Question about Sony Grand WEGA KDF-60XS955 60" Rear Projection HDTV
Intermittent lamp turn off
I have a KDF60XS955. When I power it on, the fan comes on, the standby light flashes green several times, the lamp comes on and the standby light goes to solid green. This lasts for less than 5 seconds then the lamp goes out, followed by ~30 green standby flashes, the lamp coming on with the solid green standby light for about 5 seconds then shuts off the lamp again. I can hear/feel the fan running the enitre time. This cycle continues endlessly. Please help!
  • ejchaney May 11, 2010
    Did a simple lamp replacement solve the problem. I have a similar problem, but it will not turn back on now; however, I did replace the lamp and did not seem to make any difference.
  • Michael Hochmeyer
    Michael Hochmeyer Jul 30, 2012
    the lamp is new its not the lamp or the micro switchs
Your lamp is fried just change it i did the same to mine and it works just like a charm
Posted on May 28, 2008
  • Michael Hochmeyer
    the lamp is new its not the lamp or the micro switchs thnks
I was told by the repair service to unplug the power cord for about 5min. This resets the internal computer. I think this helps but does not cure the cause. Good luck.
Posted on May 26, 2008
Sony Grand WEGA KDF-60XBR950 60 green orange green red flashing light
3 blinks is a lamp cover error, did you make sure that the lamp cover is screwed in tight? Also check the lamp cover for deformity, there is a problem with your model where the set over heats and melts the lamp cover a little causing it not to make connection with the lamp cover switch. Let me know if you find either of these problems? If not we can troubleshoot a little further.
Tim Nolan
Sep 14, 2008 | Sony Grand WEGA KDF-60XBR950 60" Rear...
The tv repeatedly turns on then off
First area to check out is the power supply of the set.
Jun 14, 2017 | Sony Grand WEGA KDF-60XS955 60" Rear...
KDF-50a12U Powers off then standby light blinks 3 times
Please recheck Lamp Cover and make sure it is fixed in its space securely as 3 times red blink shows lamp cover error.
There is small safety switch in TV cabinet under lamp cover that has to be pushed by lamp cover if it is fixed in its position properly. That switch is not being pressed by lamp cover and causing this error.
Thanks.
Oct 19, 2009 | Sony BRAVIA KDL-40V3000 Television
KP57WV600 SCREEN TURNS GREEN THEN BLANK
The self-diagnostic function of the projection TV will cause the STANDBY light to blink or flash when the television detects an issue. The number of times the STANDBY light flashes corresponds to a specific issue. As per the two examples below, some of the issues may be resolved without the need for service.
  • If the STANDBY light flashes three times in sequence, the lamp cover is not securely attached. Reattach the lamp cover to resolve this issue.
  • If the STANDBY light flashes four times in sequence, the TV may be overheating. To resolve this issue, ensure that the back of the TV is well ventilated.
If the flash sequence is not listed above or the light continues to flash, follow the steps below to perform a power reset:
  1. Turn off the television. IMPORTANT: For a projection TV that uses an internal lamp, wait 5 minutes after turning off the TV to allow the lamp to cool before continuing with the following steps.
  2. Unplug the TV power cord from the electrical outlet.
  3. Let the TV remain without power for 60 seconds.
  4. Plug the power cord back into the electrical outlet. NOTE: If the TV is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the TV.
  5. Turn on the television. NOTE: If the TV does not turn on immediately, the fan may need to finish its cycle. This is part of the cooling process for some projection TVs and is normal operation. After the fan turns off, attempt to turn the TV on again.
If the issue is still unresolved after following all of the troubleshooting steps, service may be required . Please note the number of times the STANDBY light flashes and relay that information to the service center.
Sep 22, 2009 | Sony KP-57WV600 57" Rear Projection...
Power flashes green then turns red; Lamp flashes red.
is this a flat screen first off
if it is 90% of the time the vid card has over heated they have a video card kinda like pc's one thing is most companies dont put fans on them so they over heat especially when dust start collecting on it wait and see if anyone else has any thoughts on this but im pretty sure thats it you will need to take it to someone that works on tvs to replace it and also ask them if they will install a fan on it
but like i said wait and see if anyone esle has any thoughts on this first
Apr 28, 2009 | Sony Grand WEGA KDF-60XS955 60" Rear...
SONY GRAND WEGA
May 20, 2008 | Sony Grand WEGA KDF-60XS955 60" Rear...
No lamp
whats your location, The power supply is faulty, but fairly easily repaired, if you send it to me, I will sort it out
Feb 13, 2008 | Hitachi CP-X327 Multimedia Projector
Sony Grand WEGA KDF-60XS955 60" Rear Projection HDTV Logo
495 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
