Question about ASUS VW193T Monitor
Remote display/monitor Hi, I have been using a remote Samsung monitor with my Asus laptop for some time now. Recently, I used my laptop with a projector to show powerpoint slides. This functioned normally. Since this use, I have been unable to have my Samsung monitor work again. I have tried everything I can think of. At one stage when I selected the mode to "extend my display to this monitor", I saw a flickering dark image of the Windows desktop. Now I can't even replicate that. I have proven that the monitor and cable are fine by using a different laptop. Is it most likely that the a hardware failure has occurred, and are there any further tests I should do to check/resolve? Thanks for the help in advance.
    President:
  • 2,692 Answers
First try to reinstal the monitor display driver. Failing that working I would next borrow a monitor to see it it works. That wil tell you if it is a monitor or video card  problem.
Posted on Jan 24, 2009
Can one change one of the two samsung tv remotes one is for a 24in tv being used as a monitor for computer in the same room as the new 50in tv and when someone turn the tv on with the remote the monit
The Samsung monitor wouldn't need use of a remote.... you can turn it on from unit and control speaker volume from the PC. I would tape over the receiver section on the monitor so the TV remote cannot control it!
Dec 31, 2014 | Samsung Genuine Tv Remote Aa59-00482a Lcd...
I have an asus Eee PC Seashell series netbook and I'm trying to connect it to a vizio smarttv but it keeps showing "no signal" on the tv
Have you checked these?
1. Input settings in the TV,
2. Cycle the laptop output (laptop screen, external screen, both)
Mar 10, 2014 | ASUS Eee PC 1005PE (SeaShell) Netbook
I need the remote code for the Samsung Syncmaster monitir, please
If you have a "universal" remote, it will scan for the number, or it could be listed in the manual that came with the remote. If it doesn't list Samsung monitors, try Samsung TV's. If you have the nanual for your monitor, it will be in there, too. Also, check Samsung's own site to download the proper manual and/or the codes. In the meantime, try these 2-digit codes from the manual for my Samsung Blueray system, assuming of course, your monitor uses 2-digits -- which does seem to be a standard convention. I also suspect manufactures only have a certain block of codes they use for all their remotes. 00, 15, 16, 17, 40, 43, 46, 47, 48, 49, 59, 60, or 98
Jan 23, 2013 | Samsung SyncMaster 710m 17" LCD Monitor
How can I use my second monitor on the iMac via VPN/RDP?
Hi Jessiejeh55,
It sounds like you are using the Microsoft Remote Desktop Connection client for Mac.
  1. Open Remote Desktop Connection
  2. Select the connection you wish to use with both displays
  3. Right-click and choose Edit
  4. Check the "Use all monitors" box at the bottom
Thanks
Aug 01, 2012 | Apple 24" iMac Desktop
I recently bough a Samsung RMC30C2/ZA remote and currently using it with my 55 inch C8000 series 3DTV. I can't see the 'twin display' button on my remote. There are only three icons at the...
Sorry Amn_qaisar, but the dual display is only offered on the C9000 TV's. There are two types of remotes that look identical. The RMC30C1 and the RMC30C2. The RMC30C1 has the twin display feature and was specific to the C9000 samsung TV. The TV, not the remote, has the dual tv tuner which allows the signal to be sent over WiFi to the remote. So, even if you were to buy a RMC30C1 remote you still would not get the dual picture your seeking.
Jul 16, 2011 | Samsung RMC30C2 Remote Control
I recently purchased a ASUS K60 Notebook from best buy. I am using Windows 7. I am trying to hook it up to my 42" inch LCD tv via a VGA cable. My problem is that when I do all I am getting is my Desktop...
Since you are using a laptop to connect to an extended monitor, follow these steps:
  1. Make sure that both the laptop and TV are on.
  2. Connect the VGA cable from the laptop to the TV.
  3. Then hold down the FN key and the function key with the TV/Monitor icon like the one below to switch to dual monitor display mode.
Jun 09, 2010 | ASUS K60IRBBBR05 Notebook
I have a hp pavilion dv5ooo, I want to know if possible connect my laptop to a remote display and how can I do it? Thanks for your help!!
One of the Microsoft PowerToys - Remote Display Control - v2.03 that will allow you to display on your PC your PocketPC screen when it's connected (using TCP/IP, this can be the cradle, a modem or a network card).
You can also work on your PocketPC from your PC screen with a zoomed view in 480x640 or 720x960.
The bad thing is the refresh time that is a bit slow, even with USB.
If You want to connect only Monitor (LCD/CRT) to the laptop use VGA-Cable (D-Sub) ... That's all! Enjoy!
Jan 16, 2010 | HP Computers & Internet
Forgot password to Samsung SMT-190DN
Hold the remote control's STOP ( ) button for
longer than 5 seconds. “INITIAL” appears on the display and
all settings will return to the default values.
• Press the POWER button.
Using the RESET function will erase all stored settings.
Do not use this unless necessary.
Oct 06, 2009 | Samsung SMT-190 19" Flat Panel TFT LCD...
Samsung TV can't detect connection to laptop
Make sure you set the laptop to display at a resolution the TV can display, it seems best to start with 1024x768 then work up.
If you are using a VGA - HDMI converter it is possible you will not get a picture.
You should be able to set the laptop to 1024 x 768, plug it into the TV, select PC input on the TV remote, and the picture should appear.
If not, then check you have the monitor output on the laptop switched on, test it with another monitor to be sure.
If all the above still fails to work, and you've checked the cable the TV has a fault.
I hope this helps.
Mar 28, 2009 | Samsung LA40M81/BDX 40 in. LCD TV
SANYO dvr 100e with REMOTE CAN I GET A CODE
You could get a universal remote that will let you operate multiple devices all from the same remote. You would probably need to check it to see if it would control the monitor, but you might be able to treat it as a TV.
Jan 21, 2009 | Samsung SyncMaster 710MP 17 in. LCD...
ASUS VW193T Monitor Logo
120 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
