Car Audio Front Tweeter Location: N/A
Left Front Speaker Positive Wire (+): Pink
Left Front Speaker Negative Wire (-): Purple
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Blue
Left Rear Speaker Positive Wire (+): Black
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Red
Right Rear Speaker Negative Wire (-): White
Jun 21, 2012 | 1995 Toyota Camry
Please Help I Need A 1992 Mercury Capri XR2 color-coded Stereo Wire Harness Diagram
Go to your local auto store and get the Hanes auto manual for this care and they should have a wiring schematic for you to follow also you can look your new stereo up on the web and find out what each colored wire goes to what!!! Good luck
Jun 07, 2012 | Lincoln Cars & Trucks
2004 pontiac alero colour code for factory stero my harness was cut off and i want to reconect it
GM dealership parts dept should be happy to print you off a copy of a stereo wiring diagram
Oct 27, 2011 | 2004 Pontiac Grand Prix
I need color codes wiring diagram for car stero
The easiest thing to do would be to purchase a Metra wiring harness. It plugs right in to the plugs that you will remove from the factory stereo. This simplifies wiring, as you can crimp wires by matching colors on the harness instead of mixing and matching colors on the factor wires. You can purchase this harness at PepBoys or other places where they sell car stereos. The harness looks like this. I used this harness on my 94 SL2 the same model harness applies to yours
Mar 24, 2010 | Panasonic CA VDC300 - IPod to car...
Audio wiring problem
Constant 12V+ Blue/Yellow
Switched 12V+ Gray
Ground Brown (or your own wire to a metal grounding point)
Illumination Green
Antenna Trigger Black/Red
Front Speakers 4" Dash
Left Front (+) Pink
Left Front (-) Purple
Right Front (+) Green
Right Front (-) Blue
Rear Speakers 5 1/4" Rear Deck
Left Rear (+) Black
Left Rear (-) Yellow
Right Rear (+) Red
Right Rear (-) White
I a '83 camry, there are 2 seperate plugs that go into a factory radio.
One for Power/and front speakers, and the other for rear speakers.
Sounds as if you are missing part of the harness for the rear speakers (or it is shoved in the back of the dash unused by the previous install). If there is not an un-cut plug in the dash - your only course of action would be to run your own set of speaker wire to the rear.
See this picture... these are the plugs that should go into your factory radio....
Metra kit 71-1938 will go from your factory wiring directly into your factory radio.
Thanks for using FixYa - a FixYa rating is appreciated for my effort in answering this Freebie question.
Feb 25, 2009 | 1983 Toyota Camry
Wiring harness
you should never cut the wires on your factory harness... metra and other companys have harnesses that fit your car and would provide you with a correct wire color code you need to hook up a aftermarket stereo keep that in mind but i will post the wire diagram u are looking for
Aug 08, 2008 | 2002 Honda Civic
Wireing
I need the wiring diagrams for a 1993 ford festiva, needing to know what wire is what..the factory harness was cut outta mine.
Jul 21, 2008 | 1993 Ford Festiva
I need the colour wire description for a 2000 dodge caravan Im removing the the factory stero and installing after market stero and need wring diagram , what each wire is for ,speakers ,power etc.
HI.
In the caravan are 2 types of Radio.
1. Normal sound system.
1 Premium sound system.
Note: If you don't want to cut the original wires,
You can buy a harness connector to install the aftermarket Radio. The connector are made by aplication, and are plug in.
The colour of the connector are the same colour with the Aftermarket Radio. Just you need to soldering or just put joint connectors.
Normal: colour of wires.
Pink = Battery voltage.
Red/withe = Ingnition Voltage.
Brown/red and Dark green. = Left front speaker.
Dark bku/red and Voilet = right front speaker.
Brown light blue and brown/yellow. = left rear speaker.
Dark blue/orange and dark blue white = right rear speaker.
Ground is a single wire behind the radio.
If you have a premium sound. You need to use the front speaker out to connect the speaker on the door and the speaker on the dash. To complete the 6 speaker.
OK... I hope this information work for you.
Thank you , For use fixya. Rate please.
Jul 17, 2008 | Car Audio & Video
Wiring diagram
Try Crutchfield.com. They may have a wiring diagram that you can download. They certainly have adaptor harnesses. So you don't have to cut the factory connectors off.
May 27, 2008 | 1995 Ford F150 Styleside Regular Cab
Car Audio & Video Logo
85 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
