HP COLOR LASERJET CP 3505 N PRINTER Logo
Posted on Sep 24, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Have an HP CP3505n LaserJet Printer at work. We got a fuser error 50.1 and have tried taking it out, cycling it off then on several times (once for 10 min off). Still get the same error. I see on the websites this is 85% time the LVPS (low voltage power supply). anything else I can try?
Anonymous
Level 2:
Scholar:
  • Expert 107 Answers
  • Posted on Sep 24, 2010
Anonymous
Expert
Level 2:
Scholar:
Answers
107
Questions
0
Helped
44702
Points
382
Replace fuser unit only, keep it simple,
My HP LaserJet printer 5200dtn is displaying error message "50.3 Fuser error" what is the solution to this problem because I can't print
50.3 means the fuser is getting too hot. It will either be a problem with the thermistor in the fuser or the power supply. If you can find a another fuser to test with you can answer the question pretty quickly.
59 co error
An error occurred with the developing
separation-drive assembly.
1. Check that the following connectors on
the driver PCA are seated correctly:
J403, J405, J213.
2. Check that connector J1020 on the DC
controller is seated correctly.
3. Check that connector J5008 on the
fuser motor is seated correctly.
4. Replace the developing separationdrive assembly.
5. Replace the memory-controller PCA.
6. Replace the fuser.
reseat fuser - something may be binding causing error
HP cp3505n. Message is to make sure the fuser is correctly inserted. To push all the way until it clicks. I have but the error is the same. I really need to print. How can I pull it apart? Please help....
Have you power cycled the pirnter. usually if you are going to remove the fuser on this model you need to ensure that the power is off. If you have another fuser you will want to trouble shoot like that
I am getting 50.1 fuser error on my printer cp3505n any advise
50.1 is 'low fuser temperature'
I'm assuming that you haven't been messing around with the fuser.
The book says to upgrade the DC Controller firmware.
If that doesn't work, replace the DC Controller
Go to www.hp.com/#support to find your printer and its downloads
1helpful
2answers
HP Color LaserJet 2840 keeps showing 50.2 Fuser error message. Nothing helps correct problem. What to do? Have tried repeatedly turning printer off, waiting several seconds and turning on again. Each time...
The fuser is the heating unit near the paper exit, and that error means the lamp is burned out, the overtemp sensor is out, or the thermistor in the fuser is bad. About all you can do is replace the fuser. www.precisionroller.com will have a new fuser for you.
HPLaserjet4P - printer service 50 -
A 50 Service error is a fuser error. Turn the printer off for 5 to 10 minutes, then turn it back on. If the error is still there, I think your going to need to make a service call you can try reseating the fuser, but be sure to let the fuser cool completely before touching it.
Good Luck the HP Laserjet 4p is a great printer.
2helpful
3answers
Hello
A 50 Service error is a fuser error. Turn the printer off for at least 10 minutes, then turn it back on. If the error is still there, you can try reseating the fuser, but be sure to let the fuser cool completely before touching it.
If you still have the 50 Service error after reseating the fuser, you might need a new fuser.
You can access the fuser by opening the rear door. It's located directly above the paper tray. There are two screws that hold it in place. Remove those two screws, and the fuser slides outs.
Hope this helps.
4helpful
3answers
Printer HP ColorLaserJet displays Fuser Error
My HP Color Laserjet 2600n Printer is giving me error as
" 50.2 Fuser error " . then every time i have to reatart my printer.
please give me suggestion.
thanks and regards.
ajinmumbai
k24674
Grand Canyon Tech
Grand Canyon Tech
