Question about Philips DivX Ultra HTS6500/37 Theater System
Philips DVD Home Theater HTS6500/37
Will not play dvd's, no disc error.
  • 2 more comments
  • Anonymous Sep 28, 2008
    happens all the time, the system has to be reloaded about 8-10 times than it suddenly works, it sucks... Philips has a piece of **** product what can one say...
    no disc error philips hts6500 dvd home theater system
  • thom666 Oct 14, 2008
    Mine is hooked up with an HDMI Cable and my TV just reads INVALID FORMAT although the audio is working.
  • Anonymous Oct 28, 2008
    It just wont read a disc
  • Anonymous Dec 04, 2008
    I have the same problem. Also, the few disks it does find , the movie stops halfway through
I tried this and it worked.
If you are getting No Disc issues, blow on it using some compressed air. After I did that several times, my discs had no problems getting recognized and playing again.
Posted on Oct 13, 2008
I have a Philips HTS5550 home theater and i have found out that the dvd spindle spins a disc for a few seconds, then it stops and displays a "No disc error" on the screen. What is the solution to repa
First, make sure you're not trying to play a bad disc by testing with another factory-burned DVD. And ... please do not be insulted here ... be sure the labeled side is facing upward. If still the same, the laser is mot likely defective and you will not be able to repair that yourself.
Aug 07, 2014 | Philips HTS5550/12 DVD/DivX Home Cinema...
I have a Philips HTS5550 home theater. The dvd machine has of late been displaying a "No disc error" when i insert a dvd in the machine to play. I have already tried using the cleaning kit. What might
if there's no flashing red light on lens?.. the ribbon connector of lens is not properly connect, or change it if you notice that it has lines cracked. the bad performance of the disk spinning motor is also causing why was your unit displaying "no disc" error.
Aug 04, 2014 | Philips HTS5550/12 DVD/DivX Home Cinema...
Does the model HTS3372D/F7 play both Blue Ray and DVD or just DVD's ?
If you web searched the question or for a manual you might find something like
http://www.p4c.philips.com/files/h/hts3372d_f7/hts3372d_f7_pss_aen.pdf
... which says "Plays it all
Play virtually any disc you want - whether they be CDs, (S)VCDs, DVDs, DVD+R, DVD-R, DVD+RW, DVD-RW or DVD+R DL. Experience unbeatable flexibility and the convenience of playing all your discs on the one device."
or
http://www.p4c.philips.com/files/h/hts3372d_f7/hts3372d_f7_dfu_aen.pdf
which says "If there are questions regarding our TV set
compatibility with this model 525p and 625p
DVD player..."
Um, no Blu-Ray.
Aug 07, 2011 | Philips HTS3372D Theater System
Got a philips hts3357 some discs play some come up no disc
unfortunately Philips DVD players are more precious/ selective on DVDs than the other brands..it is true especially with "Copied DVD"..normally an original DVD should not cause such problem..however if your DVD disc itself is not clean ( i.e.finger prints ) the reading LASER sometimes has problem to read it..
I recommend to buy a "wet DVD laser cleaner system" and clean your laser on DVD and your DVD discs as well..it is available any HI-FI store..
Take care and please Remember to rate/vote and give me 4 Thumbs Up
for Helping out the Community :)
Hope this helps!
Jun 22, 2011 | Philips HTS3357/05 Theater System
I have an hts 3100 philips home theater dvd player it plays some dvd's and some others not(coming the message no disc) Can you help me about it?Why does this happen?
Hi, is your DVD player anew one?if yes the lens that makes the CD play is not OK.But if it's an old one, you can get DVD lens cleaner toclean up the lens of the DVD player...
It's the problem of dirt inside the DVD player especially the lens area.
After cleaning up the lens and still does not play, you will need to replace the DVD player lens with anew one..
You can go to the nearest repair outlet for replacement of the lens ...
Hope you understand..
Take care...
May 04, 2011 | Philips HTS3100/05 Theater System
I have a Philips HTS 3371 DVD home theatre and can not play many DVD's as it give wrong region error. Can you please provide the unlock code and how/where to enter it to get it fixed?
Hi -
Please follow the instructions below for unlocking your Philips HTS 3371
Please note: Unlocking a DVD player may invalidate the warranty. Unlock sequences may not work with some firmware updates and some DVD players have been damaged through failed attempts to unlock them. Unlocking your DVD player is done at your own risk.
1. Switch the DVD player ON
2. OPEN the disc tray
3. Key 9 9 9 9 0 using the Philips remote control supplied with the player
4. Press PLAY. The disc tray will close.
5. Switch the player OFF then switch ON again.
6. To test, play a disc from a region which was previously locked.
If it does not work the first time, switch the player off and back on, then try again.
This is a verified unlock method, but I was unable to confirm whether it works for players sold locked to Region 1 (North America). If you have a Region 1 player and the method above does not work, you will not be able to unlock your player.
Regards,
BElectric
Mar 26, 2011 | Philips HTS3371D Theater System
On one particular DVD (UP from Disney/Pixar) a certain section keeps repeating. When I stop the DVD to try accessing the root menu it freezes up and the entire sound bar locks. The only way to resolve this...
Those discs have a very strong copy protection mechanism to avoid making digital copies on PC systems but some DVD players won't play them because of that, if you have the original movie, download a copy from the internet, burn it to a dvd-r disc and play it. It's perfectly legal because you already bought the movie. The downloaded copies have no copy protection and will play better than the original.
The PHILIPS DVD-Home theater players are specially picky about non-standar disk like the one you're trying to watch.
Jan 12, 2010 | Philips SoundBar DVD Home Theater with...
Dvd player not playing
try a cleaning disc or clean the laser..
Apr 30, 2009 | Philips HTS3544/37 Theater System
LG DVD player Disc Error message even when playing lens cleaners!
LG DVD Player Disc Tray opens & closes automatically & unnecesarrily
Apr 29, 2009 | LG LXD5230 System
Philips HTS3090
1.power on dvd
2.press setup
3.press play
4.press 15902379390
5.press play
Oct 17, 2007 | Philips HTS3450 System
Philips DivX Ultra HTS6500/37 Theater System Logo
590 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
